SpodaDoo Samba Member
Posted: Sat Apr 12, 2014 12:32 am Post subject: Another dipshit new guy.. |
greetings from No-Cal... I'm mike and i have a car problem... lol.. Not new to bugs but have been away for a long time.
Picked up this bug in a trade as a "sweetener.. from what i am told is a 68 vert body on a 58 pan.. its been sitting for around 5 years so i put some tranny fluid/PB blaster mix in the cyl's and and blew out all the fuel lines checked the aluminum tank (it was dry and clean thank god).. i know i will have to rebuild the carbs at some point but i just want to see if it i can get it to pop off at all.. see what i have.. It is supposed to be a 1900ish bus engine with a cam and stuff... but i am always skeptical..
I have checked over the wiring and put power to the fuel pump and it works.. i am going to change the oil too although it looks clean on the dip stick.. was thinking of taking tins off to make sure there are no mousey nests in there or something. Am I forgetting to check or change anything before i try to start it..? have started many regular engins after sitting for decades.. never a bug engine after sitting..
hopefully the link works..
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sat Apr 12, 2014 5:25 am Post subject: |
Turn it over by hand a couple of times then fire it up looking for leaks and listen for clunks and bumps
Here is a pic of my engine after a few years of squatters
https://www.thesamba.com/vw/gallery/pix/1192214.jpg |
greg mgm Samba Member
Joined: October 07, 2004 Posts: 573 Location: Pine Cove/ IdyllwildCA
Posted: Sat Apr 12, 2014 9:04 am Post subject: |
I see you did end up buying a baja. Interesting. |
Posted: Sat Apr 12, 2014 9:28 am Post subject: |
Didn't buy it... Got it in a trade pretty stoked.. Can't wait to go play in the sand... Someone put some money into it.. Hopefully it will run and I can check that box.. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
bersa2 Samba Member
Posted: Sun Apr 13, 2014 8:36 pm Post subject: |
I may be stating the obvious but we can all over look the basics when we are trying to think big. After turning it by hand, Pull power from the coil and make sure the oil pressure light goes out when you crank the starter. |
Posted: Sun Apr 13, 2014 11:12 pm Post subject: |
bersa2 wrote: |
good point..! didn't think of that one.. i turned it over with just the starter today. had to rock it back and forth in gear a little to free it up a little.. turns over like a champ now.. that's as far as i got though.. ha to work on my roadrunner |
HERC Samba Member
Posted: Mon Apr 14, 2014 6:56 am Post subject: |
Jesus, start it already. _________________ Herc |
Posted: Mon Apr 14, 2014 9:21 am Post subject: |
lol.. Nah.. I had to do some (never ending) wiring mods on my Roadrunner, which is my daily driver. Mopars take priority in my garage.. free VW's are last on my list.. haaha!
Although my youngest just informed me that he wants this car as his first car so that bumps it up the list a little. |
BUGGUTZ Samba Member
Joined: March 13, 2007 Posts: 537 Location: Luzerne Mich
Posted: Mon Apr 14, 2014 3:14 pm Post subject: |
Ahh the never ending world of mopar wiring, ive been there. My first lesson on that........ballast resistor. Fun! |
StevieC Samba Member
Joined: January 01, 2014 Posts: 412 Location: Anza Borrego
Posted: Mon Apr 14, 2014 6:20 pm Post subject: |
HERC wrote: |
Jesus, start it already. |
Posted: Mon Apr 14, 2014 8:34 pm Post subject: |
Well.. Drained the oil today and go figure... Bout a cup or 2 of water came out with it.. Should I just say f@ck it and start it and see what happens or should I yank a cyl off and see what it looks like..? I am leaning towards saying f #ck it but I don't know VW engines.that well...
I know herc, just start the thing already... Lol |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Tue Apr 15, 2014 4:17 am Post subject: |
It's not any different than any other engine just change the fluids. Start it. let it warm up if you can and then change the fluids again. If it's going to last you'll find out eventually. I wouldn't assume it's trash just because it sat for five years. Good lord. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Tue Apr 15, 2014 8:05 am Post subject: |
Mine sat for a long time before I bought it. What made me decide to just tear int it was pulling a valve cover off and seeing rust. I would look their before say in f@# it. If its not rusty and it turns over half way decent, let er rip. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Tue Apr 15, 2014 8:49 am Post subject: |
I'll revise what I said and say I would think its trash unless I had some obvious evidence of damage. I have heard nothing that would point in that direction. Valve covers are a simple clip to remove and I would hope he would at least see that.
I appologize if I sounded brash _________________ Brian H.
covdubguy Samba Member
Joined: May 31, 2012 Posts: 37 Location: Centennial Colorado
Posted: Tue Apr 15, 2014 11:25 am Post subject: |
The 1600 single port that is in my rail sat outside for 10 years. When I was having the card tuned I had painters do a oil change and Keith said there was a 1/4 of sludge in with the oil.... And yes I was driving it around the neighborhood that way..... And it runs great!!!!! VW motors can take a lot of abuse. Drain the oil fill it up and let it rip. _________________ 74 bus
Berrian warrior
Some other rail
Dirty hippies give busses a bad name |
Posted: Tue Apr 15, 2014 11:27 am Post subject: |
covdubguy wrote: |
The 1600 single port that is in my rail sat outside for 10 years. When I was having the card tuned I had painters do a oil change and Keith said there was a 1/4 of sludge in with the oil.... And yes I was driving it around the neighborhood that way..... And it runs great!!!!! VW motors can take a lot of abuse. Drain the oil fill it up and let it rip. |
^that's kinda what I was trying to say...lol _________________ Brian H.
Posted: Tue Apr 15, 2014 2:31 pm Post subject: |
i pulled the valve cover after draining the oil and there was a tiny bit iof rust on the covers them selfs the oil that coated everything looks like it protected it... going to fire it up tonight when i get home. |
