SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sat Apr 12, 2014 4:40 pm Post subject: Body Cross Section |
Does anyone have a cross section of the body between the shock towers? _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32594 Location: Reading Pennsylvania
Posted: Sat Apr 12, 2014 5:45 pm Post subject: |
I don't have the body here but I was thinking if there is space to make a strut style brace between the two shock towers. _________________ Jesse
71 Ghia
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Sat Apr 12, 2014 6:27 pm Post subject: |
The strut brace is commonly used on McPherson strut suspension systems because of the design flaws. The upper geometry has inherent flex, as the suspension is basically a 3-point open trapezoid. Closing the trapezoid at the top adds the needed rigidity for more responsive handling. I run a brace on my strut equipped track car.
However, the VW torsion bar suspension is a boxed beam arrangement, so lateral loads do not cause it to flex anything like a strut system. In addition, the beam is bolted to the framehead in a way that braces it even further. With that in mind, I would consider the VW front suspension geometry to be much more stable, and not likely to benefit from a strut brace. If you want to strengthen the VW beam, then triangulation plates welded in the inside corners should be more than adequate. There's no lateral loading of the top shock mounts themselves, only vertical.
Paul |
Posted: Sun Apr 13, 2014 8:34 am Post subject: |
Well I'm running air suspension and I was told that the towers are too week for that...
I'm thinking of a strut style brace to reinforce it although I have yet to see a bent shock tower caused from air suspension...
Does anyone have an image of an actual bent shock tower caused by air suspensions or is this BS? _________________ Jesse
71 Ghia
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sun Apr 13, 2014 10:31 am Post subject: |
SoCalJes wrote: |
Does anyone have an image of an actual bent shock tower caused by air suspensions or is this BS? |
I personally haven't seen a bent shock tower. But, I've seen plenty of sheared upper and lower shock bolts from trying to run air shocks/air bags on the front of a VW. Those bolts weren't designed to hold the car up. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
88 E5PR1T Samba Member
Joined: December 31, 2012 Posts: 123 Location: Long Island, NY
Posted: Sun Apr 13, 2014 2:28 pm Post subject: |
Bobnotch wrote: |
I personally haven't seen a bent shock tower. But, I've seen plenty of sheared upper and lower shock bolts from trying to run air shocks/air bags on the front of a VW. Those bolts weren't designed to hold the car up. |
This. It's the shock and the shock bolts that aren't designed to hold the weight of the car, not the shock towers.
I went thru it already, broke two air shocks, and then went to back to torsions and installed an adjustable beam and drop spindles. Absolutely 100% better result. _________________ Rob
'64 Karmann Ghia "40HP VW"
instagram.com/40hpVW |
Posted: Sun Apr 13, 2014 4:36 pm Post subject: |
The bolts breaking makes more sense. When and if they break then it will be time to redesign them and make some beefier ones. For now I'll leave the towers alone and see how it goes.
Thanks for the info and feedback everyone _________________ Jesse
71 Ghia
Altema Samba Member
Posted: Mon Apr 14, 2014 8:48 am Post subject: |
Ah, the air suspension changes everything... |
