timo78 Samba Member
Joined: July 03, 2009 Posts: 931 Location: Overcast and Loving it
Posted: Sat Mar 15, 2014 12:47 pm Post subject: Whats the cause of this variable but consistent miss |
Howdy,
Intermittent issues are the hardest for me to ID.
I've get this random miss/hesitation. But it's context is always the same. It only occurs when I am gassing it, WOT, high intake draw scenarios. It generally hits then it goes away, it is a brief momentary stumble, but hasn't often shown to be a miss, miss, miss type scenario, only a single drop. Weird and an annoyance.
I'm thinking intake leak so....
Vacuum/Intake tests:
-I hooked up a vacuum gauge to the plenum, and get 17-18 fully warmed up. Good
-Gassing it drops to 2, release swings it to 23ish, then returns to 17-18. Good
-Maybe the EEC. A 'Pull' on that held up to 20. unsure but assume ok?
-Also hooked VG to throttle body, 5-thru-10 when throttling depending on aggressiveness
-Distributor holds up to 10, I went no further not wanting to harm
Fuel tests:
The rail gauge shows 28 at idle, and 38 on WOT. assume ok?
I passed over ignition related stuff because it fires right up like a champ even when coldcold. Runs good at speed, and even after initial little miss it'll still climbs good [albeit slow:] I've got a great testing neighborhood. Lots of hills.
What am I missing? Your suggestions are appreciated. _________________ > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it? |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Sat Mar 15, 2014 1:33 pm Post subject: |
This sounds ignition related...check plug wires for cuts,and grounding...the condenser might be on its way out...check the obvious coil connections, distributor cap and rotor...maybe you should go ahead and tune it up... |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sat Mar 15, 2014 2:30 pm Post subject: |
Points or electronic replacement? This is EXACTLY how my electronic points behaved before it became more frequent misses. The trash can solved that problem. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
timo78 Samba Member
Posted: Sat Mar 15, 2014 3:34 pm Post subject: |
Yeah It's is in proper tune. That's part of the frustration. The other is the randomness of occurrence.
It only happens when gassing it under LOAD. I can't get it to miss in testing parked on the curb. Ignition checks out [7.5 idle 28all-in] . It's got pertronix, and a brand new Bosch blue coil. I've had two coils fail in past, but they just went kaput ..not slowly. I have a spare and can test against that.
The last time I had these general symptoms it was a hairline crack/leak in the plastic coupler/gasket between the plenum >>intake tubes,>> and the head. I did drift propane over the whole engine and couldn't get it to spin up, so I did the other tests above.
Took it out today and tried to get to miss and it wouldn't. Its very random in occurrence.
Any other suggestions? _________________ > 78Grµn Westfalia `Donkey`
Posted: Sat Mar 15, 2014 5:08 pm Post subject: |
It would be easy to switch to points to rule that out if there is no other suggestions. Mine would only miss under load on a hot day. Really frustrating. _________________ Learn how your vintage VW works. And why it doesn't!
timo78 Samba Member
Posted: Sat Mar 15, 2014 5:55 pm Post subject: |
So interesting you mentioning heat. That was another thing I noticed in the context of when it happens most/worst. Flawless today, but it's cold out. I was TRYING to make it happen. Gassing the crap out of it all over town.
I may just throw some points in there to test. I like the PX setup and that would be a shame, but oh well running on the old school is better than questionable with the high tech. Thanks _________________ > 78Grµn Westfalia `Donkey`
Posted: Sat Mar 15, 2014 6:02 pm Post subject: |
timo78 wrote: |
I may just throw some points in there to test. I like the PX setup and that would be a shame, but oh well running on the old school is better than questionable with the high tech. Thanks |
Mine wasn't a pertronix brand, but it was 112* out on the way from Phoenix to Los Angeles and I had a deadline. It stumbled like a single cylinder miss like you described, and I didn't want to deal with it so I replaced points since I had them. Later when I had more time I put the module back in and the miss came back with extended heat and load. It got worse so I trashed the module. It was free as part of a promotion, but I won't buy another module outside of Mallory's system. They're the only ones I've tried that have perfect accuracy between the four cylinders. _________________ Learn how your vintage VW works. And why it doesn't!
Desertbusman Samba Member
Posted: Sat Mar 15, 2014 6:24 pm Post subject: |
asiab3 wrote: |
Mine would only miss under load on a hot day. Really frustrating. |
But wasn't yours some off the wall oddball brand and how does that relate to a Pertronix? Wasn't it even missing any identification on the box. Whatever brand it was they sure wern't proud of their product. Maybe that particular brand didn't like heat that day but that's sure not the situation with my Pertronix experience of running in some actual real heat enviornment.
I wouldn't say it's impossible for a Pertronix to ever fail but mine have been maybe the most dependable auto engine item Ive used. With a 2 year guarantee if one did go bad it would be good to replace it versus thinking that they are bad in general.
Last year I did have a wierd ignition problem and did try switching in some points. But the problem also continued until finding that it was some unrelated issue.
When hearing of intermittent Pertronix problems I've gotten to where I just don't buy it. Now a total failure is different. Hooked up backwards smoke quickly comes out of the distributor. _________________ 71 Superbug
71 Westy |
Posted: Sat Mar 15, 2014 10:30 pm Post subject: |
Desertbusman wrote: |
asiab3 wrote: |
Yeah mine definitely wasn't a well-known brand. I also only recommended trying points since nobody else seemed to chime in, it's quick and free assuming he kept the old parts. And I bet the Bosch Fairies didn't switch his wires in the middle of the night to get him to buy points either _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sat Mar 15, 2014 10:39 pm Post subject: |
True that, putting the old points and condenser back (temporarily )in is the cheap easy way to see what's up.
OP, I'm really glad that you revised your earlier post
That was absolutely totally out of line. _________________ 71 Superbug
71 Westy |
Posted: Sat Mar 15, 2014 10:44 pm Post subject: |
(temporarily ) |
Yeah, the 009 I got from a trash can "temporarily" lasted over seven thousand miles while I troubleshooted something else. When I got it out on the workbench last week to clean it up I found out it was a good German one!
OP- let us know what you decide to do. I don't personally know how your FI tests check out, but have you checked the condition of your fuel filter? (Does that even apply to FI systems?) _________________ Learn how your vintage VW works. And why it doesn't!
Hoody Samba Member
Posted: Sat Mar 15, 2014 10:47 pm Post subject: |
How old is your FPR? I would check that first. |
timo78 Samba Member
Posted: Sun Mar 16, 2014 10:56 am Post subject: |
Hoody wrote: |
It's a few years old, and I have the original in the spares box. It seems to check out with the values noted above.
While I had dismissed the ignition. Being that AsiaB3 had similar circumstance and it was ignition related, I will likely do a swap and see if that corrects it. I have a brand new points/condenser set in the spare box. I've had one PrX fail in the past 20years of ownership, and that was due to leaving the key in the ON position for too long. Even then it still worked, but was "under energized" and would throw a yellow/orange spark. Made it a pain to start when cold, but still 'worked'.
I may do some remote monitoring of the engine with Vac/FuelP/Timing gauges hooked up. An idea I've been pondering using the Android tablet camera>spydroid software>streaming/recording to a laptop the gauge readings in back. Feel the dropout and then review the footage to see which gauge drops out in relation.
Thanks for all of the helpful responses. _________________ > 78Grµn Westfalia `Donkey`
timo78 Samba Member
Posted: Sun Mar 16, 2014 3:17 pm Post subject: |
Today drove it like I stole it [if thats even possible with a bus]
70mi round trip in the rain. Which I personally love driving in for the extra cooling it applies. No issue ever showed itself. Random Gremlins!
I'll touch this thread back if/when it is corrected to close out. Thanks for all your suggestions. _________________ > 78Grµn Westfalia `Donkey`
AB westy nut Samba Member
Joined: June 01, 2010 Posts: 1124 Location: Calgary, Alberta
Posted: Tue Mar 18, 2014 2:27 pm Post subject: |
Sounds similar to the issues I documented on my bus last fall. Have you checked your AFM? If you can get your hands on a spare, it's an easy swap just to see if you can replicate the condition. I haven't solved my issue yet as winter came and the bus went into storage, so I share your frustration! _________________ 1963 Ruby Red 356 Cabriolet
1976 Sage Green Westfalia Deluxe |
timo78 Samba Member
Posted: Tue Jul 29, 2014 10:46 am Post subject: |
Continued:
Hesitation-Missing when "gassing it!!" and poor performance. In this instance appears due to a blown distributor vacuum advance can.
Got some time off work, and went back through the systems again recently. In this round the Vac Can bleeds out, albeit slowly. Weird because the can was holding charge during earlier tests. The part# stamp is 581.
[edit] Thank you Karl. 581 corresponds to 07 060 -the spec vac can. >> http://www.thesamba.com/vw//forum/archive/index.php/o-t--t-177103--.html
Now the big question for the sage experts is: Where can I find a replacement? Bus Depot is out of stock on the Bosch originals, and could not recommend a universal. Although "visually" the universals look just like what I've got. CIP1 has universals, [noted for Beetles]
Any suggestions on where a new OG/reman unit can be obtained for a 78 Type4 application?
Thanks!
timvw7476 Samba Member
Posted: Tue Jul 29, 2014 3:37 pm Post subject: Whats the cause of this variable but consistent miss |
when a vacuum can began to fail on me, it would die at stops and stall out
while reversing, like I didn't know how to drive stick + hard to start, like draw
the battery down hard to re-start. If this is not happening to you, check the
resistors at the end of your wires, the two short ones on cyl 1&3, two long
on cyl 2&4, they can get weird when heated and start dropping spark to that
cylinder. Usually only one is reading weird, the rest will be 4K or 5K ohms. |
Tcash Samba Member
timo78 Samba Member
Posted: Tue Jul 29, 2014 4:04 pm Post subject: |
timvw7476
It's almost certainly the vac can in this instance. Thanks though. I see you sell stuff. Ya got any vac cans with 581 stamped on the armature that hold a vac charge?
TCash
Thanks ! I was reading the OldVolks earlier today and noting how wildly different the cans are in their advance/retard characteristics. _________________ > 78Grµn Westfalia `Donkey`
Posted: Tue Jul 29, 2014 4:43 pm Post subject: Whats the cause of this variable but consistent miss |
Sorry, just have a can from '76 that I'm using since the other blew. The
Itinerant air cooled guy was going to try repairs of blown cans with sections of rubber, butyl- stuff if I recall.. don't know if he was successful at it or not,
getting the can apart would destroy the rolled bead that seals it. Plenty of people would like instructions on that repair how-to! |
