UreKem Paints Samba Member
Joined: March 23, 2014 Posts: 26 Location: Perkinston, Mississippi
Posted: Sun Mar 23, 2014 2:24 pm Post subject: |
One thing I didn't see mentioned was the effect on durability. Generally speaking, as you get the pigment deeper into the depths of the film the durability to fading and gloss loss improves. In a integrated approach (as opposed to just clearing base or single stage) the likely of delamination of the clear on long term weathering is even reduced since the two layers are intimately cured together.
The only real downside I am aware of other than the small inconvenience of mixing clear separately and adding is the effects on metallics and pearl finishes. Often as you dilute metallic and pearl is starts to take on a more coarse appearance. The side tones start to get lighter and face tones look darker. If you like that it's cool but always smart to do a test panel to make sure you like the effect. Generally speaking, base clear is the best approach for pearls and metallics, overall, which is why 99+% of pearl and metallic OEM finishes are base clear. Not to say you can't do nice single stage pearls and metallics.
Integrated single stage solids are still a great approach. |
Doug C Samba Member
Posted: Mon Mar 24, 2014 6:26 am Post subject: |
UreKem Paints wrote: |
The paint companies that do acknowledge this technique tend to add a note on their tech sheets to the effect that adding the optional clear (integrating it) can be done for 'added durability' - but I feel that most of the painters and car owners do it for depth of gloss. Probably different priorities but both are advantages IMHO.
Doug C |
irestorevws Samba Member
Joined: December 23, 2003 Posts: 122 Location: Indianapolis, IN
Posted: Mon Mar 24, 2014 8:25 pm Post subject: |
I'm just finishing my Flint Gray '60. I shot it with DuPont Chroma One with one coat of straight color, second coat was mixed with 25% clear and the third coat with 50% clear mixed in all over gray sealer.
_________________ My wife tolerates me
My neighbors hate me |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Mar 25, 2014 9:09 am Post subject: |
I love that Flint Gray. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Doug C Samba Member
Posted: Wed Apr 23, 2014 10:26 pm Post subject: |
irestorevws wrote: |
I'm just finishing my Flint Gray '60. I shot it with DuPont Chroma One with one coat of straight color, second coat was mixed with 25% clear and the third coat with 50% clear mixed in all over gray sealer. |
Hey irestorevws, I haven't checked in here for a few weeks and I just saw your post.. that paint job looks great and it really makes me that much more certain of trying this technique too. I'm ordering the clear to mix in. Thanks.
Doug C |
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Fri Aug 22, 2014 5:33 pm Post subject: |
Nason single stage cut with their panel clear.
_________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
Doug C Samba Member
Posted: Thu Aug 28, 2014 11:23 am Post subject: |
Looks GREAT! Really nice depth in that. I still haven't painted my car yet.. but I do have a quart of the restoration shop clear (not the one mentioned in their AU tech sheet to spray afterwards) to mix into the final two coats with the AU restoration shop paint. I see these pics you guys post and get all enthusiastic and impatient to get back to my car project. It's been too darn hot here lately though (I have more welding to do first - outside in the sun ).
Doug C |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Tue Sep 02, 2014 6:10 pm Post subject: |
Some of the nicest paint jobs come from trial and error. Mix some paint, do a spray out & clear over it. I used to make my own candy paint by adding single stage color to the clear. My old boss had done it in the 60s, the painter he worked with used to grind up sea shells for a pearl effect. If you talk to some of the old painters that sprayed in the late 50s &60s you will learn lots. |
