CB75 Samba Member
Joined: August 16, 2012 Posts: 88 Location: Ontario Canada
Posted: Mon Jan 12, 2015 1:59 pm Post subject: |
I haven't taken it in but my drivers side is negative camber and the pass side is positive. Ordered the bushings from cip1. Thanks for the reply. Yah put a post on the late model forum nobody replied lol. Car looks good bro!!!! |
zodlaw Samba Member
Joined: July 27, 2005 Posts: 507 Location: Battle Ground, Wa.
CB75 Samba Member
Posted: Mon Jan 12, 2015 5:32 pm Post subject: |
Yah I have to figure the picture deal out lol. No I didn't flip the tie rods that will be the next project. Same as you on a budget. It's a slow go but getting there |
CB75 Samba Member
Posted: Mon Jan 12, 2015 7:52 pm Post subject: |
here is a pic i will take some better ones when I get a chance |
zodlaw Samba Member
CB75 Samba Member
Posted: Mon Jan 12, 2015 8:20 pm Post subject: |
No not yet! Im still along way off from that. Those are 205's on there, they stick out 1/2" past the rim so I was thinking maybe go to a 145 or maybe 155 60. What are you thinking about running |
zodlaw Samba Member
CB75 Samba Member
Posted: Tue Jan 13, 2015 2:30 am Post subject: |
Thanks bud! I read threw your thread but don't recall reading those posts. Good info for sure. Good luck with the project will be following your progress!!!! |
zodlaw Samba Member
Posted: Fri Feb 13, 2015 9:28 pm Post subject: Tires on! |
175/55/15 Contenentals front
175/65/15 Dunlops rear
You can see the beam clearance, I am 1/2 way up on my adjusters.
Yeah going to need some fender work its rubbing pretty good. 165/65 might have been better but will fix the fenders to get some room. I am at 3 clicks inner in the rear.
Its prob going to be a while before I get anything more done. I still need to lower the pass rear to 3 clicks inner. If you can find used tires I would go that way till you find what you really like. So far if I can get the back worked out I thik I will love it. _________________ 68 build that had been sitting for 18yr in a garage.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8119987#8119
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0 |
zodlaw Samba Member
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Sun Feb 15, 2015 10:51 am Post subject: |
why such a short tire in the rear? i've run 2 outer/1 inner combo on MANY cars with 195/65/15 and 205/65/15 with no problems. that 175/65/15 is gonna run your rpm's up which can make you run a little on the hot side.
if it's a matter of offset of the wheels it looks like you probably have long axles and switching to short axles would give you the space to tuck a bigger tire in that same opening. _________________ ITMC
Secret Service |
zodlaw Samba Member
Posted: Sun Feb 15, 2015 11:32 am Post subject: |
175/65 are 1.4 inches shorter than the 165/80 @ 25.4. I was hoping that that inch and 7/16 would not be that big of a difference. I know the offset would be a tight fit but its what I have. I also did not know you could swap out IRS axles for shorter ones. If I could do that I would run a full size tire as long as I could run it as low. I could not seem to find any info on the irs swap to short axles with any details. If you could point me in the right direction that would be great. _________________ 68 build that had been sitting for 18yr in a garage.
CB75 Samba Member
Posted: Sun Feb 15, 2015 2:36 pm Post subject: |
Looking good bud!!!! I just finished up my rear today with 205 on there. I'm gonna try and get it a little lower though. Rolled the fender a bit and doesn't seem to rub. I'm about 31/2 down on the back try and get some pics tonight |
CB75 Samba Member
Posted: Sun Feb 15, 2015 3:09 pm Post subject: |
I was wanting to ask where did you get your centre caps from. I read threw your thread but don't think you said |
zodlaw Samba Member
CB75 Samba Member
Posted: Mon Feb 16, 2015 7:42 am Post subject: |
I tore into it again lol. I will post some when I'm done. Thanks for the info you helped me out alot |
zodlaw Samba Member
Posted: Thu Feb 19, 2015 9:20 pm Post subject: |
We have tire clearance! 3lb hammer and 1" steel block. I have about 1/4 of an inch.
I pounded the front out too. Make sure you take out your headlight, mine shattered. I was in a bit of a hurry as I don't get too much time to work on the car.
This is my sons Lego guy to see how low it is. This is with almost no gas in it and I am about 195, 200 so it will prob be 1/2 off the ground and I scraped the beam coming into the garage. I will prob take those off and cap them, or not LOL
I still have not done the pass side yet in the rear. I was driving it around and it rides pretty good. The back tire was smoking from rubbing on the fender. I need to get that done, prob take few hrs if I can find some time. _________________ 68 build that had been sitting for 18yr in a garage.
CB75 Samba Member
Posted: Fri Feb 20, 2015 12:44 pm Post subject: |
Lol I like the lego guy for scale lol. Just put mine back together. I will post some pics later. I have been cut back hours so get to work on it Fridays but the funds are bad lol. And put my rear fenders on that I had bought from a guy and when I went to roll the lip a quarter inch of bondo fell out. So stripped it down.... so more work now.. oh well |
zodlaw Samba Member
CB75 Samba Member
Posted: Sat Feb 21, 2015 2:15 am Post subject: |
