Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Apr 16, 2014 5:45 pm Post subject: Rear brake adjustment issue! |
A few hundred miles ago, I replaced my parking-brake cables and I installed new German drums, shoes (probably not German), and springs.
I was replacing the rear shocks today so I thought I'd re-adjust the rear brakes and handbrake cable adjustment.
When I went to do my adjustments, the right side would play this game with me and I wondered if anyone else had had it happen. I'd adjust to get my slight rubs and turn the drum--wheel off. When I turned the drum about halfway, it would suddenly be very hard to turn. Then when I kept turning, it would become easy again--with just the slight scraping noise that I was looking for.
It's almost as if the drum was out of round--but I know it's not. It's new.
Anyone had this happen while adjusting the rears? I had to back off the stars a little to prevent this super drag on only one half turning of the drum.
Weird.
Anyone else?
Tim |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Apr 16, 2014 5:50 pm Post subject: |
just because the drum is new doesn't mean it is not out of round
did you adjust the rear brakes first after you put in new cables then adjusted the cables? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
mrmdls Samba Member
Joined: April 27, 2013 Posts: 410 Location: New Brunswick, Canada
Posted: Wed Apr 16, 2014 6:00 pm Post subject: |
Besides the possiblity of the drum being out of round, I'm wondering if somehow there might be some contamination of the new brake shoes. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Wed Apr 16, 2014 6:20 pm Post subject: |
drum's slightly out of round....you really don't have much leverage to turn it without the wheel so try it with it on....but both sides should behave the same...if you don't feel a pedal pulsation you can ignore it....if it really bothers you swap the drums side to side and see if the problem moves to the other side....if it does its the drum,if it doesn't its the stub axle ....just cause its new doesn't mean it wasn't dropped from a great height....or could have warped from overheating (driving with handbrake on,panic stop,sticking wheel cylinder,bad rubber hose etc) |
Posted: Wed Apr 16, 2014 8:19 pm Post subject: |
I paid big bucks for those German drums.
No panic stops, no pulsating, no leaving the parking brake on--although the rubber hoses were not changed in the back (I did change the fronts).
The one thing that bugs me is that the new cable to that side has to be cinched down, using most of the threaded portion of the cable end at the hand brake. The other side does not.
I'll take the drum off again and take it to have it measured to see if it's out of round. If it is, I'm taking it back.
I really should have just gotten rear discs. It would only have been another hundred bucks, or so, anyway.
Thanks, guys.
Tim |
Posted: Wed Apr 16, 2014 8:52 pm Post subject: |
compare both sides....if you had a frozen wheel cylinder that was overextended(or couldn't retract from a bad hose) the shoes would be too far apart at the top and you'd have to pull the handbrake arm way forward before the balance bar hit the front shoe....and that could cause the adjustment deal at the handle and the drag would overheat and warp the drum |
Posted: Thu Apr 17, 2014 2:22 pm Post subject: |
So I bought two new cottor pins. This weekend I'm going to take off the drums and see what's what.
I did raise the car and stepped on the brakes a few times whilw the wife turned the wheels when I let off the brakes. The wheels would turn easily after letting off the brakes. This leads me to believe that the slave cylinder is not freezing, and the rubber hose is not plugged up.
I re-adjusted this time with the wheels on. The drag at that certain part of the spinning was not nearly as evident--practically nonexistent, actually. So, I may have discovered an issue, simply because I tried to adjust the rear drum without the wheel being on. Doing so takes away the leverage which the installed wheel gives you when hand spinning it.
The new shocks (oil-filled Sachs) provided a slight issue (nothing ever fits exactly right when I replace a part on this bug ). The bottom part of the shock would not fit into its housing, so I had to file off a little metal to squinch it in there. Other than that, the job would have taken just a few minutes.
Tim |
talljordan Samba Member
Joined: January 10, 2012 Posts: 967 Location: San Francisco, CA
Posted: Thu Apr 17, 2014 8:02 pm Post subject: |
Im having the same issue, apparently you should adjust till tight, back off three notches (ignore if it rubs half the time you spin it) pump the brakes a few times and go for a drive around the block. There shouldnt be any more rubbing. Ill be doing this tomorrow, _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Apr 17, 2014 8:50 pm Post subject: |
talljordan wrote: |
Im having the same issue, apparently you should adjust till tight, back off three notches (ignore if it rubs half the time you spin it) pump the brakes a few times and go for a drive around the block. There shouldnt be any more rubbing. Ill be doing this tomorrow, |
I have better luck if I adjust till tight, pump the brakes hard a few times to center the shoes, THEN back off the adjusters if necessary. Sometimes they don't need to be backed off. |
Posted: Fri Apr 18, 2014 5:15 am Post subject: |
if the adjuster's slot is 180 out the shoe wont center itself and adjust properly |
johnR Samba Member
Joined: August 25, 2009 Posts: 668 Location: Virginia
Posted: Fri Apr 18, 2014 8:32 am Post subject: |
Right. The slot in the star adjuster is angled and should match the brake shoe. If it's the other way, the shoe will be a bit cockeyed. |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Fri Apr 18, 2014 9:57 am Post subject: |
volksworld wrote: |
Beat me to it _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Posted: Fri Apr 18, 2014 11:58 am Post subject: |
Well, the slots are not 180 out. I don't even see how you'd get the drum on it they were.
So, I got fed up and went down to Al Kraut's VW repair shop here in town. He's an old "Muldoon" type that has been working on bugs since the world was young.
He jacked up the car and spun the wheels. One wheel was too snug. I told him that when I adjusted it yesterday, the wheel spun freely. He told he that I was not driving the car then and the brakes "expand" when they heat up. Hm? Had I adjusted it too tightly for driving?
I had him adjust the wheels--just to see if the drums were out of round--in his opinion. He told me that I had adjusted the parking brake too tightly, of course. I told him that I had adjusted it to Hayne's specs for my year: pull up three clicks on the handle and tighten the cables until you can just barely turn the wheels.
He told me that Hayne's was wrong.
Over the years, there were a number of paws in the parking brake handles. All had their teeth start at different places from the other. Three teeth on one of these, put the handle at a different height than the others. So you had to do it by feel--not the number of clicks.
He also adjusted the drums--not for the slight drag that I had adjusted--but to the point where the drag just started to show itself.
My new drums and shoes were not out of round, after all.
So, basically, I suppose it's sometimes best to listen to the old guys who have been doing this since sock hops were popular, instead of our manuals.
I watched him very closely.
Tim |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Posted: Wed Apr 23, 2014 8:44 pm Post subject: |
the best use for a Haynes manual is an emergency source of toilet paper...please get a bentley |
