roymartian Samba Member
Posted: Sun Mar 23, 2014 4:18 am Post subject: Fitting chrome to window seals |
Just about to reinstate my new window seals complete with chrome beading.
Any tips on adding chrome;
1. Instal chrome to window rubber prior to fitting to body or after?
2. How to add joining chrome piece?
3. Oval piece does join go at top or bottom?
All hints and tips needed please.
Thanks, |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Mar 23, 2014 8:46 am Post subject: |
1) Fit seal to glass. Fit Chrome to seal. Fit assembly to body
2) The Aluminum joining trim has a small tab on one edge. This fits under the Chrome trim. Then, with a twisting motion, push the clip down into the groove of the seal.
3) ??? _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
vwsonmybrain Samba Member
Posted: Sun Mar 23, 2014 9:16 am Post subject: |
You can use a string in the channel in the rubber where the chrome trim fits to help seat and guide the trim as you insert it, much the same as you use string to fit the windows to the body when installing the glass. Cuts the job in half or more. |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Mon Apr 07, 2014 7:34 am Post subject: |
The 3rd part of your question isn't very clear, but my take on it is that you are asking where the rubber seal joint is situated? On the original rubbers, the joint was on a slant: / and is one way you can see if the rubbers have been replaced or not, as the the later ones are straight l butt jointed at 90 degress.
Make sure the joints are at the highest point (eg Rear Window on the top in the middle) so as to minimise the ingress of water if the seal isn't 100% watertight. |
