electronictofu Samba Member
Posted: Tue Apr 22, 2014 12:13 pm Post subject: Accelerator Cable Setup |
I ordered a new accelerator cable, as well as the kit through Wolfsburg. It came with everything, but I don't seem to have the pin that connects the cable to the top of the rod. Anyone know what goes in there? Size, or where to find a replacement? Can't seem to find one on their site.
Or do we just bend the hoop back a little bit so it slides over? I've seen a couple setups in the gallery. Not sure what's best...
jeffff Samba Member
Joined: February 23, 2006 Posts: 1044 Location: Alberta, Canada
Posted: Tue Apr 22, 2014 12:50 pm Post subject: |
It just "hooks" in there, no pin. |
Stocknazi Samba Member
Posted: Tue Apr 22, 2014 1:07 pm Post subject: |
I have seen them installed w/o a pin.
I used the pin to install mine; it slides through the L-bracket and cable eye and is held on the other side with a cotter pin. Seems to work fine,
111 721 529A is the part number
WW lists the pin for bug -57; no listing for a bus, not included in the accelerator lever kit either.
I have always been curious if the pin was og used on buses, hopefully someone will chime in that knows. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
jeffff Samba Member
Posted: Tue Apr 22, 2014 1:29 pm Post subject: |
According to the Bentley manual.....it shows NO pin. |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Apr 22, 2014 1:34 pm Post subject: |
I've only ever seen the hook thru the bracket. Yes, you have to open it up a bit to make it fit. Not sure why that is, but its simple enough to do. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Tue Apr 22, 2014 6:37 pm Post subject: |
Definitely a pin.
Lots of info like this in the "Parts Reference Manuals" here:
http://oacdp.org/
See links at bottom... _________________ In Stereo, Where Available! |
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Tue Apr 22, 2014 7:29 pm Post subject: |
thanks for the link Everett , I really needed a good laugh today.
_________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
Posted: Wed Apr 23, 2014 12:22 am Post subject: |
mtb7001 wrote: |
Hahaa... holy crap... balls.
Awesome. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Apr 23, 2014 9:53 am Post subject: |
Eric&Barb wrote: |
Definitely a pin.
http://oacdp.org/ |
If you're talking about 81, that is for the pivot: not holding the end of the throttle cable, right?
http://oacdp.org/5867part/367.png |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Wed Apr 23, 2014 11:05 am Post subject: |
EverettB wrote: |
From that thread:
EverettB wrote: |
The cable attachment was changed Nov. 4, 1960, VIN # 678 336
Accelerator cable
Now: Cable eye hooked directly
into the hole in pedal lever.
Formerly: Secure with bolt,
washer and cotter pin. |
That explains why mine has the pin. Started to wonder after seeing other posts... _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
Posted: Wed Apr 23, 2014 6:25 pm Post subject: |
BarryL wrote: |
Eric&Barb wrote: |
Definitely a pin.
http://oacdp.org/ |
Correct! Darn, our 1958APR manual shows a part 73 in the same diagram. Part number 111 721 529 A Bolt - Accelerator cable (front) Qty. 1. Along with a washer and cotter pin. _________________ In Stereo, Where Available! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
