irun5k Samba Member
Joined: February 21, 2014 Posts: 335 Location: St. Petersburg, FL
Posted: Sat Apr 19, 2014 5:19 pm Post subject: drain locations |
Hello, I was wondering if someone has a list of drains that should be checked for blockage on a '69 Beetle?
I know there are supposed to be 2 in the bottoms of each door? I've only found one but I'm guessing one is supposed to be near the front and one near the back?
I've read about rocker drains but didn't find anything conclusive regarding whether the '69 has them or where to look?
The other I know about is the drain out of the fresh air box.
Anything else? |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Sat Apr 19, 2014 6:43 pm Post subject: |
Something related: I drilled another (a second) hole in my door bottoms because I took off the interior door panel after a rain, and the car being parked on an incline, just let the water sit in there. So I have a hole at each end now. Also, you may have two triangular-shaped hole/depressions on your door sills. If so, you might unplug them.
I have a '74 Super, by the way. But you may have two rubber sort of check valves that are for draining. They are located in the back portion of the heater channels. They are about the size of a quarter, a soft rubber, and look like a sort of squashed half circle.
Since my heater channels are rust free, I figure that was a good idea.
Maybe you have them, too.
Tim |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
Posted: Sun Apr 20, 2014 3:37 am Post subject: |
Well.......
Because of bad drains, I at one point had this discouraging pile of tin!
There is one in the rear of the pan. Below the shift coupler under the back seat. If you crawl under the car you will find a dimple pointing down with a hole, about 1/2" in the dimple. You SHOULD have a rubber valve there but it is probably long gone.
Rubber valve......
You can see the Hole and Dimple at the end of the last X pattern just before the oval transaxle mounting bracket.......
The above photo also shows the two drains at the "napoleons hat" below the brake master cylinder. Dirt builds up on the plate and rusts this critical structure away! See them in the front at the mid point of the first X.
Open the door, either door, look below the lower hinge on the very bottom of the "A" pillar...... See the arrow?.....
You need to close the door and remove the running board but you will find this hole.......... It is often rusted away or completely clogged. It drains the "Black Hole" under each front lid Spring......
Ok, open a door and look at the metal threshhold. Above the Running board but outside of the carpet. There should be two triangular shaped drain holes stamped in. You can see them in this photo near the ends left and right (this is a Convertible so you will see reinforcements that a Sedan doesn't have that get covered by carpet)......
A close up....... It's sideways, sorry, tilt head to left........
Inside the car looking out. The door threshhold, you can see the triangular drain dimples, but look to the front...... on the hinge pillar, see that round hole? This is access for the lower door hinge. It is normally covered by a plastic plug to keep out dirt, but..... Even with the plug As you drive, water and fine dirt get past the door hinges where they protrude from the body and settle in the bottom of the hinge pillar below this hole.
Clean this area or the lower "A" pillar will rot away!
Here is my door off the car, find you drain holes and clean them to prevent this kind of rot!....
Here is my heater channel, I never saw the heater channel Drain Tim describes for this is what my channel looked like!......
Not of concern IF you have good rubber but at each lower windshield corner are these holes, designed to drain away excess primer after dipping at the factory. When the rubber seal dries, these hole let in water behind the dash!..... But........ Even with decent rubber, rust happens under the rubber! See the rusty bubble area? Not good!
Sedans have drains for air behind each 1/4 window...... The crescent vent.
Sadly over time they let in moisture which the factory foam holds against the metal which in turn rusts out the entire area. A cut away view showing the air drain box and the death foam.......
I'm working from memory here but.........
I haven't photos but look at the bottom edges of your fenders where they are rolled under, there are often drain holes provided so water doesn't sit in there.
Also the front and the rear aprons where they are rolled creating a lip may have holes drilled.
If you pop you rear inner 1/4 panel interior trim panel off, you will find a drain into the rocker panel.
Additionally, If you have a Sun Roof the drain for it drains into this cavity!!! I rarely say this....... But ......... BAD DESIGN!!!!!!
Ghia
Vanagon
Beetle
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Sun Apr 20, 2014 3:44 am Post subject: |
My '69 has the rubber 'plugs', that Tim describes, at each end of the heater channels.
mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Posted: Sun Apr 20, 2014 9:04 am Post subject: |
I have to go through a five-point process to take a pic, upload it to my computer, put it in the Gallery, post it. So ...
... the drain plugs in the heater channels are at either end, just before the fenders, fore and aft. The plugs are about the size of a quarter and the exposed part of each plug is a kind of dome--but not too domey, so to speak. If you pull this plug out (it's very soft rubber), the end that sticks into the hole (which is much smaller than the exterior circumference of the plug) has a "T" from what I remember. This "T" holds the plug in.
The plugs are very soft rubber and fit kind of snug/loosy to the drain holes. This allows only water seepage to exit, while not letting a lot of your heated air to escape the heater channels.
I didn't realize I had the front plugs until vern mentioned it. Later today I'm going to check to see if they're all intact. I can't imagine where I'd buy one if it were missing.
Tim |
Posted: Sun Apr 20, 2014 1:23 pm Post subject: |
Tim Donahoe wrote: |
Tim |
Excellent description Tim........and less than a thousand words.....good work.
irun5k Samba Member
Posted: Sun Apr 20, 2014 7:09 pm Post subject: |
Thank you guys, this is a very valuable post. I can't think of any more important maintenance task, to be honest.
I do not think my '69 has the heater channel plugs. I am assuming it would be in the area exposed when the running boards are off?
I'm going to track the rest down this week.
This car is generally solid- body, pan, etc. but something clearly failed on the passenger side because the lower hinge pillar rotted out. I imagine water got in and rusted its way out. The small triangular area of body between the hinge pillar and front fender also rotted out. Weirdest thing, but from this hole I extracted a shotgun shell, metal ballpoint pen and #3 pencil. I don't know if that stuff could have dropped in from the trunk somehow... |
Posted: Mon Apr 21, 2014 3:42 am Post subject: |
irun5k wrote: |
No, not where the running board fasteners, but front and rear of the heater channel assembly , inside the fenders, the road splash area.
The rotted hinge? Clogged triangle at the bottom in front of the hinge pillar and crud getting trapped in the lower door screw hole.
Crap in the black hole? Yes, it was in the trunk and fell into the blackness!
Ghia
Vanagon
Beetle
Posted: Mon Apr 21, 2014 3:49 am Post subject: |
Tim |
Good explanation Tim! ......... but as they say, a picture is worth 1000 words!
Can anyone take a photo of these plugs and post them here?
The OP didn't follow the explanation.
Ghia
Vanagon
Beetle
djkeev wrote: |
irun5k wrote: |
Dave |
Dave, on my '69, the plugs (drains) are on the bottom of the heater channels at both the front and the rear.
Molly1973 Samba Member
Posted: Mon Apr 21, 2014 11:57 am Post subject: |
This is great information! Thank you! |
irun5k Samba Member
Posted: Mon Apr 21, 2014 1:05 pm Post subject: |
Okay, found a couple of candidates underneath my heater channels. Not sure if this is them or not. The rear looks to be something I could pry out and the front might be missing whatever it once had. Thoughts? Fenders aren't off so if there is a drain lurking there I'll have to discover it another day.
fore:
aft:
bandi Samba Member
Joined: August 24, 2005 Posts: 1063 Location: Campbellford, Ontario, Canada
Posted: Mon Apr 21, 2014 8:02 pm Post subject: |
Well, this is going to keep me awake at night now... something else to worry about... my drains!
(Awesome post. Thank you.) _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Tue Oct 04, 2016 9:08 pm Post subject: Re: drain locations |
You guys have done a GREAT job of explaining the location and function of the original factory drain holes. So, after millions of bugs produced and perhaps hundreds of thousands rebuilt by fellow enthusiasts, can anyone recommend where there SHOULD have been additional drain holes? While I'm still in the pre-reassembly stage on my '66 project, it would be helpful to know where I might locate additional drain holes in order to perhaps prolong the life of my Beetle? _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Frank Bassman Samba Member
Posted: Wed Oct 05, 2016 4:19 am Post subject: Re: drain locations |
I personally would drill a hole like the ones on the back on the plate to which the pans' outer perimeter is bolted to the heater channel, by the black hole pillar. I did a patch job on mine because they were rotted in that area alone. Clearly there was something up with water accumulating there and only there.
-Frank. |
Frodge Samba Member
Posted: Wed Oct 05, 2016 5:12 am Post subject: Re: drain locations |
Where and how many drains on the doors? |
Posted: Wed Oct 05, 2016 8:45 am Post subject: Re: drain locations |
Love this post! Thank you! |
