bad1916 Samba Member
Joined: November 14, 2010 Posts: 224 Location: Camarillo ca
Posted: Thu Apr 24, 2014 10:43 pm Post subject: |
Check out the feedback on punchdrunk in the buyer seller feedback before you order. _________________ SEMPER PARATUS!
1963 SQUAREBACK |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Fri Apr 25, 2014 11:09 am Post subject: |
You can still do it without swapping beams. I didn't swap beams and it is able to move the chassis up and down without any issues. I know the air pressure will be higher in the front because of the torsions that are left in the beam, but I don't think this will be an issue. My system is at 150psi max. I see the torsions in the beam as a fail safe. If the front air shocks do go out, then I have the torsions to keep me from fully bottoming my front beam/chassis. I just lower the car to the lowest I ever want to go.
All I gotta say is that the Accuair system is the shits!
markpetersonii wrote: |
It's good to read this, mainly because I contacted AccuAir and they recommended me to get the beams swapped and referred me to Punch Drunk Customs, which specializes in air-ride VWs. I sent them an email about a week ago and still no response. Oh well. Their loss.
If I can do it without the need to swap the beams I'd be all over it. I still want to use AccuAir's system. Everything I saw at an open house they were at, I liked. |
_________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
dpetteng Samba Member
Posted: Fri Apr 25, 2014 1:42 pm Post subject: |
Thanks all, I am going to leave the torsions in to start with. Just need to find an auto levelling 2 way system.... |
Posted: Tue Apr 29, 2014 2:31 pm Post subject: |
anyone know of a levelling 2 way system? |
Posted: Wed Apr 30, 2014 12:14 pm Post subject: |
Ah I get it, so you combine this with levelling bits... see - I know nothing |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Apr 25, 2015 1:24 pm Post subject: |
squareonair built his own 4 way air beam etc & is still welding up custom & extended beams in MO. I would ask him about custom work!
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oxsign Samba Member
Posted: Sat Apr 25, 2015 2:40 pm Post subject: |
Yeah, I've talked to him a few times on Instagram about his beams. I was asking about the use of the factory beam with the airshocks. Just wondering if he did it, and how they've worked out in the past year plus since the post. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
rays-64 Samba Member
Joined: April 02, 2010 Posts: 343 Location: corona, CA
Posted: Sat Jan 30, 2016 2:49 pm Post subject: |
supersuk wrote: |
I'm using the MONROE MA785 shocks. I forget, but I think I removed the metal and rubber bushing from the OEM shock and put it into the Monroe shocks. |
Did you have any problem with that shock hitting the upper control arm. There is another thread where the same shock could not bolt up without modifying the top shock mount location. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Sat Jan 30, 2016 6:40 pm Post subject: Re: Air Ride without changing Beam? |
I don`t think I would rely on a pair of Monroe air shocks alone to support the front end of anything. They aren't meant for that. They are meant to be used in conjunction with leaf springs or torsion bars. _________________ If you`re going to do something, do it right. |
