dcat917 Samba Member
Joined: April 13, 2014 Posts: 185 Location: Greenville, SC
Posted: Wed Jul 09, 2014 8:41 pm Post subject: Progress Report for July 9, 2014 Karmann Ghia |
The last 3 weeks have been hell on the hands. I have stripped the interior down and put POR15 on everything I can see. I have to still get the clear coat on the dash and then I can start putting things back ON the car. Had a real problem getting the new clutch cable back in. The clutch tube was packed with old dried up grease. The solution was to use a hammer and drive a 6' long 1/4" threaded rod in from the rear and use it like a pipe cleaner.
I rebuilt the clutch pedal assembly using the Bigfoot extender shaft and love the way it went together. I ran a 3/4" plastic wire conduit down my right heater tunnel for wiring. Cleaned up the rear end getting ready to install my oil cooler back there. Here is a link to the POR15 shot:https://www.youtube.com/watch?v=d7F9-XEyrYg&feature=youtu.be and some photos of the prep work:
_________________ 1981 Puma GTB http://www.thesamba.com/vw/forum/viewtopic.php?p=7794566#7794566
1971 Karmann Ghia http://www.thesamba.com/vw/forum/viewtopic.php?t=591290&highlight=
Past Projects:
1951 Studebaker Business Coupe https://goo.gl/photos/eHPuNo89m9PXZwBM8
1953 Studebaker 2-Door Sedan https://goo.gl/photos/pe38HEShzUrVSwcV8 |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Jul 19, 2014 4:19 pm Post subject: |
Coming along nicely. Who is the manufacture of the felt back sound deadening material? |
dubulup Samba Member
Joined: November 13, 2008 Posts: 387 Location: Earth People
Posted: Wed Jul 23, 2014 5:38 am Post subject: |
I like the progress! Page 3 strong on electric ghia |
DorianL Samba Member
Posted: Wed Jul 23, 2014 6:21 am Post subject: |
Ooooooo, I'm liking this... |
trevize1138 Samba Member
Joined: October 26, 2005 Posts: 694 Location: Wells, MN
Posted: Wed Jul 23, 2014 10:51 am Post subject: |
Thanks for sharing your experience!
I'm very curious about going the same route some day. I'm thinking if the engine in mine gets to a point where it needs a serious overhaul/replacement I may just go all electric.
I have a lot of nostalgia for the flat 4 sound/smell/tweaking but the idea of eliminating a ton of the complexity and maintenance that goes with internal combustion engine is alluring. _________________ '72 Ghia Coupe
'72 Westy Hardtop (sold in 2013)
'72 Super Beetle (long dead and gone!)
http://druckenghia.blogspot.com/ |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Wed Jul 23, 2014 11:07 am Post subject: |
trevize1138 wrote: |
I have a lot of nostalgia for the flat 4 sound/smell/tweaking but the idea of eliminating a ton of the complexity and maintenance that goes with internal combustion engine is alluring. |
Ditto! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Wed Jul 23, 2014 11:32 am Post subject: |
Woreign wrote: |
Ditto! |
Sounds like there may be a market for an air cooled VW engine sound module that could be fitted to the electric propulsion system. |
c21darrel Samba Member
Posted: Sun Aug 10, 2014 4:50 pm Post subject: |
Looking good man...waiting to see some real volt installations! |
Posted: Mon Aug 18, 2014 6:40 pm Post subject: |
Will you be shifting gears? If so, what type of gearing are you using in the transmission? |
Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Mon Aug 18, 2014 7:19 pm Post subject: |
You really don't need to shift gears, that is to keep engine rpm down (gasoline that is) The last guy I saw do this just left it in second, (maybe even third)it has enough torque to get it going and would roll up to 65 mph no problem. When he needed reverse you just came to a stop and shifted in. It worked quite nice. Looking great by the way, I would like a copy of the Curtis software given that I work with them every day, but Raymond will not release any to us. Lol |
