Ohio_Style Samba Member
Joined: July 09, 2007 Posts: 610 Location: You'll never leave Sparta alive, Ohio
Posted: Sat Apr 05, 2014 7:56 pm Post subject: Removing rust from sandblasted panels Eastwood fast etch? |
Disclaimer: I have don't my share of body and paint work, and typically would just have this blasted, but I don't really want to deal with all the sand mess and I don't want to blast the whole thing.
My 65 double cab had the inside upper cab walls and dash sandblasted by a previous owner and then it sat for a good amount of time. It has a good amount of surface rust, the flat areas clean up pretty well with a roloc scotch pad on a angle die grinder, but all the nooks and crannies, as well as the fuel tank area are going to be impossible to clean this way.
I'm looking at thishttp://www.eastwood.com/review/product/list/id/4967/category/234/?p=3 to kill the rust, then coat with a good primer sealer before paint. The reviews seem to be excelent. I have used naval jelly plenty of times, but I don't want to wash it down with water and flash rust again.
Anyone used this stuff with luck? Any other methods I should be looking at? _________________ Matt Johnson
Slammed Thing
https://www.thesamba.com/vw/forum/viewtopic.php?p=9278729#9278729
Lifted Split Bus Build
https://www.thesamba.com/vw/forum/viewtopic.php?t=738403 |
c21darrel Samba Member
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Mon Apr 07, 2014 9:08 pm Post subject: |
I sprayed some panels about a year ago and they are still clean but it probably is just straight phosphoric acid. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Tue Apr 08, 2014 8:41 am Post subject: |
You don't have to meticulously clean off the acid before spraying it with primer. Any primer sticks to it like glue. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
