Clutch(?) woes...
Rev. Scott
Rev. Scott is offline
PostPosted: Wed Mar 26, 2014 9:41 pm    Post subject: Clutch(?) woes... Reply with quote
'69 type I, 1600 DP, new solid disc friction plate, new Sachs pressure plate (earballed to eighteen pounds), new front shift rod bushing, new shift coupler...Hooks-up in reverse, slips in 1 through four. Turn the cable adjuster out (two clicks) wont go into gear at all. Late, raining, and I'm tired...so I didn't try to split the difference. Pedal feels right. Help?
"I haven't seen one of those since I was shootin' at 'em!"
rustybusjef
rustybusjef is offline
PostPosted: Thu Mar 27, 2014 5:42 am    Post subject: Reply with quote
Was everything perfectly clean ? No extra grease from the pilot bearing ? Does your Bowden tube have enough deflection ? Cable guides in tunnel ok ?
rockurob
rockurob is offline
PostPosted: Thu Mar 27, 2014 6:57 am    Post subject: Re: Clutch(?) woes... Reply with quote
Rev. Scott wrote:
'Sachs pressure plate (earballed to eighteen pounds),
Is this something you did ?? earballed or earbailed ???
or is this what was claimed by the parts house in their
advertisement/description of the pressure plate ???
The pressure plate is not fully engaging on the clutch disk with
the proper pressure to the flywheel ??
If you have the correct free play at the pedal, it should not slip
in any gear, especially with new parts.....it should be fully engaged
with the correct free play
afraid you are going to have to pull out and establish the problem...
doubt if it is going get better
70's....Owner "Der Bug Shoppe" Okla. City
70 Baja Street Rod Project
https://www.thesamba.com/vw/gallery/pix/1644125.jpg
Drag Buggy project:
https://www.thesamba.com/vw/gallery/pix/1726674.jpg
61 Rag Project:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1188580
Rev. Scott
PostPosted: Thu Mar 27, 2014 7:14 am    Post subject: Reply with quote
"earballed", meaning, I torqued the pressure plate by hand...Don't have a torque wrench. This usually works. Clutch cable is free. Bowden has a bend.
rockurob
rockurob is offline
PostPosted: Thu Mar 27, 2014 7:49 am    Post subject: Reply with quote
ok, I now understand Laughing never herd this expression before
did you progressively "earballed" the pressure plate bolts....??
sort of like in a sequence each bolt a little at a time crossing
back and forth between them ?? one can warp the pressure plate
especially on the old 180mm pp.
sounds like everything is correct, but something is not correct ??
still afraid you are going to have to take back out and inspect ??
I am very curious on this....???
(I am also assuming you installed the clutch disk(not upside down))
Drag Buggy project:
61 Rag Project:
58Dub
58Dub is offline
PostPosted: Thu Mar 27, 2014 7:59 am    Post subject: Reply with quote
so the clutch/pp are the only things changed from your earlier set up? What was the issue with the previous clutch?
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
rockurob
rockurob is offline
PostPosted: Thu Mar 27, 2014 8:25 am    Post subject: Reply with quote
good point !
we are also assuming that your flywheel mating surface
to the clutch disk is not scored ??
Drag Buggy project:
61 Rag Project:
Auto Fraser
Auto Fraser is offline
PostPosted: Thu Mar 27, 2014 10:32 am    Post subject: Reply with quote
Previous clutch was slipping, bad. Put a different (used) one in and it wasn't engaging properly. At the same time we noticed the bushing in the shift linkage was busted. We ordered a new clutch and bushing, and installed. Now we're having the current predicament of slipping through all four, not reverse.
58Dub
58Dub is offline
PostPosted: Thu Mar 27, 2014 10:53 am    Post subject: Reply with quote
IF the adjustment is correct and your tube is good....and you are having the same issue with a new clutch disc and PP as you did with the old... I would be looking at the flywheel.
Was this car recently purchased?... or do you have history of the clutch operating properly?
Auto Fraser
PostPosted: Thu Mar 27, 2014 11:25 am    Post subject: Reply with quote
The car has been around for as long as I can remember. I blew up the 1600 dp that was in it fairly recently so we have it swapped out for a 1500 sp that has been sitting in the garage for a while. It ran fine for a week or two before the clutch started slipping. The motor looks like you might expect from something thats been sitting in a garage. Im new at this so I don't really know what I'm looking at as much as I'd like to.
I'll check out the flywheel this weekend. What should I be looking for on it?
rockurob
rockurob is offline
PostPosted: Thu Mar 27, 2014 12:06 pm    Post subject: Reply with quote
Your flywheel oil seal may be leaking oil on the new
clutch disk...and why not reverse slipping ??
drive it more and it soon will....
or the old single port 1500 may have excessive
end play and leaking at the flywheel oil seal also ??
the flywheel surface to clutch disk....
should be clean, not burnt looking and
not scored and or have groves
lines in it......go to any vw vendor web
site and pull up a photo of a new flywheel
and compare
Drag Buggy project:
61 Rag Project:
Cusser
Cusser is offline
PostPosted: Thu Mar 27, 2014 12:18 pm    Post subject: Reply with quote
If I had a slipping clutch, I would always have the flywheel resurfaced or replaced, and new pressure plate and disc; this is not just "throw in a new disc because I'm in there" maintenance.
Rev. Scott
PostPosted: Thu Mar 27, 2014 7:49 pm    Post subject: Reply with quote
Some clarity (I hope)..."Auto Fraser", in this thread, is my son and it is his car we are pondering. The "backup motor" is a crappy old thang, but it chugs along. The clutch it had worked just fine...but started slipping. The throwout and arm are newish and of quality. No leaks at the seal. Flywheel (200mm) could be freshened...but I've gotten down the road with worse.
Again...two "clicks" out and it grinds in every gear, two "clicks" in and it slips. 'Splain the bowden please? It looks to have the correct "sag". Maybe I have this wrong. Also questioning if I may have over torqued the pressure plate, but this not the first clutch job I've done.
Thanx for all the feedback!
58Dub
58Dub is offline
PostPosted: Thu Mar 27, 2014 9:21 pm    Post subject: Reply with quote
hmmm...Ive never used a torque wench when installing a PP..... I really doubt that is causing your issue. It the TO bearing isnt holding it ....Id measure the flywheel and clutch disk.... one of them has to be bad. when you say its a solid disc ...is this a stock type clutch disk or a Puck type?
Rev. Scott
PostPosted: Thu Mar 27, 2014 10:28 pm    Post subject: Reply with quote
Wolfgang "stock" friction plate.
58Dub
58Dub is offline
PostPosted: Fri Mar 28, 2014 2:27 am    Post subject: Reply with quote
since you are into one of these odd issues, I think I would pull it and measure everything. For some reason, you arent getting enough squeeze in there.
jhoefer
jhoefer is offline
PostPosted: Fri Mar 28, 2014 9:11 am    Post subject: Reply with quote
Sounds to me like you don't have enough travel at the throwout bearing. Going in, it's probably not letting the throwout bearing release all the way so the pressure plate won't have full clamping force (and will burn up the throwout bearing). Going out, you have full clamping force but not enough travel to fully disengage the clutch so it's still spinning the trans preventing the synchros from working right. The adjustment range shouldn't be that narrow in either case. Some possibilities: cross shaft forks broken, clutch release arm too long, cable tube inside tunnel broken loose, hook on pedal failing, cable stretching and near failure, pedal stop incorrectly set resulting in limited pedal travel.
That's assuming there isn't something wrong the the clutch/pp/fw, wrong dimensions, etc.
Rev. Scott
PostPosted: Fri Mar 28, 2014 6:47 pm    Post subject: Reply with quote
Going to play with the Bowden tomorrow...
Rev. Scott
PostPosted: Sat Mar 29, 2014 1:52 pm    Post subject: Reply with quote
Bump...with a hail Mary.
Bowden checks out okay. Mounts all look good. Read the forums till my eyes crossed. Almost too much play at the pedal. This car can do burnouts in reverse...but all forward gears slip to the point that the car wont move! WTF?
The initial problem was slipping (after working fine for some time). Replaced clutch with known good Kennedy (bit overkill) But it was grinding or slipping. Bought everything new just to know it was all new. Same problem, not disengaging in FORWARD gears. GAH! Somebody please talk slow and simple to me?
66brm
66brm is offline
PostPosted: Sat Mar 29, 2014 9:58 pm    Post subject: Reply with quote
STOP doing burnouts in reverse or you will be busy changing out the transmission. Its time to pull the engine and have a measure of everything, also have your flywheel ground properly to improve your chances
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
