The Stupid Question Thread
Page: Previous  1, 2, 3 ... 13, 14, 15 ... 127, 128, 129  Next
vamram Premium Member
vamram is offline
PostPosted: Sat Oct 04, 2014 4:14 pm    Post subject: Reply with quote
Thanks, V-Wagen! I've another dumb question: Confused In mechanical terms, what exactly is "lugging the engine," and why is it bad? Eh?
Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
[email protected]
ptjjb@yahoo.com is offline
PostPosted: Sat Oct 04, 2014 5:28 pm    Post subject: Reply with quote
Lugging the engine a slow RPM, like below idle speed. It is bad because it is not pumping enough oil to keep the bearings lubricated so it wears bearings out real fast. Also fan is not spinning fast enough to remove heat.
vamram is offline
PostPosted: Thu Oct 09, 2014 6:01 am    Post subject: Reply with quote
British English to American English translation help for a 34PICT-3 please:
Brit: "slow-running adjusting screw" - is this the same as the large bypass air screw on the LEFT side of the carb?
Brit: "Slow-running mixture control screw" - is this the small volume control screw below and just behind the bypass air screw?
Thanks!
Click to view image
Save the Supers!!
cjsuner
cjsuner is offline
PostPosted: Thu Oct 09, 2014 5:02 pm    Post subject: Reply with quote
So i was looking through my box of old parts, and looked at my Dizzy,
it is a bosche, made in Germany, FJ4, but the numbers ends with 49.
So what kind of dizzy is that? is it a 009? (it is a DVDA)
69dailydriver
69dailydriver is offline
PostPosted: Sun Oct 12, 2014 12:56 pm    Post subject: stupid question Reply with quote
I'm not saying I need the feature, but could someone tell me if the 69 came with that device that automatically turns of the turn signal when the wheel is straight again?
First post, Bentley's in the mail, just picked up a 69 Type 1 this weekend to replace a 2001 Ford Escort that crapped out on me.
Brian
Brian is offline
PostPosted: Sun Oct 12, 2014 1:05 pm    Post subject: Re: stupid question Reply with quote
yes. http://www.thesamba.com/vw/archives/manuals/69bug.php
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
69dailydriver
PostPosted: Mon Oct 13, 2014 10:24 am    Post subject: Reply with quote
Thanks Brian!
And could you please tell me if, with the 1600DP (which I think the '69 never came with?), extra vents are typically required in the hood? I appreciate it.
'69 Type 1 1600DP
vamram is offline
PostPosted: Mon Oct 13, 2014 11:33 am    Post subject: Reply with quote
Thanks Brian!
Definitely required. Either that or decklid stand-offs.
Click to view image
Save the Supers!!
FrankMonroe
FrankMonroe is offline
PostPosted: Mon Oct 13, 2014 11:59 am    Post subject: 1971 vw bug Reply with quote
Hey whats up I am working on a 1971 bug and I am looking for a fresh air motor switch or button im not sure what it is or what it looks like. can anyone tell me were I can find one.
vamram is offline
PostPosted: Mon Oct 13, 2014 12:57 pm    Post subject: Re: 1971 vw bug Reply with quote
Only exists on Super Beetles. I'll post one from my dash later.
Click to view image
Save the Supers!!
Walter4
Walter4 is offline
PostPosted: Mon Oct 13, 2014 5:34 pm    Post subject: Reply with quote
The PO says that my SB has hydraulic valves and they don't need to be adjusted.
Really? Never?
GArBa
GArBa is offline
PostPosted: Tue Oct 14, 2014 1:46 am    Post subject: Reply with quote
it could have been modified. does it have the original engine?
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
Walter4
Walter4 is offline
PostPosted: Tue Oct 14, 2014 2:39 am    Post subject: Reply with quote
Not the original engine. PO said he broke the original sometime in the 90s.
Is there any way to verify the valve types? I am happy never to adjust them, but I can't find much information on their care and feeding.
GArBa
GArBa is offline
PostPosted: Tue Oct 14, 2014 12:56 pm    Post subject: Reply with quote
hydraulic lifters sit at the pushrod end inside the crankcase... I don't think there's a way of confirming this through simple visual inspection.
look for a mexican engine case, an external cartridge oil filter (to prevent oil sludge or debris to foul the lifters)... those would be positive clues.
also, on a mexi engine the lifters would bleed oil out back to the sump when the engine sits unused for a long period of time, causing the valvetrain to clatter upon startup. the clatter would then disappear as the engine warms up and the lifters regain their adjustment.
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
69dailydriver
PostPosted: Wed Oct 15, 2014 8:22 am    Post subject: Reply with quote
Hey all. Just bought the car and the speedometer doesn't work. PO assured me it only needed a new cable, which he had already installed but was just missing the C-clip at the rotor. I pulled the dust cap off and I can see the cable sticking out. I've been flipping through the forums and it seems that if the cable is sticking out the dust cap like that, something has already gone wrong?
I've jacked the car up and tried to adjust the cable from behind the wheel (and thus far I can't get the stupid wheel off because PO has anti-theft lug nut but I didn't end up with the tire iron for it) but it doesn't seem like there's anything for the square head of the cable to catch on; that is, it slides in and out of the hole in the rotor with no resistance no matter how I turn it.
Anyway, I bought the c-clips and I was wondering if someone could tell me if this cable is already a lost cause or if there's something I'm missing. I'd rather not buy another cable if there's something else going on. Thanks very much!
'69 Type 1 1600DP
vamram is offline
PostPosted: Wed Oct 15, 2014 8:45 am    Post subject: Reply with quote
The c-clip goes on after the dust cap. This search of the gallery shows plenty of pics of it on correctly:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
Click to view image
Save the Supers!!
69dailydriver
PostPosted: Wed Oct 15, 2014 9:27 am    Post subject: Reply with quote
I owe you vamram. Thanks so much; I'll start with the gallery next time I have a question like this. I'm thinking I can probably do this on my lunch break.
'69 Type 1 1600DP
vamram is offline
PostPosted: Wed Oct 15, 2014 10:09 am    Post subject: Reply with quote
Hey, that's what this thread is for! So you can ask those questions! Take a look at my posts if you have any doubts...! Very Happy
Click to view image
Save the Supers!!
69dailydriver
PostPosted: Wed Oct 15, 2014 10:42 am    Post subject: Reply with quote
It's not looking good; the end of this cable isn't grooved like the ones in the pictures. I don't even know where to seat the c-clip.
Any thoughts?[/img]
'69 Type 1 1600DP
69dailydriver
PostPosted: Wed Oct 15, 2014 10:53 am    Post subject: Reply with quote
Thank god I'm in the stupid question thread; is this speedometer cable not going to work with these aftermarket rims? Since the "dust cap" I have is for the aftermarket rims and not the original rim?
'69 Type 1 1600DP
Page 14 of 129
