thebusandus Samba Member
Joined: February 12, 2014 Posts: 412 Location: Alaska
Posted: Thu Apr 17, 2014 5:53 pm Post subject: 1975 5 Rib 002 vs 091 |
I am in the middle (getting there) of a subaru swap, and I'm reached a dilemma of whether or not to retain the 002.
I've read that the 091 is the strongest transmission built and I believe I can get one locally. Also with the swap there is more support and design affiliated with the 091. I am no transmission expert, those that know, would the 002 hold up with a 2.2 subaru?
Thanks
Divo |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Thu Apr 17, 2014 6:26 pm Post subject: |
Well I would say the 002 5 rib is the second strongest if that's any help. Go with it and if it grenades then find a 6 rib. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Thu Apr 17, 2014 7:42 pm Post subject: |
mild-core has been tearing it up with a 002. aside from what he has told me about running a smaller tire, it's doing just fine. his plan to switch to a 091 was for better gearing.
that said, the 5 rim is suppose to have the tallest of all the baywindow boxes
if you're not dropping the clutch at 10K, it will be fine.
speaking of clutches, i hope you don't plan on using a stock one _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Fri Apr 18, 2014 5:42 am Post subject: |
+3
The '75 4.86 R&P is quite strong (same ratio as all later U.S. Syncro vans) .. by far the best of the 002s. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Fri Apr 18, 2014 8:00 am Post subject: |
... of course with all thats been said it doesn`t mean its OK to do burn outs in your bus. |
archemitis Samba Member
Joined: November 07, 2012 Posts: 229 Location: minneapolis mn
Posted: Fri Apr 18, 2014 11:48 am Post subject: |
If your going through all of the trouble of doing a subaru swap, then you might as well not cheap out on the transmission.
The 091 will get your more strength(reliability) and better cruising rpms for fuel economy. Two reasons you are probably switching to the Subaru in the first place.
No brainer to me |
Posted: Wed Apr 23, 2014 1:49 pm Post subject: |
That is my thought as well Archemitis. I definitely want the gearing and the strength the 091 has, maybe even taller. I was considering changing the gearing in the 002 as well. |
