beetle98 Samba Member
Joined: May 09, 2009 Posts: 110 Location: Asheville, NC
Posted: Tue Mar 11, 2014 11:43 am Post subject: My 1957 VW Oval |
Finally, Starting to get some motivation on this car. I figure i will have some questions for the experts. So here is one. Is this the original door panel for a 57 its two tone and most seem to be just red??
bluebeetle1968 Samba Member
Posted: Tue Mar 11, 2014 12:14 pm Post subject: |
That looks like a '60 panel to me...
The ones in my oval are smooth,(no ribs like yours) plain red... _________________ Jan 1968 1500cc - The family project! Celebrating 30 years off the road....
June 1957 "Big Window" Oval Beetle! Yes it does really exist.... |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue Mar 11, 2014 6:07 pm Post subject: |
Ok I wasn't seeing any 57's with those panels.
Would these be the correct seat material as this is the back seat that came in it? You can see in first pic it had red/brick colored door pillar material that was painted black at sometime.
Posted: Tue Mar 11, 2014 11:04 pm Post subject: |
your seat is correct.
I have the same in my car _________________ Jan 1968 1500cc - The family project! Celebrating 30 years off the road....
Foxy Samba Member
Joined: June 10, 2003 Posts: 379 Location: Birmingham , UK
Posted: Sun Mar 16, 2014 9:12 am Post subject: |
The seat is correct. The interior panels should look like this;
Driver's side panel will have no pull handle just a pocket. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Fri Mar 21, 2014 6:56 pm Post subject: |
How about the door panel being from a '65? Two-tone, and no more perimeter beading; '64 was last year for beading. '66 went to single-color panels, a single chrome strip below the handles, and no pleating around the handles. |
Posted: Fri Mar 21, 2014 11:24 pm Post subject: |
Rome wrote: |
1965 door panels is physically larger compared to Pre '64 panels _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sat Mar 22, 2014 6:35 am Post subject: |
RareAir wrote: |
Rome wrote: |
1965 door panels is physically larger compared to Pre '64 panels |
are you sure? |
Posted: Sat Mar 22, 2014 12:00 pm Post subject: floop pans now! |
Fellows thanks for all the replies on the door panels. I still need those but got the body off pan and need 2 off everything else also. haha
So what is the protocol for floorpans I have always read if you can use the originals you should. The fronts of these are pretty nice but the rears are not too good. Is it ok to just do the pan halves to repair these??
New Klassic Fab heater channels on the way and Autocraft rear H apron so plenty to do. Thanks again. chad |
Posted: Sat Aug 30, 2014 5:46 pm Post subject: Question about lowering back of my 57 |
So I'm making lots of progress. Pan almost ready to mount body. I am planning to lower my car and had a quick question. I am thinking 2 outer splines. I didn't mark my angle when I removed so I used protractor and put back to factory specs 13 degrees +-. I then moved two outer splines up. Here is a pic does this look like others positioned at 2 outer splines?? Under no load also!
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sat Aug 30, 2014 6:00 pm Post subject: |
The problem with pan halves is that I'm not sure you can get the correct stampings for an Oval Bug without buying the whole piece. Later or universal pan halves (1/4 sections?) for the rear will not have the correct pattern for the battery area. If that's not a problem for you then go nuts and weld in whatever it takes to keep the spiders out. You'll probably also have to save your buttons for the floor mats and the hook for the battery hold down strap so that you can weld those back on to the new floor pan sections. Looks like you're making good progress though, keep it up! |
Posted: Sat Nov 22, 2014 8:40 pm Post subject: Engine question |
So I have made lots of progress on the 57. Almost all back together. All repairs blended in and buffed out. It's turning out great.
But I'm trying to get it all adjusted properly. When I go to set timing it seems to jump around some and when idling it back fires some and sputters on takeoff. Video is of exhaust backfiring at idle. What should I check first??
http://youtu.be/HffSrZfIXTo |
