Heathejj97 Samba Member
Posted: Tue Apr 22, 2014 6:07 pm Post subject: Drive without the running boards? Recomended? |
Ok so my running bored are rotten and gross and flex, whats worse is people keep using em as sidesteps to enter the car! Thoughy my heater hannels are fine externally tho rusty inside acirding to my inspection camera :/ id like to remove en all together and psint the outside of heater channels too, is that ok for the car? Cheers |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Apr 22, 2014 7:19 pm Post subject: . |
I think of the running boards strictly as an ornament, giving the aesthetics of the side lines continuity from the front to the back. The Type 1 looks finished with the running board in place, but there is more than one way to do anything.
I say, leave it off if that suits you. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Tue Apr 22, 2014 7:35 pm Post subject: |
Ok asesome and any bolt holes showing ill just fill with bondo them and respray em thanks |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Tue Apr 22, 2014 7:44 pm Post subject: Re: . |
ZENVWDRIVER wrote: |
I say, leave it off if that suits you. |
The rear fender of your beetle takes enough stone/rock damage kicked back from the front tire with running boards in place. Remove it and you'll be getting many more chips out of your paint. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Apr 22, 2014 8:48 pm Post subject: |
Please do this- remove one board- then jack up that side of the car. Lay on the ground and look up. The reveal of door seal and door bottom, the bottom edge of the rear quarter panel and the leading 2' of the rear fenders will all be exposed. If they are in good shape now- just wait a couple seasons after pummeling them. Yes, I am pro-running board, and I vote. _________________
EverettB wrote: |
FU#5 |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Wed Apr 23, 2014 5:09 am Post subject: |
I have seen running boards removed and sheet metal used to cover the heater channel. A couple of those folks also welded/body filled the holes in the fender used to mount the running boards. I also bought a VW once with check plate aluminum running boards. They were stiff enough to use as steps to enter the car. The man I bought the car from has fabricated them very nicely.
It is advisable to use gravel deflector shields on both front and rear fenders to keep from beating the paint off them. |
Posted: Wed Apr 23, 2014 7:30 am Post subject: |
Ill take em. Off and make a shield now cheers |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Apr 23, 2014 8:15 am Post subject: |
DON'T Bondo over the holes! You may want to put running boards back on once you discover what happens when running without them.
If cash is a problem, buy a cheap set of mexican boards. They'll be OK for a while.
Keep in mind your running boards are the way they are now because of the job they do! All that stuff beating them to death so they rust away will be beating on the rest of the car if you remove them.
So think of the running boards as a sacrificial part that you need to throw away every 10 years or so. It proects the rest of the car. Remove them and you will be throwing away doors, quarter panels, rear fenders.... _________________ Mother Nature is a Mean Evil Bitch! |
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
Posted: Wed Apr 23, 2014 9:00 am Post subject: |
Beetles without running boards are like chicks with beards, just wrong!
Buy a cheap set new or 2nd hand and paint them before putting them on. They will last for years! Better to educate your buddies that the boards are not for stepping on. _________________ 1962 Gulf Blue Patina Deluxe Beetle
1963 SubHatch Westfalia MG/PW
1967 Fastback RHD Regatta Blue
1970 FI Auto Squareback
1999 T4 Transporter 2.5 TDI Reimo
http://www.youtube.com/@BuscowboyClassics
https://www.instagram.com/buscowboy/ |
hitest Samba Member
Posted: Wed Apr 23, 2014 9:16 am Post subject: |
Well, we tried... _________________
EverettB wrote: |
FU#5 |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Wed Apr 23, 2014 6:28 pm Post subject: |
My baja don't need no steenking runnning boards _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Wed Apr 23, 2014 9:44 pm Post subject: |
Ahhok true they can stay ill grund rust off em and re inforce em with steel till i can afford new onss |
