easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Mon Apr 07, 2014 10:13 pm Post subject: Allstate single wheel trailer data plate location |
I got my trailer back from body/paint & was reassembling when I noticed the data plate holes are gone.
Can anyone pull a couple hole measurements from the passenger side body seam?... where the front panel meets side panel.
Also up from the bottom lip?... or up from cargo floor.
Thanks,
E
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Daniel Samba Member
Posted: Tue Apr 15, 2014 2:41 am Post subject: |
Hi,
Just measured one: 25mm from the side seam and 120mm from the bottom lip.
It was a bit dark so plus or minus a mm or two!
Cheers, Daniel. |
easy e Samba Member
Posted: Tue Apr 15, 2014 8:51 am Post subject: |
Thanks!
I tried using a rare earth magnet inside the bed & steel filings on the painted side... move magnet around to locate a hole. I wasn't successful, but maybe with a narrowed focus I'll have better luck.
My backup method to find a hole will be to scrape away some of the inner bed coating & find a hole... re-coat. _________________ aka: Evan
