Angelo Amato Samba Member
Joined: January 22, 2005 Posts: 83 Location: Wirral, england
Posted: Tue Oct 21, 2014 10:44 am Post subject: |
very neat.
agree on the second bolt hole, all it would take would be to drill one. those brackets are perfect. |
beetlejc Samba Member
Posted: Wed Nov 19, 2014 9:11 am Post subject: |
Great thread! I ordered my 911 sport mounts today.
I noticed something unusual on my '69 Fasty. From what I've read, the rear-most engine mount (closest to the trunk latch) ceased to be used after '68. (Correct?) My '69 still has the vacant mounting plate. Is that just residual from an early body panel stamping or should I try getting a rear mount and installing it? |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Wed Nov 19, 2014 10:41 am Post subject: |
beetlejc wrote: |
It's more of a stabilizing piece than a proper mount. The early cars are swing axle and the engine is supported mostly by the swing axle subframe. Your car is IRS and doesn't have the support from the bottom (using the side mounts and rear hanger).
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Nov 19, 2014 10:44 am Post subject: |
More is not better here- the IRS mounts plus the swing axle stabilizer will fight each other. The IRS mount is a far superior design anyhow- it's all the stability you need. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Nov 19, 2014 1:59 pm Post subject: |
Angelo Amato wrote: |
very neat.
Yup, that's why VW used anti-vibration nuts on the bolts. If you really think about it, the bracket bolts to the end of the hanger bar, which is bolted to the engine. Vibration from the engine and flexing of the mount can cause the nut to back off, and the bolt to vibrate out. Having the 2nd bolt in place is added insurance against the engine falling onto the pavement. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
FartsMcFarty Samba Member
Joined: August 18, 2017 Posts: 39 Location: Austin, TX
Posted: Sat Nov 11, 2017 7:42 pm Post subject: Re: Late Rubber Engine Mounts |
has anybody attempt drilling a second set of holes into the yoke? About to do this for my Fastback |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Sun Nov 12, 2017 9:01 am Post subject: Re: Late Rubber Engine Mounts |
I sacrificed the lower brackets off of the old mounts:
Drilled holes for plug-welding a rod thru the middle.
A pass through to ream and de-burr.
Tacked into the mounts, lightly, to keep from melting the rubber.
Grind a bevel to weld the washers on.
Go really, really slow to avoid melting rubber.
Smooth.
And underneath.
I messed up and didn't get the washers on first.
Had to split them to get them on, then weld back together.
_________________ Bus Motor Build
What’s That Noise?!? |
gheezerghia Samba Member
Posted: Mon Feb 10, 2020 9:34 am Post subject: Re: Late Rubber Engine Mounts |
JJM86 I know it’s been a few years but I wondered how things worked out with your Porsche engine mount mod for your Type 3? I’m experiencing some vibration from my automatic transmission and figured one of the solutions would be to replace the tired engine mounts. Would love to hear your thoughts. Thanks man! |
