mslawren Samba Member
Posted: Thu Apr 17, 2014 9:08 pm Post subject: Help ! not sure what is wrong Spring plate |
I dont know what is going on. I was told i should replace the inner and outer bushings on my things. But, as i am trying to put them back in they will not fit. The spring plate and rod look straight and normal, but the plate cover will not line up bolt on or anything. Not sure what i have done wrong. Got the plate cover on the other side, but the cover does not sit center on the spring plate... help ... why?
surfarii Samba Member
Joined: November 26, 2006 Posts: 307 Location: Hawaii
Posted: Thu Apr 17, 2014 9:52 pm Post subject: |
All of the torque from the torsion bar will make the plate difficult to line up. Once you get one threaded it will become easier. I don't know how others do it but i wrap a 5/16 proof coil chain around the upper shock mount and fasten both ends around the axle of my floor jack with a 3/8 grade 8 bolt with flat washers.
I then Jack the spring plate up a bit to relieve downward pressure on the torsion bar. Just enough to get one bolt started. Dont lift the vehicle off the ground!
If you have a drift punch it will help get things lined up.
Once one is started I use C-clamp vise grips to help pull the plate in and start the threads of the other 3 bolts
Keep out from under it and make the vehicle is not going to fall on you.
Interested how others do it as well |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Fri Apr 18, 2014 6:07 pm Post subject: |
may want to go with longer bolts to get them started, once "sucked up" into place, you can replace, went through this recently. took a little wrestling
longer bolts really helped. |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Fri Apr 18, 2014 7:14 pm Post subject: |
I use 2 long bolts diagonally to draw it in. Then use the original bolts in the other 2 holes. Then the long bolts can be replaced with the originals. _________________ (ignore the X's ) |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Apr 18, 2014 7:15 pm Post subject: |
Agree, longer bolts and tighten in a cross pattern. Then swap to the correct bolts. |
Posted: Sat Apr 19, 2014 3:13 am Post subject: |
Longer bolts and talcum powered dusted over the bushing. |
Posted: Sat Apr 19, 2014 7:19 am Post subject: |
Thanks for all the advise i will try it. Does it matter that the spring plate cover does not sit centered on the spring plate? |
74 Thing Samba Member
Posted: Sat Apr 19, 2014 8:44 am Post subject: |
Yes, longer bolts....I believe that they are 10x1.5M |
Posted: Sat Apr 19, 2014 8:59 am Post subject: |
mslawren wrote: |
The cover pretty much preloads the bushings when installed. What you are seeing is normal. |
guppysoup Samba Member
Joined: June 07, 2003 Posts: 387 Location: Jalisco, Mexico
Posted: Sat Apr 19, 2014 9:28 am Post subject: |
If you don´t have longer bolts (like me) use some small c clamps or vice grips and line the holes up with a screw driver. _________________ 1973 Thing/Safari
1985 Bug/Vocho wanna be class 11
2014 Amarok TDI 4x4 |
hobie16 Samba Member
Posted: Sun Apr 20, 2014 5:53 pm Post subject: |
guppysoup wrote: |
If you don´t have longer bolts (like me) use some small c clamps or vice grips and line the holes up with a screw driver. |
Don't munge up the threads. _________________ Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron |
