svs Samba Member
Posted: Tue Apr 15, 2014 7:02 pm Post subject: Removing an aftermarket steering wheel |
It's a Grant wheel and I'm pretty sure the part that slides on the steering shaft the steering wheel bolts to is part of the adapter kit to make it fit.
I need to remove it and it's not sliding off the shaft. Can't see a retaining pin or clip.. It slides a little them stops.
Whose done this and knows?
Thanks.
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
svs Samba Member
Posted: Tue Apr 15, 2014 7:51 pm Post subject: |
56Cabrio wrote: |
You need a steering wheel puller. |
Is that an aftermarket adaptor for that particular steering wheel? Is it designed to use a puller to slide it off the splines?
I'm pretty sure it's part of the adapter kit. |
svs Samba Member
Posted: Tue Apr 15, 2014 9:10 pm Post subject: |
Thanks Dave, your post gave me an idea to bolt the steering wheel up and gently pull... It's off!
The kit you linked is it.. I replaced my steering box and it moved the steering wheel towards the driver and I slid the column tube also but just a little short of where it's needed. There is a small bind with the steering wheel at the top of the shaft.
This is what I'm trying to trouble shoot. Any ideas on that?
This was the spacing before I started to move the outer column tube
Posted: Tue Apr 15, 2014 9:15 pm Post subject: |
svs wrote: |
Is your steering coupler pushed all the way in ?
Maybe your turn signal wires are preventing the column from coming up far enough ?
_________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
svs Samba Member
Posted: Wed Apr 16, 2014 10:35 am Post subject: |
Steering coupler is all the way in and I removed the Turn signal housing itself to remove that as a limiting factor.
Now trying to learn what the correct spacing is now that everything is clear and can be aligned without interference. |
