KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Wed Apr 16, 2014 8:46 am Post subject: Question for non-USA (non-FI) cars |
I happened across this photo in the gallery:
Looking closely at the rear inner fender area, it looks like it not only lacks the FI ECU box as expected, but it also either has a flat cover plate, or embossing without the panel being punched out for the box. I don't see a gasket on the plate, and it appears flush (no shadow line). Can't be sure without a higher resolution photo.
So the question is, do the later, Euro non-FI cars have a plate screwed in place, or just an embossed pressing where the hole would go on an FI car? |
Dlglobal1 Samba Member
Posted: Wed Apr 16, 2014 9:09 am Post subject: Re: Question for non-USA (non-FI) cars |
KTPhil wrote: |
That's my car.. It's a Euro model 1970 TA and the ECU plate is embossed. But, as you can see there is some factory sealer there around it...so it appears to be two separate pieces.
_________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
KTPhil Samba Member
Posted: Wed Apr 16, 2014 9:10 am Post subject: |
Fascinating, thanks!
Now you can ignore my PM from 30 seconds ago! |
