bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Posted: Sun Apr 06, 2014 11:45 am Post subject: So i bought a 3D printer |
As the title say's me and my brother have gotten a hold of a 3D that's at our disposal . Now the question if I was willing to print some parts out, what would you guys want?. I will upload some pics later. _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus |
Jake Hoff Samba Member
Joined: February 22, 2008 Posts: 166 Location: Southeast, South Dakota
Posted: Sun Apr 06, 2014 12:43 pm Post subject: |
A 21 window deluxe
I was going to ask for a 23 but I don't want to be greedy |
punkabillyvw Samba Member
Joined: November 12, 2013 Posts: 86 Location: Waco Tx
Posted: Sun Apr 06, 2014 1:19 pm Post subject: |
headlight and hazard knobs with vw emblem cut out so i could put little led inside |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Wed Apr 09, 2014 4:25 pm Post subject: |
I have a non-vw, non-car app in mind. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Thu Apr 10, 2014 6:34 am Post subject: |
it appears that the 3D technology has not yet advanced beyond making cute little plastic octopuses! _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Posted: Thu Apr 10, 2014 12:25 pm Post subject: |
How about the plastic parts in a '65 sunroof? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Sat Apr 12, 2014 8:48 pm Post subject: |
what kind of plastic does the scanner use? any way to get rid of the record type ribs on the models? 3D printing stuff is pretty sweet. what are your dimensional constraints to scan or print? _________________ Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Sat Apr 12, 2014 9:42 pm Post subject: |
Dr OnHolliday wrote: |
I have a non-vw, non-car app in mind. |
Me too they are 80% something or other... Haha
There is a company here in town that makes them and for $40 it's all yours, no jig required. Pretty good stuff I have two of them... _________________ Stupid people do stupid things. |
Posted: Sat Apr 12, 2014 10:36 pm Post subject: |
^^^ I want one that's 100% + % for aluminum shrinkage, to use as a reusable pattern for casting them in aluminum...
I thought most guys, or maybe just the most geeky, used cadd files to print parts.... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Apr 13, 2014 5:29 pm Post subject: |
Can you make me some trimmer line for my weed whacker? _________________
EverettB wrote: |
FU#5 |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1765 Location: Newmarket, ON
Ace Samba Member
Posted: Sun Apr 20, 2014 9:47 am Post subject: |
I didn't see any treanslucent filament. Did you find any? |
Posted: Fri Aug 15, 2014 1:11 pm Post subject: |
the little plastic catch in the glovebox latch for late beetle would be great ive bought three now and they have all broke in matter of weeks way to brittle nice hard plastic or the ability to make one then mold it for a pewter or lead replacment |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Sun Aug 17, 2014 3:39 pm Post subject: |
An e brake handle in the shape of brass knuckles.
And a center post lift for garage. _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
Posted: Sun Aug 17, 2014 3:46 pm Post subject: |
And a VW key but with a twist. Here is my main power cut off and i would like a key that has the round VW logo in it. I can send you the dimensions?!
The Phil Samba Member
Posted: Thu Apr 02, 2015 11:36 am Post subject: |
Thread bump.
So no one else has interest in a 3D printer?
I noticed the op mentioned scanning parts. While that is very cool and I have yet to to get a scanner set up, I have a printer I share with my dad.
He is a design engineer and I've been learning how to use the program solid works. It's amazing what we've printed up for fun and what we've made to fix household things. _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook Dec 2012. No other Social Media. |
Posted: Thu Apr 02, 2015 1:02 pm Post subject: |
The wheel on my dishwasher upper rack broke last night. Can't order just the ten cent piece I need, have to order the whole twenty dollar kit.
Was just thinking it would be nice to have a 3d printer for just this kind of crap around the house. _________________ Royals 2015 World Champions
Posted: Thu Apr 02, 2015 6:17 pm Post subject: |
Tbird,
I understand the frustration. The cheap chrome plated bezel on the hose sprayer of my sink broke. Thanks to our printer, we just printed a grey bezel to replace it. We've also made new eyeball jets for the pool. Leslie's pools wants around 25-35 bucks a pop. Poof, 10 hours later, i've got my own custom designed bright orange eyeballs in the pool. I think they are rather fetching if you ask me.
Here's the printer company that we bought from. I have the Rostock Vmax 2.
http://seemecnc.com/products/rostock-max-complete-kit
The deal is, you can get it for a grand, (really cheap consider the footprint size that it can handle) but you have to build it yourself. Now, the directions for it are among thee BEST step by step directions (PDF) that I, or my engineer father have ever seen. In some steps, it even has quick youtube tutorial links. all the from building it, to setting up firmware, installing it on the computer, how to tune it in, everything. There is nothing that went unnoticed.
Oh, last note: the software for it is online, and free. Open source. It doesn't get any better than that.
PS: here is a forum on 3d printing
http://forum.seemecnc.com/viewtopic.php?f=38&t=1581` _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
