JanS Samba Member
Joined: February 07, 2014 Posts: 15 Location: Pittsburgh Pa.
Posted: Sun Apr 20, 2014 9:52 am Post subject: Beetle oil capacity |
The manuals say 2 1/2 quarts with no mention of a filter? I drained my 59 with a later model Brazil engine and it looked like 4 or 5 came out. After draining and replacing the filter and adding 2 1/2 quarts the oil didn't even touch the bottom of the stick? It's a chrome after market stick but how could it be off a good 3 inches??? Thanks! |
sb001 Samba Member
Posted: Sun Apr 20, 2014 10:01 am Post subject: Re: Beetle oil capacity |
JanS wrote: |
Do you have a deep sump attached? And a full flow oil filter? This would add at least 1-1.5 quarts of oil.
The fact that you say you "replaced the filter" makes me think this is what you have _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Apr 20, 2014 10:01 am Post subject: |
if it has a filter it needs more. Are there long hoses to the filter or is it screwed onto the oil pump?probably needs another quart. |
JanS Samba Member
Posted: Sun Apr 20, 2014 10:11 am Post subject: re |
Here's a picture of what I have |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Sun Apr 20, 2014 10:17 am Post subject: |
that's an aftermarket sump. it uses about 3 quarts by itself. Just fill it up to the full mark on the dipstick _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sun Apr 20, 2014 10:49 am Post subject: |
It's a Scat 1.5qt sump, so put in 3.5 quarts and top up after checking the dipstick. _________________ Glenn
Member #1009
#BlueSquare |
JanS Samba Member
Posted: Sun Apr 20, 2014 10:58 am Post subject: Re |
Might take less. Just measured it. It's 10 X 9 and only 1 1/4 thick. Probably the reason I was getting blow by as it being overfilled. Couldn't find one listed that size? |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sun Apr 20, 2014 11:11 am Post subject: Re: Re |
JanS wrote: |
well how ever much it takes to be within fill line on stick ,...if its a spin on filter start engine after oil change let it run a few minutes , turn offf ,,in 5 minutes recheck oil stick.. |
JanS Samba Member
Posted: Sun Apr 20, 2014 12:28 pm Post subject: Re |
Ok the stock engine is 2 1/2 quarts, this sump looks like the 1 1/2 quart. So how about if I go with 4 quarts and use that as the full mark on the stick? The chrome stick that's in there is probably for an engine without a sump. It measures 6 inches. |
Posted: Sun Apr 20, 2014 4:11 pm Post subject: Re: Re |
JanS wrote: |
I could be wrong , but even with the stock stick and the added sump, you should go to the fill line on the stick , ....if it was any longer , the fill line would sit at the same spot as stock.... |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Sun Apr 20, 2014 4:19 pm Post subject: Re: Re |
JanS wrote: |
The existence of a deep sump has nothing to do with the length of the dipstick, since the max oil level will be the same in either case (just the quantity to get to that height changes).
As you say, try 4 quarts and check the oil level on the stick - if it needs a little more to get to the oil level up to the full mark, then put a little more in. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Apr 20, 2014 4:41 pm Post subject: |
...yes and MAKE SURE THE DIPSTICK IS a Beetle one and not chopped down from a Chevvy or something ! (it happens...)
Glenn Mr. 010
Posted: Sun Apr 20, 2014 5:41 pm Post subject: |
VWCOOL wrote: |
...yes and MAKE SURE THE DISPTICK IS a Beetle one and not chopped down from a Chevvy or something ! (it happens...) |
I'd hate having my dipstick chopped down. _________________ Glenn
Member #1009
#BlueSquare |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
