kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Tue Apr 15, 2014 7:40 pm Post subject: Restoration of "Davey", a 67 Bug |
This Forum is to show the restoration of my wifes 67 Bug "Davey"
The bug was her first car bought for 2200.00
Since we are married now, I got the car for free!
My Goals for this bug are
1.) Restore the body
a. Two tone paint, fushia with white sides
b. Put a "W" rear deck lid on it
c. Restore the sunrood (fml)
d. Suicide the doors
2.) Modify the Suspension
a. Air bag it
-Have it slammed for show
-At normal hieght when on the go
b. CB prefromance brakes on all fours
c. Convert to 5 wides
d. Tranny raise???
d. Narrow front end
3.) Upgrade the guts
a. Use rancho perfromance tranny
b. Bore and Stroke the engine to 1915cc 74 crank and 90.5piston
c. Redo the valves
4.) The Creature Comforts
a. Convert to oil heater, vice heater boxes
-BN4 heater?
b. Install Air Conditioning
c. Electric windows
d. better defroster
e. Radio, install one |
2true Samba Member
Posted: Fri Apr 18, 2014 3:14 am Post subject: |
Piccccssssss _________________ AKA Destroyer of the Rants...... |
6Kabrio7 Samba Member
Joined: July 22, 2006 Posts: 2387 Location: California
Posted: Thu Mar 05, 2015 10:28 am Post subject: |
In her original glory in Hawaii
The bane of my existance, PITA sunroof
Working hard on the Westy, but hope to send Davey to blasting this coming month before the baby gets here. _________________ 84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner |
Posted: Sun Apr 19, 2015 7:09 pm Post subject: |
Just picked up a complete set of 67 fenders at kelly park today. On my way there, cursing the day I thought a sunroof would not be that bad to fix. _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
Posted: Fri May 01, 2015 9:53 am Post subject: |
So just picked up a raft op clip and a better set of fenders. Can't wait to never see or touch the sunroof again. _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
Posted: Wed May 06, 2015 6:19 pm Post subject: |
Started breaking down the ragtop. Here is how it goes
Submariner |
Posted: Fri May 08, 2015 6:09 pm Post subject: |
Got a little farther today. Removed the inner roof liner and rear most bow assemble. Missing a plastic white roller.
Submariner |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Fri May 08, 2015 6:38 pm Post subject: |
if you are going to do a flag do a German flag _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc
Posted: Tue May 12, 2015 3:37 pm Post subject: |
Almost done with luggage pan replacement
Submariner |
Posted: Wed May 20, 2015 7:50 pm Post subject: |
Sand blast and cut the rust out
Submariner |
Posted: Wed May 20, 2015 7:51 pm Post subject: |
And some more
Submariner |
Posted: Fri Jun 05, 2015 9:05 pm Post subject: |
A little farther. Now is time start some serious welding.
Submariner |
Posted: Thu Jun 11, 2015 1:33 pm Post subject: |
Just got my wiring harness, will be test fitting the fuse box prior to paint to get everything just right.
Here is what I bought
http://www.watsons-streetworks.com/dune-buggy-wiring-kit:
Also, the great task of putting in the ragtop sunroof will occur in just a few weeks. If anyone has any pointers that would be awesome. _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
Posted: Thu Jun 18, 2015 9:45 pm Post subject: |
Home to start the last bit of metal work. _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
Posted: Mon Jun 22, 2015 8:43 pm Post subject: |
Just started to really sit down and get the sliding ragtop sunroof in. Biggest things I have to say is measure 25 times and cut once.
Here is what I did with measuring.
TOOLS (the things you might not think about):
1.) 120 inch sewing measure tap. (It's really hard to measure curved objects)
2.) Carpenters square, made from bendy plastic. (I liked to make a measure perpendicular from a verified reference line or point.
Drawing the cut lines
1.) KEY REFERENCE POINTS: are a must. For this I used on both the donar clip and the car to get the clip the following:
A: Roof center-line. This was measured several times and verified in the a couple key places, i.e. windsheild, B-pillar, and few key points measured a specified distance from the B-pillar to form perpendicular lines from the gutter which ran across the roof.
B: B-pillar
C: Front of ragtop hole in roof.
D: Rear of ragtop hole.
E: Sides of ragtop hole.
When all was said and done I measured the diagnal distances across the roof to verify I made a perfect box. Did it right on the first try.
Other things to account for in the cut:
1.) How much the cutting instrument removes.
2.) How much of an over-lap you want when using a flanging tool. This is the strongest and most seem-less way of installing panels.
NOTE: When using a flanging tool, right angles are impossible to flange, to get around this I cut diagnol across the corners a small amount to form a octogon from the clip. Also, when using a flanging tool, verify that the all areas of the panel to be installed have no raised obstructions to offset your flang, _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
Posted: Mon Jun 22, 2015 9:47 pm Post subject: |
Here is the final color I am going for, its a close match!
Here is the paint chip:
Here is the white I am using for the two-tone:
Submariner
Posted: Mon Jun 22, 2015 9:50 pm Post subject: |
Here is the clip cut from the Donor roof. Tomorrow is cutting the the car roof to fit the donor clip, to include a .25" flang.
Submariner |
Posted: Tue Jun 23, 2015 6:59 pm Post subject: |
Going the extra mile and got the cut out clip from the donor sand blasted. Crisp, clean and ready for welding.
Question: do I keep the corner supports?
Submariner |
