art_lessing Samba Member
Joined: February 20, 2014 Posts: 154 Location: Sacramento
Posted: Sun Apr 20, 2014 4:10 pm Post subject: 69 Ghia wiring confusion |
Does anybody know why this diagram:
Has nothing to to with the only available 69 GHia wiring diagram?
http://www.thesamba.com/vw/archives/info/wiring/ghia_67_USA.jpg
The Hazard switch is dead center at J6 with only three wires. K , S and ground.
Does anybody have a suggestion as to how I can combine the two? The wires dont match up
SOO conffuuuuuuuuuused!
DQ |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
mountainkowboy Samba Member
Posted: Sun Apr 20, 2014 11:41 pm Post subject: |
^ X2, that's the same switch my 71 has. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Posted: Mon Apr 21, 2014 12:27 am Post subject: |
Mine has the big blue box though..nine pins...can I just use select pins?
That diagram is for the 1970-1 ghia....with way more switches and buzzers than my 69.....made in 68....so at what point did they start and stop using the big blue box and was it ever in conjunction with the hazard switch with all the terminals on the back? |
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Mon Apr 21, 2014 5:56 am Post subject: |
Had a similar problem with my 69 UK car, seems to be a mix of 70/71 switches and relays, but with the rest of the loom largely unchanged from 67.
I have both diagrams printed out and if I can't find something on one, it's usually on the other _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Mon Apr 21, 2014 8:52 am Post subject: |
ok..so here's the burning question....what hazard switch goes with the big blue relay? It only should have three terminals And can I use the big blue relay with the normal hazard switch?
DQ |
Posted: Mon Apr 21, 2014 2:12 pm Post subject: |
Looking at the 67-69 Ghia wiring diagram here: http://www.thesamba.com/vw/archives/info/wiringghia.php
All the terminals used on that wiring diagram are on the blue relay in the advert, plus the colours on the bottom of the blue relay also match the wire colours on the 67-69 Ghia wiring diagram. 54 and 54f aren't used in the 67-69 Ghia loom, but then as the advert says these were used in bugs, buses, ghias, type 3's and type 34's, so it wouldn't be unusual to have a couple of extra terminals not used.
The 67-69 loom shows this relay in use with a three-wire "emergency light switch" (which I assume is the Hazard switch) _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Mon Apr 21, 2014 2:23 pm Post subject: |
I see the confusion now . The old volks home diagram you posted is more off a late 69 -71, and is of the switch for those years, not the relay . it will not have any relevance for you. follow the linked wiring diagram..... |
Posted: Mon Apr 21, 2014 3:53 pm Post subject: |
is there a way to plug that switch into the mix? I have both the relay and other but no 3-wire switch type ...I wonder how I would test the functionality of the complicated switch to find the right plug points.... |
