shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
Posted: Tue Apr 01, 2014 12:36 pm Post subject: When a car has been re-painted |
My '66 Beetle is in very good condition. Preparing the car to be sold the original owner had the car re-painted without removing any of the windows. I have two project planned that will require the windows to be removed. The windshield has a break and needs replacing and I want to install pop-out in the car. Knowing what the window opening will look like when they are removed will there typically be an ugly paint line after the new seals and windows are installed? Will new seals usually over lap the paint line?
I've considered having all of the windows removed and those areas feathered and re-painted for obvious reason but it would be a little more than I want to take on right now. _________________ Pearl White 1966 Sedan
Retired US Army - 21 years 11B40, 173rd Airborne Brig. - Vietnam Combat Veteran |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Apr 01, 2014 1:29 pm Post subject: |
the front seal would be 50-50 that it will cover the paint line. the rear pop-outs will for sure show the paint line when opened. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Apr 01, 2014 2:25 pm Post subject: |
yeah you better make yourself ready for some blend-in painting
I sometimes 'cheat' when repainting a car: I leave the old windows installed but cut the edge of the old window rubbers back 1/8-inch with a sharp knife.
After the car is painted, replace the glass with clean pieces and new rubbers.
The new rubbers will conceal/seal the fresh paint's edge
Doing this saves lots of work with masking paper |
