1969 Bug Build
Page: Previous  1, 2, 3, 4 ... 10, 11, 12  Next
zodlaw
zodlaw is offline
PostPosted: Thu May 29, 2014 7:52 pm    Post subject: Reply with quote
Yess! I got the front end out finally Applause It still looks strait but I will put a square on it before I start.
Also the adjusters showed up today. I still trying to figure out if I am going to modify them so the nut is on the bottom instead of the inside. If I did that I would prob extend the the sides and slot the top more so I would have more adjustment. The plans are to use the adjusters with the monroe air shocks untill or if I need the thru rods. I am going to say about a week to get this done so I don't have to rush.
Does anyone know the clearance needed between the towers to clear? Mine is kinda smashed up. If I ever want to use this on another car I want to make sure it clears with out any pounding to be done. Smile Let the fun begin Twisted Evil
68 build that had been sitting for 18yr in a garage.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8119987#8119
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0
zodlaw
zodlaw is offline
PostPosted: Mon Jun 02, 2014 4:20 pm    Post subject: Reply with quote
Spent about 20 min bending smashing and hitting the front apron. It latches and locks. On a side note went to woodburn bug show it was a good time. Figured after seeing all the dubs and talking to a few people going 4" beam. I have started cutting off the brackets for the pan head, very slow. I am at 45 min and its still on. Sad I should have the beam done this week and hope to bolt it up next week.
zodlaw
zodlaw is offline
PostPosted: Wed Jun 04, 2014 12:10 pm    Post subject: Reply with quote
Well I got the fixture done and the brackets off.
I used this small table because I could get all the clamps on it. I also tacked the fixture down after I welded the center braces.
After the fixture cools off, I will start cutting the front beam with a pipe cutter and taking 6 inches out Very Happy 4" for narrowing and 2" for the adjusters. Wink
zodlaw
zodlaw is offline
PostPosted: Thu Jun 12, 2014 7:42 pm    Post subject: Update! Reply with quote
I finally stayed after work to finish up the beam thus far. It was taking to long nibbling at it. Tomorrow will start on the rest.
I tried to fit the beam in I knew it would not fit because of the towers. I think for this one I will make the dub fit around the beam. If I fix the front end down the road I will deal with changing the beam later. I won't have to take the whole thing apart to do that. So I added on to the adjusters and notched the slots .5 inches. The only reason I did this is because I am going air shocks down the road. I will prob be running static for a while and if I put dropped spindles on then I want to be able to adjust it up more.
Whats left?
move zerk fitting
Final inside cleaning (make sure I get all the crap out, for the 3rd time)
Shock stabilizer bracket
Steering stop bracket (Don't know if I am going to put that on)
Dimple and cut leaf springs
zodlaw
zodlaw is offline
PostPosted: Wed Jun 18, 2014 7:12 pm    Post subject: Reply with quote
Very Happy Beam is ready to fit up! Almost three weeks it took. It was good experience but I would buy one if the funds allowed. It was no too hard but really messy when it came to the grease.
Next up are the tie rods after I clean up the steering box. I am trying to track down a 14mm tap. If I can not find one, I will cut and re-weld them up. Laughing
zodlaw
zodlaw is offline
PostPosted: Mon Jun 23, 2014 9:47 pm    Post subject: Reply with quote
Well the bad news That zerk fitting I moved, it hit the steering box. So I had to take it out. At this point I need to get the bug out of the garage and moving. I will have to move it 2" or so to the right side of the steering box. If the bearing is not in the way. Sad Live and learn I guess. I have been out of the loop for long time so I will know next time, If there is a next time. Smile
So I did 3 inner splines on the back and I have 165s. The front is the 4" narrowed beam with NO dropped spindles. right now the tires are hitting the head light buckets. Don't know what I am going to do cut them or find some small tires. I will prob cut them because the fenders are hosed anyways and they are pushed back a little.
So going to hunt some cheap tires down if I can find any. Razz
puddle
puddle is offline
PostPosted: Mon Jul 07, 2014 8:36 am    Post subject: Reply with quote
Too bad the front end is dented up, would look good rolling just like that Cool
1970 Bug
2011 Jetta TDI
2007 Toyota Tacoma
zodlaw
zodlaw is offline
PostPosted: Mon Jul 07, 2014 8:50 am    Post subject: Reply with quote
Yeah, I wish it was not all bashed up but I not complaining. Its fun to tinker on though. I am trying to figure out what to notch in the rear spring plate wise. Might have to cut off the bump stop and notch the either the swing arms or the shock mounts. Just waiting for the cash to come in if ever. Smile
zodlaw
zodlaw is offline
PostPosted: Mon Aug 04, 2014 4:05 pm    Post subject: BAM! Reply with quote
This is the first fit up and they looked just as I thought they would.
Side shot the rims are even with the end of the fender. I might have to roll them a little so I don't get any tire rub. I don't know what size I am going to run yet. The 145/65 are out as they are only suppose to go on 5.5 rims and these are 6 wide.
There is plenty of room under and back side of the rims
I had to see what the white looks like.. not sure yet. Smile
I took a pic of this just for ref in the future for anyone else looking for info on these as I could not find much. Tried to get it to focus but no luck.
zodlaw
zodlaw is offline
PostPosted: Tue Aug 05, 2014 4:15 pm    Post subject: Test paint Reply with quote
Just trying to figure out some colors for these wheels before I get them powder coated. I am still picking away it.
Just about to place the order for the dropped spindles and lowered ball joints. Laughing
bug-ugly
bug-ugly is offline
PostPosted: Tue Aug 05, 2014 5:13 pm    Post subject: Reply with quote
You are going to want to pick up some dropped spindles. Three reasons why:
1. Your ball joints are going to bind and limit or negate your suspension travel.
2. They will move the wheel back in the fender well and reduce or eliminate rubbing on the headlight buckets.
3. They are only $99.
zodlaw
zodlaw is offline
PostPosted: Tue Aug 05, 2014 7:04 pm    Post subject: Powder coat stripper..magic Reply with quote
I like the part they are only $99. This is a tight budget build it took some time to get the funds for the spindles. I was old school back in the day with no drp spindles.. But I am old now and like the softer ride. I love the reasons and appreciate the info and support. Now if you can give me some ideas of what tires to run that would be great. Smile I am thinking 175/55 front and 205/55 rear but I Don't know if those will fit.
Now for the stripping of the wheels.. I looked and looked. This stuff is pretty good.
The wheel
The Goods...
Now soon as I sprayed this on it was like popcorn cooking.
Then it was just falling off, This stuff is great!
Few minutes later and its pretty clean, I think about 15 min or so to just clean it up.
Back side..
and mostly clean need to do the inside rim. They had this stuff on sale for $6 so prob be into it about $18 after I am done. This is way better than the jell stuff. I used a stainless steel brush to clean the small stuff still need to hit few spots. Over the next week I will finish these up and pressure wash them off before they head into powder coating.
One more thing, careful this stuff will burn you Twisted Evil
bug-ugly
bug-ugly is offline
PostPosted: Thu Aug 07, 2014 6:40 pm    Post subject: Re: Powder coat stripper..magic Reply with quote
Actually, the spindles are $109.95. Still pretty cheap and an absolute necessity, if you ask me. Some people will say that cast spindles are weak and inferior to forged ones but I have run these exact spindles on two cars and a set of cast link pin dropped spindles on my current bug. I've never had a problem.
http://www.jbugs.com/product/22-2859.html
As for tires, 135/15's are good for the taller look. They fill the fenders better than lower profile tires and they cleared the headlight buckets on my '68 with 4" beam and drop spindles. They look good paired with 165/15's in the rear.
I've also run (and currently have) 155/60/15 up front. They look good with a 195/65/15 in the rear (which is pretty close in diameter to the stock 165's). Kumho sells the 155/60 smart car tire but they wear out pretty quickly. I have Continental 155/60's right now and they've held up much better and were only about $30 more for the pair.
You can get the 135's pretty cheap if you order online. The ones I had, I got here: http://www.summitracing.com/parts/cok-55597/overview/
$70 each and free shipping. They had good tread life, as well.
bug-ugly
bug-ugly is offline
PostPosted: Thu Aug 07, 2014 6:46 pm    Post subject: Reply with quote
P.S. I love the look of your car. If it were mine, I'd pull the front end as straight as possible and roll it, as is.
My old '68 with 155/60/15 in front and 195/65/15 in the rear.
zodlaw
zodlaw is offline
PostPosted: Thu Aug 07, 2014 8:51 pm    Post subject: Reply with quote
Nice! What is your set up in back? Sometimes I wish I had swing axle rear because you can go a lot lower. IRS has its own problems after at 3 clicks. I just ordered my stuff yesterday. I got these for $89 and they say forged.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-22-2859
Yeah not doing anything to the outside. I tried to pull the front as much as I could. I even used a porta power. The only thing I got it to do was lock an latch so it would not fly open on the freeway. Oh and as luck would have it, a guy was selling 155/60s cons for $80 a pair today on cl. I am all out of $ for a while so I missed that killer deal. Sad
zodlaw
zodlaw is offline
PostPosted: Tue Aug 12, 2014 6:31 pm    Post subject: Got my caps! Reply with quote
Not sure I like them yet and this is the last wheel to be cleaned up. This is still the old paint and rattle can job, not powder coated yet. Smile I just wanted to see what is going to look like with the cap on it. I think I will powder coat the lugs for now to get me by.
front shot
I like the side shot, hope the tires fill it out.
Got some lip action going on but not much. I am going to try and run at 3 inner clicks.
This is what I am thinking ,155/65s front maybe 195/60s in the rear. If I do the 195s I could run 2 clicks in the back and that would solve some problems I will have to deal with. These are 6" x 15". You guys have any tire suggestions?
zodlaw
zodlaw is offline
PostPosted: Fri Aug 22, 2014 5:02 pm    Post subject: Reply with quote
Well its been a while since I posted. I finally got the wheels stripped all the way down. Here is the main shot of the rim for other purposes Wink
Here are the bunch...
I pulled the bug out to get some good shots so I can p shop some dif colors on the car. I have to make up my mind by wed, that is when they are getting powered coated.
This one is ok but I thought I would post it anyways
If any of you feel so inclined to do a photo shop of this with the rims on it that would be great. I am having a hard time making up my mind. Mad
The three main colors I am playing with are green, black and white not in any particular order. I am only going to do a two tone color. Smile
zodlaw
zodlaw is offline
PostPosted: Thu Sep 11, 2014 6:11 pm    Post subject: Reply with quote
Well this is what I am going for.
Not that low but close. Laughing
The wheels did not come out that good. They have powder coating issues that I will have to deal with before they go on. This also is the best out of them too. Evil or Very Mad Either way it is what it is and its time to focus on other things till I can get some tires.
If anyone is following this thread, what do you think?
BG Brian
BG Brian is offline
PostPosted: Thu Sep 11, 2014 8:49 pm    Post subject: Reply with quote
im kinda liken it with the rusty stockers.Did they powder coat those in two colors?I guess its difficult to get a nice clean line betrween the two colors.They just look too clean and shiny on a ratty car.Maybe rub some mud on em.When you gonna get that car back on the road?
zodlaw
zodlaw is offline
PostPosted: Thu Sep 11, 2014 9:32 pm    Post subject: Reply with quote
Yeah it was done in two. The white was done first then black. The black is to thick. I am shooting for spring I hope. Its all about the money though. Smile I think also when I get tires it will be a lot better.
Page 3 of 12
