Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Apr 19, 2014 3:52 am Post subject: |
I remember reading that deal about the punch marks when it was posted recently...
There's no mention of it in any official VW literature I've ever seen, and I asked a local VW mechanic who was trained by VW in 1962, and he said he never heard of such a thing.
It would be impossible to time a Type 3 engine this way since you can't see such a mark when timing the engine.
Don't go down that rabbit hole. _________________ 71 Elm Green FI A/T Squareback |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Apr 20, 2014 5:30 pm Post subject: |
You are relying on foreign punch marks... and a hot hood handle?
Really? |
sb001 Samba Member
Posted: Sun Apr 20, 2014 6:44 pm Post subject: |
VWCOOL wrote: |
Really? |
Uhh- yes, REALLY.
I don't have to have science lab equipment to know when I touch my hood handle and it near burns my finger that my engine is running too hot, and the reason for the punch mark and how it relates to timing has already been explained at length by the original poster of it, so if you're going to go after someone for that how about disproving his theory instead of putting "really" in italics as if you're making some sort of genius statement.
I really don't have time for unhelpful posts like the one you just threw up here, VW COOL. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Sun Apr 20, 2014 7:05 pm Post subject: |
I'm thinking what VW Cool is implying and which has been repeated in several earlier posts is that you don't know what temperature your engine is only other than how it feels. The simple solution would be to go to a sports/outdoor store that sells the long thermometers and stick it in there and see - that way you'll know for sure and the people on here will have some very useful information. I too thought mine was running hot because the dipstick was too hot for me to touch but I went and got a thermometer and found it wasn't. Just to be sure, I also bought the thermometer from SAVEMYBUG just to be sure and for piece of mind.
You may be right, it may be too hot. Just get a thermometer so you can tell everyone "I told you so!" It's an important piece of information that you can't do without. Hope you get it all solved. |
Posted: Sun Apr 20, 2014 7:11 pm Post subject: |
sb001 wrote: |
the reason for the punch mark and how it relates to timing has already been explained at length by the original poster of it |
Yes, and it boiled down to "a guy told me this". He couldn't even supply a name, or any way to verify any of what he said.
Show me a piece of official VW literature which explains the theory, and how it explains how it's contradictory to everything VW ever published regarding using the case seam.
Until then, it's a rabbit hole. _________________ 71 Elm Green FI A/T Squareback |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Apr 20, 2014 7:21 pm Post subject: |
A stuck exhaust valve that no longer can be adjusted is proof it got hot. I'm sure when sb001 says the handle is hot he's comparing it to when the engine ran good and the handle wasn't hot after a long drive. When you have a vehicle for a long time you know when something is different and not right. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Joey Samba Member
Posted: Sun Apr 20, 2014 7:31 pm Post subject: |
Donnie strickland wrote: |
sb001 wrote: |
Until then, it's a rabbit hole. |
It really does make sense when you think about it. If you ever checked the deck height on an engine it's rarely ever the exact same on both sides. It's the same reason there's different pitch/size camshaft gears. The crankshaft bore is simply off center on the horizontal plane in the case. _________________ Joey
VWCOOL Samba Member
Posted: Sun Apr 20, 2014 7:41 pm Post subject: |
sb001 wrote: |
VWCOOL wrote: |
Really? |
Uhh- yes, REALLY.
I really don't have time for unhelpful posts like the one you just threw up here, VW COOL. |
Actually, what I offered was very helpful: I'm highlighting your TOTALLY INAPPROPRIATE heat measuring technique. It will be far better for you to rely on more conventional mechanical practices/techniques than heat-soak from your exhaust |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Apr 21, 2014 3:33 am Post subject: |
without re-reading - I am assuming your engine/body seals are in good shape and all tin is in place. Also, have you measureed the oil temp. Just on first cup of coffee and will be late for work if I dont get rolling.. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Apr 21, 2014 7:47 am Post subject: |
Don't you have a local guy that is an expert on these engines that helped you rebuild it the last time you almost put a rod through the case? Have you asked him? |
sb001 Samba Member
Posted: Mon Apr 21, 2014 8:12 am Post subject: |
Bashr52 wrote: |
Don't you have a local guy that is an expert on these engines that helped you rebuild it the last time |
no. _________________ I'm the humblest guy on this board.
1600 SP engine
Randy in Maine Samba Member
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Sat Apr 26, 2014 9:11 pm Post subject: |
VWCOOL wrote: |
Really? |
Most of the time, when the hood handle is HOT as hell, the engine is even hotter.
One guys bug at the shop cut out the rear apron, so the muffler heats the engine like crazy. (its currently at the shop to fix this problem)
1st degree burn on my finger from the hood handle.
And I couldn't even touch the carb it was so hot. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
type1vwjapan Samba Member
Posted: Thu Jul 17, 2014 10:29 pm Post subject: |
don't know if this was mentioned somewhere in this thread, too long didn't read it all, but I just wanted to mention how much I like my savemybug dipstick sensor.
sure, it's simple and doesn't give you cylinder head temps, but it still gives you a great piece of mind knowing if your engine is running too hot or not. I really think that in most cases knowing your oil temps is adequate enough.
I also like that it still gives you a stock look, as I don't like aftermarket gauges ruining my beautiful stock dash. I also like that the light comes on when your engine temps are getting up there, so that you have a bit of a warning to back off and let things cool down.
I was worried about my bug when I first got it and got everything straight with it, and I was relieved to find out that my engine is running right where it should be. even on hot days using the A/C on full blast in stop go traffic over here in Japan. can't tell you how many times I kept popping my deck lid and touching my scalding hot disptick and burning my hand like a jackass and screaming "DOOH!" like Homer Simpson before I got this unit.
it must be pretty hot there in Arkansas, too, so I'd think that your dipstick being too hot to touch is probably nothing to worry about. mine still gets pretty hot, as I have to take my hand off of it after a couple of seconds. yet, everyone's tolerance for pain and how hot something is different.
my dipstick sensor ended up malfunctioning last week, which is rare from what I've heard, got a lemon I guess, and they're sending me a brand new one all the way to Japan, no charge. I bought it about a year ago, too! nothing to lose with trying it. you definitely don't have to worry about being screwed over by them, like I read happened to you with that EMPI junk. sorry to hear about that fiasco.
take care! |
sb001 Samba Member
Posted: Thu Jul 17, 2014 11:19 pm Post subject: |
Thx type1vwjapan
I defintely will look into a thermometer of some sort whenever I start my second engine rebuild (hopefully soon.) You are correct about Arkansas getting pretty hot in summer- but believe it or not it was only 70° here today for a HIGH- very rare mild summer we are having here this year.
That whole EMPI episode was blown out of proportion- it was just engine sled tin after all- but I learned my lesson.
Speaking of which, money's pretty tight at the moment, so I may just drive down to Booneville and buy one of those rock solid GEXs _________________ I'm the humblest guy on this board.
1600 SP engine
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Jul 18, 2014 10:36 am Post subject: |
Hyperspace wrote: |
I guess every bit helps, but the cylinder heads can be ruined long before the oil temp will indicate a problem. If an aircooled motor had one guage that should have been obligatory, I'd have made it head temp guages. |
Yep, it's rare to have oil temps that are too high without the heads also being hotter than they should. And you can cause a lot more sudden damage with hot heads than hot oil. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
