shugco Samba Member
Joined: November 25, 2012 Posts: 9 Location: Pahrump, NV
Posted: Thu Apr 17, 2014 1:07 pm Post subject: Are dual webber 44s too much for a 1914? |
I am starting a 1914 build; I have a fresh cut dual relief/ full flow case, Steve Tim's stage 1 heads 40x35.5, and 94mm mahle pistons. I am unsure about which cam to go with, I have access to some dual webber 44s but im wondering if they are too big. I am a new builder but will have help. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Thu Apr 17, 2014 1:40 pm Post subject: |
Looking at the intake valve at 40mm you might want to go smaller carbs. Otherwise you may have sluggish responsiveness compared to a 40mm Carb. You might be able to get away with smaller venturis to get a little closer. Depends on the application too. Sitting in traffic I would go 40's. Drag car; 44's or even 48' if it's high strung. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
shugco Samba Member
Posted: Thu Apr 17, 2014 4:27 pm Post subject: |
I've thought about going stroker, I don't wanna have to drop off case to make clearance. What's the biggest crank I can use in a OG case without needing more room for clearance? |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Thu Apr 17, 2014 4:31 pm Post subject: |
74mm usually fits without clearance needed. You can put a 76mm in there if you don't mind clearing out ~2mm of material in a few places. I've clearanced for 76mm by hand - it's easy with a small dremel tool. For 78mm and above a machine shop saves a lot of hand work. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
shugco Samba Member
Posted: Thu Apr 17, 2014 6:55 pm Post subject: |
Well, after talking with my mechanic...we are going all the way. 82x94 stroker. Mild cam so it's streetable. Dpr crank in the order list. |
sambabus Samba Member
Joined: December 02, 2009 Posts: 324 Location: N. Cal
Posted: Thu Apr 17, 2014 7:31 pm Post subject: |
shugco wrote: |
Nice choice! That's up next for my bug. _________________ 1971 Westy, 2017cc 78.4 x 90.5 Tims Stage 1 plus 42x37, CB 44IDF's, 135 mains, 175 airs, F111, 50 idles, Engle 110, 30mm, 009, single QP, DD CHT 300*f, VDO oil always 180* Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=541370
1970 convertible bug, 1835cc, single 40IDF, disks.
Symptoms Solved and Fixed http://www.thesamba.com/vw/forum/viewtopic.php?t=551358 |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Fri Apr 18, 2014 3:36 am Post subject: |
shugco wrote: |
It costs almost the exact same amount. Good choice. Fk8 with 1.25 rockers, 9:1 compression...done. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Fri Apr 18, 2014 4:03 am Post subject: |
I do not know of what crank brand you are using, but in general be really, REALLY careful of stroker crank quality. Seen s few 'name brand' cranks quit well before 20,000 miles in light duty streeters.
This is an advantage of retaining a standard stroke crank - the VW forging is just about formidable
And 44s are a good choice for a 1.9L
Hope this helps |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Fri Apr 18, 2014 9:40 am Post subject: |
shugco wrote: |
Now you're talkin'...the 44's will work for sure now and after drivin' a 2276, you'll wonder why you didn't do this before. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
shugco Samba Member
Posted: Fri Apr 18, 2014 9:55 am Post subject: |
12.5 or 13lb flywheel?
I have 1.4 rockers, 5.5 H rods, mahle B, and just upgraded my Steve Tim's stage 1 to Stage 2 42x37.5, dual 44s. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Fri Apr 18, 2014 10:00 am Post subject: |
For the street 13 lbs.
My bet, Web 86B and 9,5 CR. The Tims stage2 heads are great.
T |
shugco Samba Member
Posted: Fri Apr 18, 2014 10:02 am Post subject: |
94mm B, not sure what CR yet. between 9-9.5. |
LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Wed Apr 23, 2014 12:13 am Post subject: |
Would 9.5 CR be possible? I wanted 9:1 for a street car too, I was thinking 1914 but I think 2276 is better now. I want a quick response but I want to use regular pump fuel. I'm guessing 91 for 9:1.
Would 91 still for work 9.5? _________________ one, two, many
one too many |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Apr 23, 2014 1:15 am Post subject: |
I ran 9.6 on my 2276 w/ idas and i was able to run 87. But for the mpg gain and cooler vs cost, its worth running 92.
Awesome step up to Tims stage 2s. Like Alstrup noted, they really are great street heads for price and performance imo. Now you can run an fk10, fk8 or 86b. 10 cr. 13 vs 12.5 # diff is so small. Get which ever one is cheaper. Most important, get everything balanced and do full flow and a deep sump. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
