Fuel tank wiring - 86 rabbit - please identify this plug
Forum Index -> Water-cooled VW Share: Facebook Twitter
landkholdings
landkholdings is offline
PostPosted: Sat Mar 29, 2014 6:13 am    Post subject: Fuel tank wiring - 86 rabbit - please identify this plug Reply with quote
This little plug and the wires coming out of it are toast. If anyone knows what it's called, a part number, or where to get one, it would be greatly appreciated. I have searched to no avail.
Thanks in advance
Kevin
ps2375
ps2375 is offline
PostPosted: Thu Apr 24, 2014 3:19 pm    Post subject: Reply with quote
That is the power to the intank pump and also the fuel level sender. I would hit up a salvage yard and get one with some of the harness there. You may have a pump going out, that looks to be quite some current draw to melt the wire that much. If the burnt wire is the pump. Check a Bently wiring diagram to determine which wire is for what. Or you may have just had a short at the sharp edge of the cover.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
