jason Samba Member
Posted: Sun Mar 30, 2014 12:54 pm Post subject: Vert rail replacement question |
My car needs the rails replaced. The body is already out of wack. I pulled the body together until the rear door gaps are even. The problem is one side is wider than the other. One side is 4mm and the other is around 5.5mm. My question is should I adjust for door gap or make the door holes the same which is hard because I cant find a place to measure that is the same on both sides. |
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Mon Mar 31, 2014 5:45 pm Post subject: |
Did you you look in the Body/Paint section on the samba? There is a sticky on convertible channel replacement. Also do a search in the Body/Paint section for that type of repair. _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
jason Samba Member
Posted: Mon Mar 31, 2014 8:41 pm Post subject: |
I did, |
smmf Samba Member
Posted: Fri Apr 18, 2014 8:33 pm Post subject: |
Is the body off the pan? If not, can it be bolted back up? Once bolted up check the door gaps, if the gaps are good, reinforce the body so it doesn't move when you unbolt it. Make sure the body bolts at the back by the shocks and the front beam are bolted down
With a gap difference like that the body is tweaked (twisted)
Bolting it to the chassis is the perfect jig to square it up |
