shugco Samba Member
Joined: November 25, 2012 Posts: 9 Location: Pahrump, NV
Posted: Tue Apr 22, 2014 11:25 am Post subject: 2275 build review |
I am a new builder that will have help, I have assembled my parts list and was interested in any input from others.
OG case opened for 94, full flow, tapped for turbo, dual relief
82mm DPR crank, VW journals
5.5 H rods
1.4 rockers
steve tims stage 2 heads 42x37.5, match ported manifolds
fk8 cam
dual 44s
13lb chromoly flywheel
kennedy pressure plate
wiseco or mahle piston kit
009 distributor?
blue coil?
bosch alternator? what size? small stereo, 1 subwoofer, 500 watt amp
lifters?
any other suggestions? Thanks
This will be a weekend driver, occasional drives on the freeway 100-200 miles. I will not be on the drag strip but I would like to put somehonda's to shame every now and then.
rustybusjef Samba Member
Joined: December 19, 2011 Posts: 329 Location: EVERETT WASHINGTON
Posted: Tue Apr 22, 2014 12:14 pm Post subject: |
Try a 010 dist instead of 009. Also you could use AA P&C's . Dont waste your money on scat rockers , both sets of mine were machined wrong , try CB Performance maybe bugpack |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Wed Apr 23, 2014 2:08 pm Post subject: |
rustybusjef wrote: |
Got Scats in mine and their fine. They replaced Bugpack roller bearing setup which were nothing but hassle. |
shugco Samba Member
Posted: Fri Apr 25, 2014 7:40 am Post subject: |
I've already ordered the SCAT rockers, fk8 cam, heads and manifolds. I am wondering which lifters to order, what cam gear, what pushrods, and kennedy stage 1 or 2? |
Bobthepilotguy Samba Member
Joined: March 28, 2008 Posts: 40 Location: East Tennessee
Posted: Fri Apr 25, 2014 7:50 am Post subject: |
shugco wrote: |
I have had good luck so far with engle lifters on my 2332 with fk8, cb 044's, dual springs, and 1.4 rockers. If it were me I'd get cb straight cut cam gears, cb chromoly push rods, and a kennedy stage II (you said "tapped for turbo" so I'm assuming you're going to turbo the motor). Depending on how much boost you might go with a puck style disk as my stage II is currently slipping with 9lbs and a solid disk. _________________ This is a test of the emergency tagline system. Were this an actual tagline, you would see amusing mottos, disclaimers, a zillion net addresses, or edifying philosophical statements. This is only a test. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Apr 25, 2014 9:03 am Post subject: |
shugco wrote: |
CB lightwieght lifters, Cb straight cut gears, Manton CTF chromo pushrods, Kennedy Stage 1 with Kush lok disc. Except for the Cb straight cuts I run this exact set up and Scat straight cuts on my 2276 86C daily. Mine hooks right up... _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
shugco Samba Member
Posted: Fri Apr 25, 2014 10:37 am Post subject: |
thanks.. I am not going to turbo for a little while but ill still go stage 2 so im not buying twice. I'll go ahead and order the straight cut cam gears, engle lifters, and chromo push rods. I was leaning in those directions but needed input as ive never built bigger than 1600. |
Posted: Sat Apr 26, 2014 1:44 am Post subject: |
NO. Order cb lightwieghts not engles. Pay the extra 70$ its worth it. _________________ 2276 IDA's 86C 11-1 DD !
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat Apr 26, 2014 2:37 pm Post subject: |
X2 on anything other than Engle lifters. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
