D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Sat Mar 22, 2014 9:48 am Post subject: 12 volt flywheel matched to 6 volt system question |
I do apologize if this has been asked in the past. I looked but couldn't really find the info I was looking for.
I want to put an engine with a 12 volt flywheel into a car with 6 volt system.
I have a 36 horse engine with Porsche crank, rods,and 12 volt flywheel. This engine is balanced and blueprinted. I was informed by a renowned 356 mechanic that I would be best off not to remove the flywheel. He said that I should grind some of my bell housing and put a 12 volt gear on my 6 volt starter.
Here's the question: How much do you grind off bell housing? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Mar 22, 2014 10:03 am Post subject: |
http://www.thesamba.com/vw/search.php?cx=partner-p...8208069j44 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Sun Mar 23, 2014 9:19 am Post subject: Re: 12 volt flywheel matched to 6 volt system question |
D. Haviland wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=100126&highlight=12v+flywheel |
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Sun Mar 23, 2014 9:28 am Post subject: |
Is the flywheel from a 912 Porsche? If so it would probably require grinding of the bell housing. If you can get a 356 flywheel, it would bolt right up to the crank and would be compatible with the 6V starter and no grinding would be needed. If the flywheel is a 12V VW flywheel modified to mate with the Porsche crank, it should fit fine but would require a change to a 12V gear on the starter. Personally I would look for a 356 flywheel as that is the cleanest solution. |
