Viva.Sabata Samba Member
Posted: Sun Apr 20, 2014 10:22 am Post subject: Greetings! |
I could swear that there was an introduction sticky, but here goes anyway.
We are the happy new owners of a 1987 full camper, who we named "Josey". Love it! Thanks to all for the great information in the forum as everything I have needed so far has been discussed at length. Hope to pay it forward as I dig into the van.
My goal is to restore it to as near new condition as practical in preparation for retirement in 10 - 15 years. In the interim, Josey will be used for camping on the high school sports circuit for the next several years.
Things done so far are:
1. Overhauled right head due to sloppy re-build job/leaky intake valve seat.
2. Replaced ALL fuel system rubber including tank grommets/hoses, fuel filter, fuel pump, injectors and hoses. Most of the hoses were original and badly rotten. As stated numbers times on the forum, this is a must do!!
3. Replaced throttle valve with new to me Go Westy version due to slop in the butterfly valve shaft and hard to adjust switch
4. Replaced rusted out starter
5. Installed 16" Go Westy aluminum rims and new Michelin tires - huge improvement in handling!
6. Installed sound deadening material on front, slider, and rear doors
7. Replaced all hoses in engine compartment
8. Replaced pitted and cracked windshield and new seal
9. Installed headlight upgrade kit
10. Replaced pop top canvas with new synthetic type - awesome!
11. Full tune up
12. Replaced front window seals
13. Tinted all windows except windshield
Major projects for this summer are to:
1. Replace ALL remainder of cooling/heating system from pump to radiator
2. Install new LPG tank and propex heater at location of rear heater
3. Replace master cylinder while I have the dash out
4. Sound deaden the front panel while dash is out
5. Maybe get to mitigating minor seam rust
Any tips/advise on the cooling system replacement would be appreciated. For example, I plan to replace the thermostat housing with the Go Westy version and the coolant tower with the aluminum, one available at Van Cafe. All hoses, rubber, or-rings, sensors, and pipes will be replaced. Will also replace the heater fan motor when replacing front heater core. Are there other things I should replace while the dash is out, such as the wiper motor?
Thanks - happy to be a part of this cult![/list] |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Apr 20, 2014 10:56 am Post subject: |
I couldn't tell if your list includes replacing the radiator -- but replacements are cheap enough that this may be the time to do it. |
bluebus86 Banned
Posted: Sun Apr 20, 2014 11:06 am Post subject: |
when the dash is apart, be sure to replace the foam seals that go on the air flappers, The foam is failing by now, which means the air vents wont totally seal off, so you wont be able to keep out cold outside air when driving. so glue in some new foam seals.
And I did replace my radiator before it failed, I did like you , new motor so I replaced all the hoses, and the radiator too. my truck has a plastic tank radiator similar age and it cracked, not wanting a failure on the road, I replaced the Vans plastic sided radiator with new. new one is aluminum, old one was copper, but both have plastic side pieces. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sun Apr 20, 2014 2:04 pm Post subject: |
Welcome. Sounds like you have gotten off to an incredible start. Pictures or it didn't happen. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Posted: Sat Apr 26, 2014 9:03 am Post subject: |
bluebus86 wrote: |
And I did replace my radiator before it failed, I did like you , new motor so I replaced all the hoses, and the radiator too. my truck has a plastic tank radiator similar age and it cracked, not wanting a failure on the road, I replaced the Vans plastic sided radiator with new. new one is aluminum, old one was copper, but both have plastic side pieces. |
Yes - I am definitely replacing the radiator and the air ducts. With regard to the seals I don't recall seeing anything of that sort on the VC or GW websites. Does anyone have suggestion on a material that will last? |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Posted: Sat Apr 26, 2014 3:48 pm Post subject: |
Welcome aboard!
1. Post pics.
2. Add your location to your profile, so we have a point of reference for future questions and comments. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
