Scorpwanna Samba Member
Posted: Thu Apr 17, 2014 12:28 am Post subject: Fuel Pump, buy another or rebuild one |
I'm currently on my second new empi (i know...) fuel pump and it looks like I may need to get another.
Since my fuel gauge is erratic I never know exactly when I might run out of fuel. Usually I can tell by where the needle is but rainy weather seems to make it shift around. Anyway, I ran out of fuel the other day and pulled to the side of the road, gas can to the rescue. Seems ever since then the car acts fuel starved. It's ok for the first few mins or mile or so then it starts loosing power bucking just barely. I experienced this before when I found that the previous fuel pump I had in it (empi) wasn't squirting fuel but about a few inches so I changed the fuel pump to the current one in it a few months ago.
I fear that running out of gas has hurt the pump that's in it and was wondering if it was just best to rebuild a pump that came with the other engine I got with my car. It's a brosol brazillan pump. I took it apart to check out how the insides were and clean it up some. It was full of old hard fuel and what looks like dirt. I figured now would be the perfect time to try and see if I could rebuild it, it's something I've wanted to do for a while. So I ordered a kit from wolfsburgwest for the 1200-1600 rebuild. Seems pretty straight forward until I read on here about preloading...
Since I've never done one of these rebuilds is it best if I found a better fuel pump to replace the one I have now? Maybe one that will last the next time I run out of gas?
_________________ 1971 Super Beetle Sedan Stock
Manufacture Date: December 12 1970
Left Factory on: December 17 1970 (Emden Germany)
Received: Washington, USA
Original Color: L 12 D Shantung Yellow
SOLEX 34-PICT 3 Carb
I've got a Bentley |
Posted: Thu Apr 17, 2014 12:37 am Post subject: |
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111198555
This is the kit I bought for it, but when I took apart the pump I have it didn't have some of those parts. Like a midsized spring, or that little piece of black what looks like felt.
In the picture below, aside from the obvious pump base gaskets X'ed out the 4 pieces that I'm pointing at are what I didn't see inside the pump.
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Posted: Thu Apr 17, 2014 12:38 am Post subject: |
clean the contacts and earth connections on the vibrator unit and it's interface with the speedo, to get that guage stable. While you are there, throw out the metal vibrator and replace with new black solidstate one.
Check with a multimeter that fuel tank is grounding properly to the chassis.
Also pull sender from tank and make sure the float hasn't sprung a leak. _________________ If you can't fix it with a hammer, it is an electrical fault.
Photo's http://www.thesamba.com/vw/forum/album_search.php?search_author=Hyperspace&show_results=summary |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Thu Apr 17, 2014 5:24 am Post subject: |
Those pieces are for the delivery valve assembly, and ARE part of your fuel pump. Scroll down about halfway on this page: http://www.hotvws.com/content.php?contentID=45
you need to be careful removing it. The felt piece in the kit replaces a bakelite piece in the pump. I re-used the original piece cleaned up and the new spring.
If you ran your tank dry, chances are some gunk got through your fuel line and is what's causing your hesitation problems. Take out the fuel lines in the engine compartment and blow through them. Take the top of the carb off and remove the float needle valve and blow it out as well as the carb inlet passage. A small chunk of crap or rubber from new fuel lines will bounce around and clog that valve, causing the engine to run like shite. put a new filter by the tranny. This is the LEAST you can do, will cost about $5 and some time, and hopefully will solve your problem without swapping the fuel pump. I would run some fuel through the pump before attaching the hose back to the carb just to work out any little chunks that may be floating around in it. The rebuildable pumps are nice cuz they have a little filter screen in them you can take out and clean occasionally. I rebuilt a Bocar one like yours recently for my new engine.
Good luck sir... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Posted: Thu Apr 17, 2014 10:44 am Post subject: |
I've got a clear filter before the tranny. That's what makes me think it may be pump related. :( _________________ 1971 Super Beetle Sedan Stock
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Fri Apr 18, 2014 12:37 am Post subject: |
Not sure if the '71 SB has the same tank as the '73 SB. Have you looked at the filter at the bottom of the fuel tank?
_________________ AshMan40
Posted: Sat Apr 19, 2014 12:41 pm Post subject: |
The tank inside the car is only 2 years old. It's built in filter doesn't line up with the hole in the body of the car to unscrew it out.
It feels like something did get sucked into the carb though, but I dunno how. From the tank i have rubber fuel line to hard line to rubber - <clear filter> - rubber - metal - rubber - pump. Lines are less than a year old and haven't been played with much. However I guess it could suck something through and into the carb. I haven't had the chance to take the oil bath breather off and the top off the carb to look in the bowl. I can imagine a piece of rubber there for some reason.
Anyway, got the pump parts cleaned and waiting on the rebuild kit for the fuel pump from wolfsburgwest. Still though I took everything apart from it and don't see that ring piece anywhere.
Posted: Sat Apr 19, 2014 4:31 pm Post subject: |
^^^bottom row of this pic, 3rd, 4th, and 5th items from the right are the pieces you have pointed out in the kit pic with red lines. They are different in the kit but will fit. I re-used the old ones with the new spring. The ring you have pointed out on the far left of the rebuild kit pic is a gasket you use under the bolt that gives access to the filter screen.
Also the two halves in the middle of your pic above go around the shaft to the big diaphragm. They are busted obviously. you'll see it in the kit picture as a black ring going around the base of the connecting rod that attaches to the pump rod lever. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
Posted: Sat Apr 19, 2014 9:57 pm Post subject: |
Is this going to be a problem? Doesn't look like this part was put in centered.
The underside of the side that faces up even has these little teeth like it wasn't shaved off or something.
Posted: Sun Apr 20, 2014 6:32 pm Post subject: |
Anyone know of a good solution I could use to clean some tar like old gas out of the inside of the filter? Something that won't eat the plastic? _________________ 1971 Super Beetle Sedan Stock
Posted: Sun Apr 20, 2014 8:02 pm Post subject: |
I don't have a jig, but I have read about creating one with screws and stuff.
I haven't reassembled anything yet, waiting to see if someone can tell me if that part being off center will be a problem or not. I emailed wolfsburgwest about it and haven't heard back from them either. _________________ 1971 Super Beetle Sedan Stock
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Apr 20, 2014 8:18 pm Post subject: |
Scorpwanna wrote: |
Anyone know of a good solution I could use to clean some tar like old gas out of the inside of the filter? Something that won't eat the plastic? |
If your plastic fuel filter is dirty I think it's best to replace it then to try to clean it.
I bet the rubber thing will be fine . It's just sucks that's about the best we can expect these days |
Posted: Mon Apr 21, 2014 3:44 pm Post subject: |
Guy named Rich from wolfsburgwest is sending me another top piece to replace the one he even says looks defective.
Thanks for the link to the jig.
Should I paint the fuel pump, if so what kind of paint? I have a spray can of engine/muffler silver I used on the muffler. I only ask this because when I bought a rebuilt solex it was shiny metal aluminum looking. Kinda want the parts to match. _________________ 1971 Super Beetle Sedan Stock
Posted: Tue Apr 22, 2014 10:30 am Post subject: |
