FairfieldDave Samba Member
Posted: Mon Apr 21, 2014 7:47 pm Post subject: Brake job? |
Hey group, my back drum brakes are starting to grind a little (time to replace pads?) just trying to understand how big of a job it is to complete in my garage. Is it worth just having it done somewhere else? Also don't know what it's will cost?
Dave |
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Mon Apr 21, 2014 7:57 pm Post subject: |
Do you do any mechanical work yourself? Brakes are easy. Done them in all sorts of places,mostly out in the driveway so a garage would be a step up. Grinding is never a good sound and you may need your drums turned as well as pads. |
joeyk803c Samba Member
Joined: January 19, 2014 Posts: 102 Location: United States
Posted: Mon Apr 21, 2014 7:58 pm Post subject: |
Drum brakes aren't hard to do, they just take time. Search youtube, and watch a couple videos. I did them on my bug and so far so good (bug is rolling now, but stops when brakes are applied). Cost for you to do it, should be $40 for new shoes, a hardware kit and some brake cleaner. A shop will cost anywhere from $80+
The knowledge that you'll learn from doing your own brakes though is not something you can put a price on. |
LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Mon Apr 21, 2014 10:29 pm Post subject: |
If you decide to do it yourself, send me a PM and I will make a video and post it on Youtube for you.
It's really not hard at all, you will need a flathead screwdriver, a vice grip, 36mm socket, and a torque wrench. A hammer will be nice to take out a little horse shoe for your e-brake.
I think that's all you need. The only things you probably don't have are the socket and torque wrench which you can rent at AutoZone for free. _________________ one, two, many
one too many |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Tue Apr 22, 2014 3:31 am Post subject: |
I would think someone should mention the 300 ftlb axle nut standing between him and his break pads. Once that is off the rest is easy.
I doubt you have a torquemaster or a impact wrench. They are the right tools for the job. I just use a 3 foot breaker bar and a foot high stack of wood blocks. I put the wrench on the lug nut, and the other end on the blocks. I then drive the car, either forward or reverse thus spinning the axel. Wrench not spinning + axel spinning = loose nuts. |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue Apr 22, 2014 9:08 am Post subject: |
If you are going to change the pads on drum brakes you are misinformed and best off letting someone else do it. |
Posted: Tue Apr 22, 2014 10:39 am Post subject: |
Pads,shoes, whatever. Get over yourself. He is asking if he can do the job. He can if he is so inclined. It's not rocket science, no matter what you call it. |
Posted: Tue Apr 22, 2014 11:40 am Post subject: |
finefettle wrote: |
it is rocket science
by the time he fails to adjust them properly loses the pedal and pulls the master cylinder
you will understand |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Tue Apr 22, 2014 12:23 pm Post subject: |
If you decide to do it , do one side first leave the other one open for reference , once youre done with one side do the other ... |
gargamel Samba Member
Joined: December 20, 2011 Posts: 693 Location: Orange Grove, Texas
Posted: Tue Apr 22, 2014 12:52 pm Post subject: |
Just take pics with your phone, if you need a reference point. I did. One of those torquemeister tools (be it pricey) makes this job a breeze. I tried a breaker bar with a long pipe and got no where. Frustrated and tired of looking like fool balancing on the pipe to my neighbors, I ordered one and amazed how it loosened up in mere seconds.
Yes, there are a bunch of good videos to give you an idea. I had ZERO experience in this department (cars in general to be honest) and I have it down to doing the entire brake system. Just do your reading and watching.
Save and learn, at the same time. The alternative is to take it to a mechanic and you know how that will go. They will see you coming a mile away. No pun intended.
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Tue Apr 22, 2014 12:59 pm Post subject: |
DeathTrap wrote: |
finefettle wrote: |
There's a bit more to life than adjusting your brakes 2 or 3 times a day! It seems that's about all you get done... ADJUST BRAKES...ADJUST BRAKES... ADJUST BRAKES...............GET A LIFE!
mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Posted: Tue Apr 22, 2014 1:16 pm Post subject: |
put a favorite on this post mort
I am so old I did 4-5 vw brake jobs a day
I could sell the s::: out of them when all they needed is an adjustment
heck if I did the brakejob and they had half a brain they'd come back often for another adjustment
those that didn't got a new brakejob somewhere else
talked crap because I insisted on keeping them safe
or maybe they'd take it on and before ya know it they have the master out
in all the brake jobs I can't remember one master cylinder replacement
there's those tyhat do
those that have
and those that talk |
Your right. It's Socket science. You win
Good luck with your brakes. |
Posted: Tue Apr 22, 2014 1:29 pm Post subject: |
DeathTrap wrote: |
those that have
So why shoot the guy the down? He's asking a question? Because he said brake pads, instead of brake shoes?
This is the problem with America. Somebody asks about something, makes a minor mistake, and then people tell them they can't do it.
Why should any of us ever try to learn, or do something if there is always going to be somebody to tell us that we shouldn't, or we can't do it?
I say fuck them. I've had plenty of people tell me I can't do something, yet I do it or I try. I would never know if I could, or couldn't if I never tried. This is a forum for helping people, not shooting them down.
Sorry about the ignorant customers you've had in the past. I deal with ignorant ones today at my job. Saying that I'm just telling them they need extra parts so I can get more sales, instead of thinking, he's telling me these items are needed so the job is done right the first time, not the second and I don't have drive back up here. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Apr 22, 2014 1:48 pm Post subject: |
Funny how talking someone into buying something that will cost them money--something they don't even need, can be thought of as "selling".
A while back, I took my Del Sol in to get the wheels aligned, and they gave me an unasked-for estimate on a set of McPherson struts that they said I needed. $662.33, they wanted.
I took the car down to a wheel shop that usually does my bug alignment and the owner there says my Del Sol's struts are fine.
So, did Les Schwab try to "sell" me a set of struts, installed? Or did they just try to steal my money?
It's all a matter of opinion, I guess. But my opinion compelled me to turn them in to the California Bureau of Automotive Affairs today.
"Sold" 'em down the river, I did.
As far as this newbie's brake job, I'd say go for it. But first, watch a few You Tube videos on how to do it. A number of specialized tools are required, and also a feel for brake adjustment. Get a Hayne's or Bently manual, too.
Tim |
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Tue Apr 22, 2014 1:51 pm Post subject: |
You are NOT supposed to wait until it starts making expen$ive noi$e$ before doing a brake job. |
Posted: Tue Apr 22, 2014 8:58 pm Post subject: |
Tim Donahoe wrote: |
Tim |
There is a difference between selling, and stealing. They were trying to steal from you, not sell you anything.
That's how today's world works. |
