oasis Samba Member
Posted: Wed Apr 23, 2014 9:17 pm Post subject: hard top weight |
I had planned on conscripting my brothers-in-law and nephew to help take the hard top off of Thing and onto its cart in storage last Sunday. I didn't do it because all family members were engrossed with serious matters and fond remembrances of my father-in-law who recently passed away.
So, the top still needs to come off.
My wife and I wrestled with the cap off of our Rabbit Pickup some years back, and clearly the Thing top is heavier. I think the two of us plus our 23-year old daughter and her boyfriend can do it. My wife thinks it is too heavy.
I have average strength. My wife and daughter have a certain toughness about them but they are somewhat slight at 5'4" and 5'3".
Am I endanger of the top crashing onto Thing because it is too imposing for the four of us to handle? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Thu Apr 24, 2014 5:27 am Post subject: |
Found this on the web:
Fiberglass and glass hard top for VW Thing.
Length: 7 ft 0 in
Width: 4 ft 6 in
Height: 2ft 0 in
Weight: 100 lbs _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Thu Apr 24, 2014 7:10 am Post subject: |
I've lifted mine off by myself several times. I climb into the car, unbolt and unclip the top, and then lean over the front seat. Reaching out my arms (I have a nearly 7' reach side to side), I grab the rails on the edge and then stand up, lifting the top off the car. I then lean back, which puts it back over the rear, so it's absolutely free of the lip on which it rests. I then walk out of the car, while holding the front up until I get out of the car, lowering it gently down to rest on the steering wheel. I then walk around to the rear and grab the heavy rear section of the top, lift and then pull it back, letting the front of the top reat on the top of the front seats. I then do a shifting of its weight, bringing the front of the top up and completely off the car, while holding it by the rails. I then lower it down to the ground, resting on the rear edge. Once it's on the ground, I move it with a hand truck to a corner for storage.
It's a LOT easier with two people. I wouldn't suggest using more than two people, as you'll be bumping into each other.
If you can't find a second person, I'd suggest using a kayak hoist or something similar to lift it off the car. |
Semper_Dad Samba Member
oasis Samba Member
Posted: Thu Apr 24, 2014 11:50 am Post subject: |
100 lbs? Maybe its bulk made me think it was heavier when I was fitting it on correctly. (The knucklehead who transported it had it cockeyed and secured with two measly bolts.)
The hoist is nice but unfortunately the house we moved to does not have a garage -- my one requirement that got forsaken. I do have a drive in storage area I rent for it and the excess goodies we didn't toss before the move. I won't be constructing anything that elaborate there. I'll be just using a top cart I "won" on eBay.
Sounds like I can conscript my daughter's boyfriend and have my wife and daughter there just in case. Then, we'll go for a no top ride until I get the softy on board.
Thanks for the info! _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Fri Apr 25, 2014 9:26 pm Post subject: |
My lid (that I never use anymore) is a fiberjet. I got pretty good at taking it off and on by myself...physics. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
kubelmann Samba Member
Posted: Sat Apr 26, 2014 12:35 am Post subject: |
My wife (4’ 10”) and daughter (5’) are and I (5’7”) used to lift the factory hardtop with steel side supports in-place off the car every spring. After unbolting the top with the front latches released but still with the retainers in place, my daughter and wife lifted at the rear corners as I lifted from the rear center. Once the got a good hold on the rear, I went inside the car and we walked the top off the back of the car. I set the front edge of the top on the far rear edge of the car. Then I stepped outside and we lifted the top off the rear of the car and set the top on its (very simple) cradle (constructed from 2"x4”s) for the season. Using this system we never had to stretch or strain. The top on its cradle also doubled as a great storage area for various in-progress projects. There are also loads of folks who have built a winch that hangs from the rafters of inside their storage building. |
oasis Samba Member
Posted: Sat Apr 26, 2014 11:32 pm Post subject: |
Haha, building a winch ... it took me loads of time and my entire down-by-the-docks vocabulary to build the top cart ... but it's built!
This is from an eBay ad. This is essentially what I built:
Edit: This pic shows angled little bars from the upright back to the base that is parallel to the floor. Mine does not have these, but it does have two cross members across the base as well as across the back.
FWIW, everyone's instructions on how to do it is much more clear than the rubbish piece of paper that came with this cart. Hopefully, I'll have some genuine pics to show the happy results or the damage. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
oasis Samba Member
Posted: Mon Apr 28, 2014 7:23 pm Post subject: |
Okay, then. A two part delay.
One was getting the bolts off. That delay was annoying but has a solution. I need the right tool for the right job.
The other part I'm not so sure about. The stand on wheels seems to be intended for smaller tops than the Thing top. One possible solution is to place the top 180 degrees about as in the pic above -- that is, instead of the top of the top being against the high cross bar, having the inside of the top of the top against the high cross bar. From the above view, one would see the inside.
However, I'm not overly confident that will work. So, next question ...
Would I be risking (or guaranteeing) damage to the top if I propped it up against the back wall of storage?
I would use rugs and such so it wouldn't get scraped. I'm just wondering if the back glass or the entire back panel would crack by bearing the weight. Having it take up space by being in its normal position but on the ground is not an option. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
oasis Samba Member
Posted: Tue Apr 29, 2014 8:16 pm Post subject: |
oasis wrote: |
Would I be risking (or guaranteeing) damage to the top if I propped it up against the back wall of storage? |
I'm a little surprised no one has experience or an opinion on this.
Maybe I can trade the top for some work. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
surfarii Samba Member
Joined: November 26, 2006 Posts: 307 Location: Hawaii
Posted: Wed Apr 30, 2014 12:07 am Post subject: |
Oasis,
Have you tried setting the top in the rack as described? If so how does it feel?
Sounds like that hard top is more trouble than it is worth.
Maybe sell it and get a soft top. |
hwyellow Samba Member
Posted: Wed Apr 30, 2014 1:42 pm Post subject: |
oasis wrote: |
I'm not saying this is proper top storage, but i've always just laid mind on a side against the wall. The fiberglass flexes a little but not bad. I've thrown around the idea of selling it and getting a soft top as it is a PITA to remove and store. |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Thu May 01, 2014 6:27 am Post subject: |
Having owned both, I would say the factory vwoa top is much heavier than the fiber jet that I have now, actual weight unknown, atleast a two person job to remove or put on |
oasis Samba Member
Posted: Thu May 01, 2014 10:53 am Post subject: |
surfarii wrote: |
Have you tried setting the top in the rack as described? If so how does it feel? |
Not yet. I was thwarted in my efforts earlier this week in trying to take the bolts out. The ratchet/socket set is piecemeal and the wrenches I have are all long-handled. So, I only got half of them off.
Last night, I endured a three-hour drive home from work in the monsoon with a tornado watch and bought a set worthy of someone who knows what they're doing -- which 90% of the time won't be me.
My observations earlier in the week was just me eyeballing the rack near Thing. My one and only tape measure was left at home as I was not expecting to need it. The rack looks like it is more suitable for tops from a little T-Bird, Mercedes, Miata, and the like. It might still work by inverting it.
surfarii wrote: |
That's what really is chapping my rear bumper. It had the soft top on it when I bought it. It was taken off and placed inside for transport with the hard top then installed. If I knew then what I know now, I would have told the seller to keep his hard top.
If I get the hard top stored properly, I will try to sell it. If it becomes too problematic, I may give it away in some elementary trade.
Tonight, I will look at what I might be able to do in hanging it on the back wall of the storage unit. Hopefully, that set-up won't be as involved as a hoist. We'll see. Maybe the rack will work after all. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
FV195 Samba Member
Posted: Thu May 01, 2014 3:18 pm Post subject: |
So my friend is scrapping a Jetta, and have me the small rear wing that was on it, I'm going to mount it on my hardtop. Think of the downforce, and the cool factor, yes I make myself laugh |
oasis Samba Member
Posted: Sat Jun 21, 2014 5:03 pm Post subject: |
Here's the assembled rack. There's enough Thing in the pic to give you an idea it has a good chance of not working.
There are two hooks on the side wall (hard to see, sorry) I was trying to think of a way to utilize so I could rope the top there against the wall.
Having a hoist like some people Have (very nice) just isn't feasible with a rental unit that has a somewhat low ceiling and this pipe in the middle.
I may be destined to sell the hard top. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
