Rjhdog Samba Member
Posted: Mon Mar 31, 2014 8:35 pm Post subject: Just replaced all shift boots and seal. Now shift issues... |
I just replaced all the boots on the shift linkage next to side of tranny. I also replaced selector shaft seal as well but removing the reverse housing on other side of tranny.
Re greased all bushings etc.
Reinstalled everything and now I am having a very difficult time getting it to shift properly. The shift ball is coming half way out of the cup when shifting into 2nd or fourth as well as reverse and then jams up as the ball hits the edge of the cup. The shift rod has too much movement forward.
I tried adjusting shift plate in cabin but to no avail.
Please help!
Is it possible that the shift ball level can be reinstalled incorrectly. I think there is only one way for the teeth to align, right?
It's almost like the ball isn't far enough down in the cup but I may be incorrect.
I did try hammering out the roll pin and may by some chance bent the linkage rod but I hope that's not the case.
Any thoughts here.
Thanks! |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
Posted: Mon Mar 31, 2014 8:51 pm Post subject: |
Possibly misindexed shift arm on shift shaft? It is supposed to be horizontal in neutral. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
Rjhdog Samba Member
Posted: Mon Mar 31, 2014 9:16 pm Post subject: |
vanonimous wrote: |
Possibly misindexed shift arm on shift shaft? It is supposed to be horizontal in neutral. |
Could you further explain? How would one mis-index the shift arm? |
PDX_Greg Samba Member
Joined: August 26, 2012 Posts: 39 Location: Portland, OR
Posted: Mon Mar 31, 2014 9:28 pm Post subject: |
Did you adjust the linkage in the gear box (from under the van)? Bentley shows you how and provides the correct measurement for adjustment. The shift plate is only for minor adjustments. _________________ 1987 Full Camper Westfalia, 2.1 WBX |
Posted: Mon Mar 31, 2014 9:31 pm Post subject: |
Just looked at a spare I have and it can not be misindexed. There is a spline missing from the factory preventing that scenario.
I just rebuild both my van's shifters and they shift beautiful. I did it without separating the shift rod, did you separate yours? _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1001 Location: Oakland CA
Posted: Mon Mar 31, 2014 10:10 pm Post subject: |
Check the bracket that holds the shift rod to the transmission forward of the ball. You may have it on the wrong side of the mounting point. This can be connected either forward of aft of the attachment point. I'll check in the morning, maybe with photo. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Rjhdog Samba Member
Posted: Mon Mar 31, 2014 10:11 pm Post subject: |
If I understand this correctly:
I did separate the shift rod in order to hammer out the roll pin to remove the cup in order to replace the boots. If that's the shift rod you are asking about.
It was just a circlip and pin at the knuckle midway up to remove the rod if I am talking the same thing?
It's good to know that its impossible to misindex...
So is adjusting in the box my issue?
I didn't mess with that at all so I don't understand why i would need to readjust that?
Rjhdog Samba Member
Posted: Mon Mar 31, 2014 10:17 pm Post subject: |
[quote="davideric9"]Check the bracket that holds the shift rod to the transmission forward of the ball. You may have it on the wrong side of the mounting point. This can be connected either forward of aft of the attachment point. I'll check in the morning, maybe with photo.[
I have the mounting plate attached forward to the front of the van. I could see how the mounting plate could get attached on the other side towards the rear. Is attached towards the front correct? |
goffoz Samba Member
Rjhdog Samba Member
Posted: Mon Mar 31, 2014 10:37 pm Post subject: |
I mounted plate on the ears so plate is closest to front of van. Is that right?
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Mar 31, 2014 10:37 pm Post subject: Re: Just replaced all shift boots and seal. Now shift issues |
... _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
Rjhdog Samba Member
Notice how ball comes out of cup and jams up.
Any thing look incorrect in terms of mounting placement?
Thanks all
levi Samba Member
Posted: Mon Mar 31, 2014 10:43 pm Post subject: |
Rjhdog wrote: |
I mounted plate on the ears so plate is closest to front of van. Is that right? |
Yes, to the front is correct _________________ One of these days I'm gonna settle down,
https://youtu.be/cSrL0BXsO40 |
Rjhdog Samba Member
Posted: Mon Mar 31, 2014 11:17 pm Post subject: |
Thanks mate. I tried searching but alas I didn't see this post.
It helps somewhat. I don't understand how the shift lever with ball (that what is know as j" part?) can be installed backwards. Ball should boing down and splines side on the inside to attach to the shaft. ????
Can the shift lever with ball be misaligned by being a spline or two off angle? I thought it had two flat spots to prevent one from misaligning? That could be my problem. The angle could be too far forward in neutral. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Tue Apr 01, 2014 6:52 am Post subject: |
Did you replace the ball? It looks like it is just too short, but there is no adjustment for how deep the ball is in the cup. If you did replace it, compare it to the old one. From the factory, there is a special nut and washer that sometimes gets lost. The bracket is then not secure against the shift rod splines. If you only have the nut, it will not tighten down correctly, because it hits the splines. _________________ ☮️ |
Rjhdog Samba Member
Posted: Tue Apr 01, 2014 7:56 am Post subject: |
Same parts. Same ball and cup. Only thing new are boots and seal.
I think that I misindexed the ball part at the splines. Is it possible to install off angle although it looks like the slots for the splines look to go on only one way? As there are two flat spots on part? |
wecm31 Samba Member
Joined: August 05, 2012 Posts: 359 Location: Eganville, Ontario
Posted: Tue Apr 01, 2014 8:13 am Post subject: |
Rjhdog wrote: |
I have changed my ball piece and was quite careful to get it back on
in the same spline orientation. I seem to recall that it would go on in
any position, don't recall any flats that would act as a key or locator.
If that is true....then you could remount the ball piece to obtain better
meshing angle with the cup.
I'll get into the archives and post a picture of my ball prior to removal,
it might help you. _________________ Gerald P
1985 Vanagon (Betty) & 1985 BMW R80RT (Wilhelm)
vintage boxers!!
Gone are the days we stopped to decide
Where we should go, we just ride:) |
goffoz Samba Member
Posted: Tue Apr 01, 2014 8:32 am Post subject: |
From what I can see in your pics, maybe, when you reassembled the yoke, you shortened the linkage slightly.
check just forward of the yoke, there is a clamp joint where the shift rods slide into each other, they can be shortened and also be rotated here.
If your clamp is loose, it could have slipped in a bit shortening the whole thing.
This would explain why your cup is travelling to far forward.
I assume you pulled the rubber boot for the pic, but in case you don't already know , that boot on the cup can seat all the way down.
There is a grove in the plastic, above the ball that the boot snaps into, then the lower skirt can slip over the cup and will stay there.
Its awkward to do |
Posted: Tue Apr 01, 2014 9:53 am Post subject: |
With the van in neutral, with the shift rod disconnected, it should point straight down. From memory, the shift shaft is missing one tooth and the ball piece should only fit in one spot, but like I mentioned earlier, if it was misinstalled and running loose, it could be completely hammered. I'd be inclined to replace the ball piece anyhow as part of this repair. It does wear. _________________ ☮️ |
Posted: Tue Apr 01, 2014 9:58 am Post subject: |
I had the exact same problem when I took things apart in this area (and not the joint in the shaft). I wish I could remember howI fixed this, but I do know I had something assembled wrong, maybe the shift lever (ball piece) was not seated correctly. Double check the assembly before you replace anything. _________________ 1987 Syncro Westfalia, stock (bought 1994)
