Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Tue Sep 02, 2014 5:39 pm Post subject: |
Looking really good! If you get any farther post a few of the motor/trans combo. What it the gauge to the left of the speedo? And what's in the radio plate? I'm really itching to see this. |
dcat917 Samba Member
Joined: April 13, 2014 Posts: 185 Location: Greenville, SC
Posted: Tue Sep 02, 2014 6:15 pm Post subject: |
Thanks Kmolenda, here are the details:
This a shot my dash for this project. From left to right, we have the voltmeter, speedometer (may be replaced with a Garmin), the motor controller display, and the state of charge meter. The state of charge meter is like a gas gauge. The unit to it's left puts out system error codes mainly. The voltmeter monitors the 12 volt Ghia systems health.
I will have a separate 144 volt 100Ahr electrical system to install that supports the motor that the 2 gauges on the right will be showing. I.m drawing that up now and trying to figure out where to put the components. These relays and switches are HUGE and connected by 2/0 cable.
I'll post photos of the motor installed later this week if all goes as planned. _________________ 1981 Puma GTB http://www.thesamba.com/vw/forum/viewtopic.php?p=7794566#7794566
1971 Karmann Ghia http://www.thesamba.com/vw/forum/viewtopic.php?t=591290&highlight=
Past Projects:
1951 Studebaker Business Coupe https://goo.gl/photos/eHPuNo89m9PXZwBM8
1953 Studebaker 2-Door Sedan https://goo.gl/photos/pe38HEShzUrVSwcV8 |
Posted: Tue Sep 02, 2014 6:46 pm Post subject: |
That was my guess BSOC and the 12volt . Looks great. Does your Curtis provide a 12 volt output supply also or is that going to be a separate system all together? I know on the lifts we start with 36v (usually) jump to the AC component through the amps, then have a distribution of 24v , 12v and 5v outputs for running 12v computers, cameras or whatever they want to outfit it with. The only trouble I have run into is the AC component on some of the motors tends to real havoc on computer systems due to the isolation of the electrical system from the frame of the truck. Anyways, I wish I had the funds to do a project like this, your really doing a nice job, not only with the Ghia as a Ghia but looks like a really well thought out electrical setup. I've really enjoyed following your progress! |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue Sep 02, 2014 7:00 pm Post subject: |
dcat917 wrote: |
Shooting for a 144 volt traction pack or about 42 cells, should give me 60 miles around town and support freeway speeds. Not going to be a cheap project but I should learn lots of new tricks on this one. |
Great project,
Is that using 7-12V or 14-6V batteries? I read once that 6 V were better but the tech has been improving so much I don't know what's current. What is the life expectancy on the batteries these days? Also how long would it be to recharge after that 60 miles?Thanks. |
dubulup Samba Member
Joined: November 13, 2008 Posts: 387 Location: Earth People
Posted: Fri Sep 05, 2014 8:15 pm Post subject: |
I'm loving this this project! Super clean work...and nice MB. Any plans for the torsion bars with all the added weight? |
Posted: Sat Sep 06, 2014 7:19 am Post subject: |
Great walk through ! She's a real beauty, I am impressed. Can't wait to see this run. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Sat Sep 06, 2014 8:13 am Post subject: |
Sweet project!
I'm digging the whole thing.
Looking at your interior shot here:
The digital gauges and all that clean silver bare metal go together.
Don't finish it all out in fluffy carpet and poofy padded vinyl or cloth.
Leave it all clean silver metal and you have some type of high technology clean-room industrio theme perfect for the powerplant retro-fit you have going on!
Plus, you don't need the sound insulation, because it will be quiet,
And the weight savings will help both mileage and performance..! _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Sep 16, 2014 5:39 pm Post subject: |
I have a feeling your going to be stopping for a lot of bathroom breaks listening to the pump noise, lol. The fan is quite loud, I suppose you could find a quieter one. Looking great. What's an eta on a first test run? |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Sep 18, 2014 6:46 am Post subject: |
Just curious - will that coolant get hot enough to need a pressure relief cap on the reservoir similar to the cap used on a standard water cooled automobile radiator?
I can't tell from the picture/video if the cap on there is a pressure relief style or not.
Another thing I'm curious about - if you wanted to run an air conditioning system with a vehicle that has been converted to electric drive, how would the compressor be driven?
Obviously modern electric vehicles must have a system made specifically for that application, but I imagine they would be pricey.
(... as opposed to the inexpensive portions of the electic drive conversion such as the motor and batteries ) |
Posted: Thu Sep 18, 2014 2:38 pm Post subject: |
KGCoupe wrote: |
The system has a sealed non-venting cap now. I might swap it for a vented one later. As far as AC. they make a bracket for that.http://www.evwest.com/catalog/product_info.php?products_id=184 _________________ 1981 Puma GTB http://www.thesamba.com/vw/forum/viewtopic.php?p=7794566#7794566
Past Projects:
Posted: Thu Sep 18, 2014 4:30 pm Post subject: |
The AC system I saw installed in another electric VW was driven by another 24v dc motor up front, the guy did a great job, but it was a 24v dc drive too. No where near as cool as this build. |
Posted: Thu Oct 16, 2014 8:46 pm Post subject: |
I need some updates...I drove a Model S (again) and caught the fever all over _________________ http://vimeo.com/108749110 |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Fri Oct 17, 2014 8:18 am Post subject: |
KGCoupe wrote: |
Some motors have a double-ended shaft setup that has the shaft opposite from the transmission end projecting out (as it would on a standard Aircooled VW engine. A pulley is attached to this, and the A/C compressor is driven by belt from this pulley, similar to any gasoline powered car. Shaft can be used to drive alternator, hydraulic pump for power steering, A/C compressor, etc.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
