bluebus86 Banned
Posted: Fri Apr 18, 2014 4:38 pm Post subject: Re: Engine running too cool? |
Mr. Fickits wrote: |
Recently finished my 1904cc build and got it in the car. Runs great but the oil and heads just aren't getting up to operating temp. Should I be concerned? The jetting is close (not perfect yet). timing is 10/30 with the 009. Engine specs below.
1904cc 74 x 90.5 balanced
Aluminum super case
043 heads 40 x 35 p&p
52cc chambers, mirror polish
.038 decks
9.2:1
running 91 octane
26mm Schadek full flow'd
Gibbs HR1 15w50 conventional oil
dual Weber 44idfs
1-5/8 stainless sidewinder exhaust
compufire ignition
I cannot get the oil over 180F degrees and heads over 250F. I have had the VDO senders and gauges for a while and have worked is the past. The CHT sender is under #3 spark plug, the temp sender is at the rear pressure relief in the case. |
your oil temp is nice, I like 180F, the heads are way cool, could it be it was a hot day and your thermocouple on the heads is reading low because of the high ambient temperature?. Remember the head temp thermal couple reads higher as the air temp at the gage drops, and visa versa, as the air temp increases, the age will read lower.
what is your air temperature? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Mr. Fickits Samba Member
Posted: Fri Apr 18, 2014 5:58 pm Post subject: |
Its been in the 70s here in Reno. I'd like to tell you we have 6 feet of snow and its -30...but no. |
bluebus86 Banned
Posted: Fri Apr 18, 2014 8:22 pm Post subject: |
ok, time to make sure your calibrated, if you can bring a pot of boiling water o the car, and knowing your boiling point, you can check the gage calibrations. a camp stove will work to boil some water at the car, then dip the sendors into the water and read the gages.
The gages could be way off, I hope your oil is ok, I would be happy to have 180F oil. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Apr 19, 2014 9:53 am Post subject: |
So I just took the car out for a 30 minutes and hammered on it the entire time. It's about 65F ambient air. The hottest I could get the motor was 200F oil and 250F CHT. BTW. I'm loving this 1904. Car hauls ass. If y'all think these temps are acceptable then I will just leave it alone.
I will calibrate the guages as suggested.
Thanks again for the help all. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Apr 19, 2014 2:28 pm Post subject: |
I wish I could get my oil up to 200 Degrees.....
I'm lucky to hit 160 degrees.
I think I might have it fixed now though, _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sat Apr 19, 2014 5:22 pm Post subject: |
I would be tempted to drop the timing down to 28 deg and see how the temps react _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
