StevieC Samba Member
Joined: January 01, 2014 Posts: 412 Location: Anza Borrego
Posted: Tue Apr 15, 2014 9:37 am Post subject: Getting rid of the gas tank |
I think I'm gonna run a spun fuel tank behind the rear seat of my buggy
I think the stock front tank makes noise up there besides being almost useless as far as capacity due to the angle of my buggy
can I just take the front tank out and leave that area open underneath? |
RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Tue Apr 15, 2014 9:49 am Post subject: |
I dont see why not. Just make sure you cap off the steel line in the tunnel on both ends just in case you want to go with a different option like one of the tanks that Brad (iguana) has available for our buggies at a later date.
The tank removed will make it a bit lighter in the front (tank + gas) so be aware of that. Have you thought about what method you will use for tank level indication? _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
Posted: Tue Apr 15, 2014 10:01 am Post subject: |
thanks, my steel line runs outside the tunnel on the right side... unless that the brake line
I'm gonna buy one of those spun tanks with the fuel sender flanges
one of these
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Tue Apr 15, 2014 1:02 pm Post subject: |
You should be able to get 10 gallons of useable fuel from the stock tank, but it might take some work.
You might need to move the filler to the top rear of the tank.
You also might need to make sure the petcock on the bottom doesn't have "main and reserve" feeds and that you might be on the main.
You also probably need to take off the hood and ensure the tank is properly supported from below by brackets and secured by tabs.
Perching the fuel tank up above the back seat sounds like a poor design |
wythac Samba Member
Posted: Tue Apr 15, 2014 1:16 pm Post subject: |
You will need to put something to cover the hole where the fuel tank was, to keep air/dust/fod from coming up thru that hole and into the cabin at your feet. |
Posted: Tue Apr 15, 2014 1:53 pm Post subject: |
BL3Manx wrote: |
I'm draining the gas now, I'mg gonna pull the fuel outlet from the bottom of the tank and see what's going on with it
I'm guessing I could just pull the hood and flip the tank around with the filler to the rear and cut a new hole for the filler cap wherever it ends up
Something is making heavy noises over the whoops at speed and I'm guessing it's the tank
anyway I was thinking here behind the back seat is a perfect place for the spun aluminum tank
Posted: Tue Apr 15, 2014 1:54 pm Post subject: |
wythac wrote: |
thanks that's what I wondering, I don't want to mess with all that |
wythac Samba Member
Posted: Tue Apr 15, 2014 2:00 pm Post subject: |
If you put your primary tank elsewhere all you would need to do is put a shutoff valve on the spigot coming out of the original tank, them reroute or T the fuel line to your new tank.
I like the weight of the fuel up front for Fore and Aft balance. My tank has a 9.3 gal capacity...if it was only 5 I'd be lookin at options too... |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Tue Apr 15, 2014 2:01 pm Post subject: |
It's just me, but I think you would be able to find a fuel cell that would fit that location for close to the same price as one of those spun tanks. And I'd bet you could find one that was 10 gallons or more. With the fuel cell, you would be able to situate and angle it to get your full flow, since most of those tanks are square or rectangular. That would keep the weight on the front end and, if you got one with the foam, allow a little bit of crash protection. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Apr 15, 2014 3:21 pm Post subject: |
I get 9 1/2 gallons out of my stock VW tank in my Manx. I have seen the brackets on the spun aluminum tanks fail on sandrails that were in an accident, I wouldn't want that behind me without more protection from it.. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Tue Apr 15, 2014 5:57 pm Post subject: |
Letterman7 wrote: |
that sounds like the best plan, any idea what the dimensions would be? |
wythac Samba Member
Posted: Tue Apr 15, 2014 6:06 pm Post subject: |
How about this for an idea:
You have a lifted body which should give you more room on the underside of the stock tank. How about removing the tank and fabricating a bottom to graft to the top of your existing tank that takes advantage of that space and increases your fuel capacity. The tops and bottoms of stock tanks are rather simply constructed and welded.
This would allow you to keep the top of the tank with fuel filler and gauge sender intact. The gauge would probably be inaccurate on the lower end, which would put you in the 90th percentile of buggy owners...
Of course you'd have to make good measurements and find a fabricator...neither are insurmountable tasks depending on your local resources.
Just a thought. |
Posted: Tue Apr 15, 2014 7:10 pm Post subject: |
StevieC wrote: |
Letterman7 wrote: |
Only you can answer that with the body lift. Pull the original tank and take some basic measurements. Hop on Summit Racing or Jegs and look at their stock fuel cells and go from there. A Pro-Street 12 gallon cell measures roughly 17" x 17" x 11" - plenty small enough to put under the hood. |
EVfun Samba Member
Posted: Tue Apr 15, 2014 7:39 pm Post subject: |
With a body lift it might be possible to make a frame to mount the tank to the bottom side of the body opening. It could be designed to mount the rear part of the tank lower than the front, bringing it back to about the level VW intended, the one that allows it to hold 10.5 gallons. _________________
Wildthings wrote: |
Posted: Tue Apr 15, 2014 8:06 pm Post subject: |
I guess I won't know until I pull the hood
I have an a-arm subframe that takes up most the room under the gas tank.
Is the gas tank symmetrical? So I can rotate it around with fuel filler to the to instead of the bottom?
And if you do that will the spout reach the hood like it does in the front? |
BuggyFaron Samba Member
Joined: September 01, 2005 Posts: 441 Location: Canyon Lake, Texas
Posted: Tue Apr 15, 2014 8:45 pm Post subject: |
I just looked on the Summit website and a 10 gallon, black plastic, Fuel cell, that is built for Street Rods. Is $169.97, that seems likes a great option. Once I have the fuel cell I under the hood. Then I will re-glass the area under the hood to work with the Fuel cell. Seems to me that is a like this is the option to go with. |
joescoolcustoms Samba Member
Posted: Tue Apr 15, 2014 9:24 pm Post subject: |
If you are hearing more than fuel slosh from the front tank, you need to investigate what it is and why. Is the tank loose? Is the front of the body not supported?
Second, you need to investigate why you are only getting 5 gallon use out of that 10 gallon tank. Is there a riser on the outlet raising it up and leaving a large portion of fuel in the tank unused.
The tank cannot be switched around 180*, it only fits one way.
Before I would change anything, I would see why it is doing what you describe. Post a photo of how the tank's bottom is in the body with the discharge point, post a photo of the front tank/body supports, post a photo of where the front filler is located on the tank. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Apr 15, 2014 10:54 pm Post subject: |
joescoolcustoms wrote: |
Before I would change anything, I would see why it is doing what you describe. Post a photo of how the tank's bottom is in the body with the discharge point, post a photo of the front tank/body supports, post a photo of where the front filler is located on the tank. |
The more I look at it I don't see any supports for the body past the passenger compartment
Maybe the whole front is just hanging there
Heres' the tank bottom
Here's another pic of the front side
Another pic
the front
motoRAT Samba Member
Posted: Wed Apr 16, 2014 3:54 am Post subject: |
look I've done to my tank, I was getting only 5 litre (1.5 g) capacity, and on right turns, fuel came out, so this is what I did, not tested yet but I'm confidente it will work
cut it
flip it
_________________ Be curious, dismantle it all, reassemble it, go for a ride! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
My body just hangs out front as well. I think adding a support is not a bad idea. I kind of have that with a rubber bushing supporting the front of the stock tank, but something better will be done later. Its very possible that your body is flexing enough to allow the tank to bang into something. 10 gallons of fuel is a bit of weight to be hanging out there.
Anyway - I went through this last year on our buggy - had issues with the stock tank and was gonna be a real challenge removing hood, plus am planning a body off redo in the future. Did a 13 gal Jaz (I think) fuel cell in the rear seat area. Not super happy with it, but it works for now. Issue to consider. Tank angle greatly impacts your fuel sender reading. Mine sloped to the rear some and even if reading 1/8 tank, it only took 5 gal to fill it.
When I do the body off - will probably go back to a stock location tank. _________________ D-Dubya Manx clone - 63 Short pan,1914.
