Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Thu Apr 24, 2014 12:45 pm Post subject: Some 'what is its" ...help appreciated |
My 66 bug project came with a small tub of odds and ends in the trunk. Found some useful stuff (the missing rear seatback shoulder bolts ..) but also some stuff I can't quite identify. Two of the skinny-headed bolts; two of the small tubes with a hole and tightening bolt gizmos. Perhaps some of you more experienced Beetlers can help out. Check the photo and let me know. Thanks.
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Apr 24, 2014 12:50 pm Post subject: |
looks like a broken off battery lug, adapters for fuel cable & clutch cable. The short bolt with the large head looks like an adjuster off a refrigerator. the last piece looks like a spacer for a keyed shaft. Hope this helps |
Posted: Thu Apr 24, 2014 1:25 pm Post subject: |
Okay ..perhaps I should have been more specific. Here's the pic with the items numbered, 1 through 5. Item # 2 is definitely NOT a broken battery lug. The part on the bottom right is not 'broken' ...just worn. And #3 is not a fridge leveling foot ...the flat bolt head is less than 3/4 inch wide, and the threaded part is less than a half inch long (VERY tiny fridge??). #4 takes an 8mm wrench on the bolt, and the bolt head is marked KAMAX 5.6 ..
So, let's try again ...okay?? Thanks
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Thu Apr 24, 2014 1:27 pm Post subject: |
Left to right, and then foreground:
Fan hub, Broken marine battery post adapter, rear seat pivot bolt, heater box cable / accelerator cable clamp, accelerator cable shortening adapter. _________________ Good Luck
Al |
Posted: Thu Apr 24, 2014 2:03 pm Post subject: |
Okay, thanks. I'll defer to your expertise on all except #3. Not a rear seat pivot bolt. THIS is a rear seat pivot bolt ...and I found two of them in the tub ..not chrome though. Lots of patina. LOL.
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Thu Apr 24, 2014 10:51 pm Post subject: |
#4 is a barrel nut used to hold accelerator cable at the carb., and used at the heat exchangers to hold the heater control cables to the spring brackets that open and close the heater flaps. |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Fri Apr 25, 2014 6:59 am Post subject: |
Memories fade, but after 4 + decades of rebuilding 200 + engines and buying, refurbishing, repairing and selling 58 different VW's, # 4 doesn't ring a bell with me. I've completely blown apart 5 VW's to build kit cars, a dune buggy, and a homemade rail since the 70's, and I don't recall seeing that part. When someone more knowledgeable identifies it as a "xxxyyy" and it really does come on a VW, I reserve the right to plead ignorance and advanced years.
Perhaps it really IS a leg adjuster for something smaller than a refrigerator. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Apr 25, 2014 7:15 am Post subject: |
#4 is a throttle cable adjustment stop. Part number 111 129 921.
In all my decades of dropping 200 + engine parts on the ground, all of them have had 9 digit part numbers.
I have seen #3 somewhere. When I drop one out of my car- I'll see where it came from! I'll have a definitive answer by Sunday... _________________
EverettB wrote: |
FU#5 |
Posted: Fri Apr 25, 2014 7:33 am Post subject: |
Thanks for all the input guys. So, if I put my "Mentalist" skills to work, I could surmise that at some point in my bug's life (...get it: Bug's Life ...) it has had some major overhaul work done on the fan, carb, etc. ...and perhaps a previous owner took the battery out of his boat and put it in his car. There was a complete Solex Pict 30 carb in the parts tub as well ..I suppose I should keep that, rebuild it and use it for a spare. I guess this whole episode lends credibility to the advice to bag and label the parts as I tear my bug down for the rebuild ..... |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Apr 25, 2014 3:57 pm Post subject: |
drs1023 wrote: |
Memories fade, but after 4 + decades of rebuilding 200 + engines and buying, refurbishing, repairing and selling 58 different VW's, # 4 doesn't ring a bell with me. |
#4 is a barrel nut (VW part #111 129 921) Without it, how are you attaching the throttle cable to the carb linkage? _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
templeofspeed Samba Member
Joined: June 06, 2007 Posts: 279 Location: Central midwest
Posted: Fri Apr 25, 2014 6:43 pm Post subject: |
#3 is part of a rubber fuel pump mount, which would have been two metal parts vulcanized to rubber. If 5mm thread probably one of the fuel trap mounts used on mk2 jetta/golf. Or old GM A/C condenser mounts... _________________ Is your suspension broken? |
Posted: Fri Apr 25, 2014 6:45 pm Post subject: |
_________________ |
See, I can't even type # 3 properly |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Fri Apr 25, 2014 6:54 pm Post subject: |
RareAir wrote: |
1: alternator/generator cooling fan hub
2: ???
3: ???
4: barrel nut for heater box cable/accelerator cable clamp
5: accelerator cable shortening adapter. |
Agreed, although #5 was also sold as a broken throttle or heater cable repair end
eyetzr wrote: |
looks like a broken off battery lug |
Agreed, #2 broken battery terminal adapter, commonly used in Marine, truck or RV battery's
templeofspeed wrote: |
#3 is part of a rubber fuel pump mount, which would have been two metal parts vulcanized to rubber. If 5mm thread probably one of the fuel trap mounts used on mk2 jetta/golf. Or old GM A/C condenser mounts... |
Agreed, #3 is only 1/3 of a broken rubber insulated mount, also commonly used to mount electric air pumps on New Beetles. IIRC also once used to mount Rabbit and Dasher radiators...
_________________ -Bruce
An ounce of prevention is worth a pound of cure.
Posted: Fri Apr 25, 2014 7:02 pm Post subject: |
I think you maybe onto something there: there are two of them, and upon close examination, one of them has some black rubber residue on the bottom side. I've seen similar mounts used on some antennas, etc. as well. Perhaps it didn't "belong" in that tub of VW bug leftovers afterall.
Now that I know I don't need them for the VW rebuild, perhaps I'll used one to level that wobbly filing cabinet in my office!!
Thanks for all the input guys!! |
grandpa pete Samba Member
