notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Wed Aug 27, 2014 3:45 pm Post subject: |
This is what was there.
And then covered by a belly pan.
Yes most of the buses sent to the North Americas have a heated rear window as standard. If there was a case to see it deleted - it would be in a commercial bus. Mine has the defrost rear window. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Posted: Thu Nov 06, 2014 11:12 am Post subject: |
So I bought a new house - yeah! No more disposable income. I love the new place but dayum. I sure dont like the moving. To top it all off, we kept the other home and rented. So that all had to be dealt with on top of it all. We are now coming out the other side of the moving madness finally.
One of the best things ever was using this bus for what its intended. Hauling
The new home isnt to far from the old so this little bus proved invaluable for lots of runs back and forth. I may put all projects on hold so I can pull the motor - detail clean and fix the eberspacher. The bus deserves it!
t3kg wrote: |
1964 1500 S
Xevin Samba Member
Posted: Thu Nov 06, 2014 11:50 am Post subject: |
Nice! Congratulations on the new house
Dig that that blue panel. Kind of miss the ridiculous
Teddy Bear paint job. That was over the top. So bad it was good.
The blue is proper though. Good luck with the move. |
1967250s Samba Member
Posted: Sun Dec 07, 2014 8:27 pm Post subject: |
[quote="notchboy"]This is what was there.
Can someone describe all that stuff under there? I have a '72 and don't have any of that crap. Does any of it help the heat? _________________ '72 Elm Green Deluxe |
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Sun Dec 07, 2014 8:40 pm Post subject: |
That middle rectangle box is a BA6 gas heater. I don't believe 72 came with a BA6 but could have came with a BA4 heater that was located in the engine bay. But both were optional not a standard item. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Sun Dec 07, 2014 9:31 pm Post subject: |
Yep. That is a BA6 Eberspacher Gas Heater. A very optional accessory. It is meant to heat you up more so than the motor can. It came out in 74 I believe and went through the Vanagon Era. If your Bus had an optional heater in 72 it would of been a BN4.
I was lucky to find a panel with this heater on it from the factory. One of the reasons I bought it. I have yet to actually get the thing running - but its all there. _________________
t3kg wrote: |
1964 1500 S
Zelten Samba Member
Posted: Sun Dec 07, 2014 9:39 pm Post subject: |
Jason, are those pictures from under your bus? Is that belly pan steel? It almost looks fiberglass in those pictures. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Sun May 24, 2015 8:36 pm Post subject: |
Not much on improvement. Biggest hing was the hangers for the seat belts Looking slick
I did get a goofy light for the top when I use the bus for emergency services.
t3kg wrote: |
1964 1500 S
Xevin Samba Member
Posted: Mon Jun 15, 2015 5:01 am Post subject: |
Was the clock in the bus when you bought it? Or did you pull that out of the "Toy box"? _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Mon Jun 15, 2015 5:10 am Post subject: |
Thought you might like this
Clatter wrote: |
SGKent wrote: |
Posted: Mon Jun 15, 2015 9:20 am Post subject: |
Xevin wrote: |
Was the clock in the bus when you bought it? Or did you pull that out of the "Toy box"? |
That came from the stash
Cant have a delivery vehicle if you don't know what time it is, right? Gota have an Eberspacher to keep you warm on those cold days delivering out to Timbuktu and you gotta be able to clean the headlights and windshield off while traveling the path less taken, right???
t3kg wrote: |
1964 1500 S
Xevin Samba Member
Posted: Mon Jun 15, 2015 11:29 pm Post subject: |
Buddy. Sorry to drop this on your thread. I know you can appreciate seeing
Two NBs, in two days
Don't worry about that jank mirror on Rusty.
DaleNW gave me his hand me downs.
Clatter wrote: |
SGKent wrote: |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
eche_bus Samba Member
Posted: Fri Nov 20, 2015 10:53 pm Post subject: Re: 1976 Canadian Delivery Commercial Panel Bus |
That FLIR video was really interesting to see. Thanks for sharing! |
