Dirtylittle70Bugger Samba Member
Joined: February 21, 2005 Posts: 158 Location: Long Island, New York
Posted: Tue Mar 18, 2014 6:51 am Post subject: BRM/tire combo |
I'm looking to change the look of my car a little bit. I'd like to run a set of silver BRMs on my 67 beetle. The car is lowered in the front with 2.5" drop spindles and about 1.5" in the rear. Stock trans and 67 axles. My plan is 15x4.5 with stock 165s on the front. And 5.5s or 6.5s in the rear with 195/65/15s on the rear. Most of my research says on paper this should work. Is it asking too much to expect the 6.5s to fit under the stock rear fenders with the 195s? I'd like to see a little bit of a wheel lip. Nothing crazy, just enough to know that it's a wider wheel at a casual glance. I hesitate to just get the 5.5s which should be no problem at all. Due to the fact that most people have told me you may not really notice the different with the 5.5s. If all else fails. I may just go back to my original plan of some 6" widened factory 66-67 wheels for the rear. Any info would be greatly appreciated. _________________ I thought I was wrong once, but I was mistaken.
1967 VW Beetle, Java Green, 1500SP, Roof Rack, trailer hitch |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Mar 18, 2014 7:16 am Post subject: |
I would buy the 5.5" since you can run 205's on them to get the tires close to the fenders. I doubt you could run 205's on the 6.5" without rubbing? I would rather have bigger tires than bigger wheels. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Mar 18, 2014 8:48 am Post subject: |
I get that. But I want a stock or as close to stock height tire as I can. I had 205/60s they were too short. And I doubt a 205 in a factory height would fit. _________________ I thought I was wrong once, but I was mistaken.
Posted: Tue Mar 18, 2014 9:41 am Post subject: |
I don't worry about stock height. I have 205X70 & 185X60 on 5.5" wheels to fill the fenderwells with a 1.5" forward rake. I am down 2 splines in front & 1 spline in the rear.
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Tue Mar 18, 2014 9:44 am Post subject: |
A stock height (155/80-15) is 24.8"
A 205/60-15 has a 24.7" diameter, which is about as close to the stock height as you can get.
A 195/65-15 has a slightly larger diameter, at 25.0"
To be on the safe side, I'd go with the 5.5s. |
Posted: Tue Mar 18, 2014 10:56 am Post subject: |
Is the offset of the BRM replicas an issue? I see many people running them so I imagine not. I'd really like the 6.5s but I value function over form. _________________ I thought I was wrong once, but I was mistaken.
Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Fri Aug 01, 2014 7:07 am Post subject: |
Anyone know the offset of the 6.5 BRM's and will the fit a short acle?
Thanks |
