richardsvdubs Samba Member
Joined: January 27, 2014 Posts: 5 Location: Salyer CA
Posted: Tue Apr 22, 2014 10:08 am Post subject: New starter/extra wire |
I have a 69 bus. Bought new starter. It has one male connector. The old one had multiple connectors. There is one wire going toward the front of the bus. Small gage. Any ideas what to do with this or what it is for? |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue Apr 22, 2014 10:11 am Post subject: |
You need a manual for a bus! But it is an easy goody to hook up, that wire you have, is it red? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Tue Apr 22, 2014 10:24 am Post subject: |
It is solid white. |
1967250s Samba Member
Posted: Tue Apr 22, 2014 10:53 am Post subject: |
Sounds like a mod or replacement. The wire from the starter switch to the solenoid should be a @12 gauge/ largish red wire. Look under your dash and find where it goes. There are free wiring diagrams up in the technical section. |
Posted: Tue Apr 22, 2014 8:04 pm Post subject: |
Where does your white wire go? About the only thing I can think that someone would add to the #50 circuit would be some kind of alarm device, or maybe a bypass for an added external ignition ballast resister. |
