Total Bummer Forever Samba Member
Joined: March 30, 2014 Posts: 52 Location: San Jose CA
Posted: Sat Apr 19, 2014 8:49 am Post subject: Fuel pressure regulator locations with stock pump? |
I'm having a difficult time determining where to mount my fuel pressure regulator outside the engine bay while using my stock pump. Can the regulator be mounted on the intake side of the pump, up by the gas tank? Or am I limited to running it off of the discharge side somewhere crazy? |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2237 Location: Medford, OR
Posted: Sat Apr 19, 2014 9:32 am Post subject: |
Being as it needs to regulate the pressure going to the carbs, discharge side.
If you are running it to dual carbs, you can run the line back to the left side firewall, mount the regulator there, and T from there to each carb.
If course that doesn't get it out of the engine bay. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Apr 19, 2014 11:26 am Post subject: |
Best place is on shelf above workbench....
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Sun Apr 20, 2014 8:39 am Post subject: |
Dale M. wrote: |
Dale |
X 2
Why do you want to use a regulator for a stock pump? More parts and more leaks. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
Posted: Sun Apr 20, 2014 8:52 am Post subject: |
Dual kads. I need to get to 2psi and I don't really want to use gaskets unless it's definitely the better way to go |
hooker Samba Member
Posted: Sun Apr 20, 2014 9:08 am Post subject: |
Total Bummer Forever wrote: |
If you have good needle valves in the float bowls on the inlet of the carbs I found kads do fine up to 3 1/2 lbs. Unless you get GOOD regulators and a gauge too it's a waste of time and money. You can also shorten the fuel pump rod some to lower the pressure in a stock fuel pump _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Apr 20, 2014 4:51 pm Post subject: |
Try it without the reg first. I have never installed a reg with Kaddies and a stock mechanical pump
I use a Facet with modified Kaddies (electric/higher-flow pump required for the engine's power level - otherwise I would use stock!) and there are no pressure-related problem with it (prolonged idle) either ... so give it a try.
Hope this helps |
Jcr. Kat Samba Member
Joined: November 09, 2012 Posts: 180 Location: san diego ca.
Posted: Mon Apr 21, 2014 4:13 pm Post subject: |
No need for regulators no adding gaskets learn to do it the old school way like hooker said shorten the rod. |
