Jake Hoff Samba Member
Joined: February 22, 2008 Posts: 166 Location: Southeast, South Dakota
Posted: Sat Apr 19, 2014 8:37 pm Post subject: |
RareAir had the best comment so far to bypass the ignition switch by hot wiring the coil up
Could a faulty ground somewhere do this ?
And your sure its in the electrical side? |
vamram Samba Member
Posted: Sat Apr 19, 2014 10:33 pm Post subject: |
Pretty sure it's electrical. I mean, read the description. The car runs fine for 10-12 miles then just dies.
Say I'm doing 50 mph, I leave it in gear (4th), flip the ignition switch off/back on and it immediately starts again as if nothing had happened, except for a big backfire from the muffler - so gas was still getting into the chamber when no spark was getting there for a few moments, enough to get thru to the exhaust in time for the restart and BOOM backfire out the muffler.
I think anyway... _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
sb001 Samba Member
Posted: Sat Apr 19, 2014 10:51 pm Post subject: |
What is deck height and why is it important? How do you measure deck height?
What does deck height have to do with CC?
Is it necessary to lap cylinders before installing heads? Why do heads have to be machined?
When mating the two case halves back together what sealant (if any) is best to use?
How do you check and/or shim end play?
And finally, if you have no valve clearance when adjusting valves, and no amount of adjustment fixes it, what is wrong? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Sun Apr 20, 2014 11:37 am Post subject: |
Have you tried by passing the ignition yet? The new ignition switches for the most part are pieces of crap, and tend to wear out quickly especially if you have a lot of keys swinging from it. However, depending on the temperature where you are at, the symptoms also mimic a bad coil. Coils generally start to give problems when they get hot. Try the bypass first, if no results, see if you can bum a coil from someone. It doesn't have to be any special type, a stock 12V coil will power the engine just fine. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
vamram Samba Member
Posted: Sun Apr 20, 2014 3:05 pm Post subject: |
Multi69s - it ended up being the coil. I replaced the Flame Thrower one w/a new Duralast from Auto Zone and proceeded to go on a nice 50-mile cruise. Nary a hiccup the whole time.
I'm done w/Pertronix products. In the last 2 years, I've had an ignitor module go bad, the vac can on a Flame Thrower SVDA give up the ghost, and now a Flame Thrower coil. THREE STRIKES, YER OUT!
As always, thanks to those who responded w/possible causes and test ideas! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Sb001
I have heard gasgasinch is a good block sealant
YouTube measuring end play it's really simple
Not understanding the valve adjustment question at one point there has to be some sort of clearance if everything is stock
Hopefully someone else will jump in on the other questions |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
Posted: Thu Apr 24, 2014 9:10 pm Post subject: |
Looks like there are three different sizes sold on airhead parts
The part number you need for a 71
311-721-361
That's on airheads parts maybe there are more
It didn't give measurements to help you but maybe another parts warehouse site gives them that would let you know which one you have
There's a bunch of clutch cables as well |
Posted: Thu Apr 24, 2014 10:37 pm Post subject: |
Post a measurement of your tube and I will check mine and see if they are the same
But the Bowden tube not Your tube |
Hoobie Samba Member
Joined: October 27, 2012 Posts: 87 Location: Australia
Posted: Fri Apr 25, 2014 2:11 am Post subject: |
can we please not have everyone comparing Bowden Tube sizes? Aren't we all beyond that now? |
beetlenut Samba Member
Posted: Fri Apr 25, 2014 7:53 am Post subject: |
Hoobie wrote: |
So is THAT your stupid question? _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
windfish Samba Member
Posted: Fri Apr 25, 2014 9:50 am Post subject: |
Got a contribution to this thread:
A previous owner painted over the id tag in my trunk, the one behind the spare tire.
Best method for removing paint? Its so thick the raised lettering on the tag is completely illegible. |
vamram Samba Member
Posted: Fri Apr 25, 2014 9:53 am Post subject: |
windfish wrote: |
Dremel w/a wire brush attachment? Airplane paint remover you brush on, available at most auto parts stores? Careful for overruns onto the apron. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Fri Apr 25, 2014 10:00 am Post subject: |
windfish wrote: |
Jasco, with a small paint brush. paint it on, wipe it off with a rag soaked in water. Carefully |
Hoobie Samba Member
Posted: Sat Apr 26, 2014 4:04 am Post subject: |
beetlenut wrote: |
Hoobie wrote: |
So is THAT your stupid question? |
is that YOURS? |
Posted: Mon Apr 28, 2014 11:14 am Post subject: |
Hoobie wrote: |
beetlenut wrote: |
Hoobie wrote: |
is that YOURS? |
Yes. Is THIS yet another from U?
But since I'm already here in the land of stupid questions,
Why chrome Moly grease in CV's instead of Synthetic? I know synthetic wasn't around way back when, but even now it is the prefered/recommended grease for them. _________________ scrapyards are for quitters
Wetstuff wrote: |
Aldwych Samba Member
Joined: November 20, 2013 Posts: 59 Location: Vienna, Austria
Posted: Mon Apr 28, 2014 11:19 am Post subject: |
Should I be able to turn the engine by hand (by just turning one of the fan belt pulleys) when it's cold? |
Hoobie Samba Member
Posted: Tue Apr 29, 2014 4:14 am Post subject: |
Remember there are no stupid questions, just stupid people.
Should be able to turn it by hand using the fan pulley with the spark plugs out, or if your rings are broken, or if your valves are shot, or if you have an interesting cam, or your pistons are broken in half or have holes in the top, or you do it very very slowly.
Of course you SHOULD be able to turn it a little way before you feel the compression slow you down even if your engine's not completely shot to hell.
Why does my cat's breath smell like fish? |
