Info and Source needed T1 to T3 Dipstick
grandpa pete
grandpa pete is offline
PostPosted: Mon Apr 21, 2014 7:47 am    Post subject: Info and Source needed T1 to T3 Dipstick Reply with quote
Info and Source needed T1 to T3 dipstick part/adaptor....... ANY help appreciated....photo REALLY appreciated
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 21, 2014 9:20 am    Post subject: Re: Info and Source needed T1 to T3 Dipstick Reply with quote
Here's 2 links for the same part. The 1st one I couldn't get much firther than the pic and text.
http://www.kustom1warehouse.net/Oil_dip_sticks_and_blockoffs_for_VW_Volkswagen_p/page4-2011.htm
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5427
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Notch
Notch is offline
PostPosted: Mon Apr 21, 2014 9:32 am    Post subject: Reply with quote
I am not aware of an adapter that will allow you to check the oil on a standard Type 1 case. I believe the type one dipstick is in accessible when the Type 3 fan shroud is installed. The adapters Bob found are for adapting a Type 3 or universal case to use a type 1 dipstick. I don't know if any of these will clear a the fan shroud on a type three.
'64 Notchback
'67 Bug
(sunroofs both)
1964 Lavey Craft, Flatbottom V-Drive, 406 Ford
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 21, 2014 9:36 am    Post subject: Reply with quote
He has a type 3 engine case, and is looking at converting the dip stick to a t-1 style due to a lack of clearance in his "sedan delivery" project.
Tram wrote:
Tram wrote:
eyetzr Premium Member
eyetzr is offline
PostPosted: Mon Apr 21, 2014 9:39 am    Post subject: Reply with quote
Hey grandpa, I thought you had a type 3 motor in that project? I am with Notch on this the adapter will interfere with the fan housing, mount.
eyetzr is offline
PostPosted: Mon Apr 21, 2014 9:40 am    Post subject: Reply with quote
modify the type 3 tube & re route the rubber to connect the body portion to the engine.
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 21, 2014 4:45 pm    Post subject: Reply with quote
Have you looked at his project in the last couple of days? He's got a good chunk of t-3 load floor in place, and has already removed a 1.5 inch section out of the engine hatch, along with adjusting the rest of the floor to get it inside. Last I looked (earlier today), he was working on tieing in the "new floor to the bus walls. Twisted Evil He still had a gap between the bus rear door (narrowed), and the modified t-3 floor. That gap had a step in it too.
I had suggested it to him, as he might not have enough room for the oil filler and t-3 dipstick tube arrangement. Like he said himself, he wished he had the T-3 floor before he started, as he's about 8 inches short of getting things to fit back there (part of the reason for taking 1.5 inches out of the hatch). Shocked
Tram wrote:
Tram wrote:
grandpa pete
PostPosted: Mon Apr 21, 2014 9:51 pm    Post subject: Reply with quote
Bobnotch ; I like your idea of indenting the new vertical rear plate to fit oil dipstick tube and cap
63 two fold rag
eyetzr is offline
PostPosted: Tue Apr 22, 2014 4:57 am    Post subject: Reply with quote
hey GP, no Bobnotch I had not noticed the latest build update. But I would agree it looks like an indented panel on the floor & an indent on the lid would give him his clearance for the dip stick. You have a great build on the go. I guess the next car you will save more of the sections until you finish the car. Wink Wink
grandpa pete
PostPosted: Wed Apr 23, 2014 7:47 pm    Post subject: Reply with quote
Hello Bobnotch ; How would I go about turning the tube out of the engine so that it is more vertical ?..........TOOLS ,,,,,,,,,,TECHNIQUE ?................THKS
63 two fold rag
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Apr 24, 2014 6:11 am    Post subject: Reply with quote
If you turn it vertical you still have to indent it or it will be sticking up into the flat load floor? I have a black rubber mat on mine.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
eyetzr is offline
PostPosted: Thu Apr 24, 2014 6:32 am    Post subject: Reply with quote
I think he is going to have to indent or be real creative with the tube fitment. you will probably have to adjust the length of the dip stick as well.
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 24, 2014 10:02 am    Post subject: Reply with quote
With it bolted to the engine case, I'd use an oxy torch, and get the tube cherry red, and bend it up. I only say have it on the engine, so you know how far you can actually take it (the cooling shroud will limit how far you can go).
Tram wrote:
Tram wrote:
