RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Thu Apr 24, 2014 6:17 pm Post subject: Poor mans dakota digital |
Less than $30 shipped from Hong Kong. Cold junction compensation, 18' k type wire, ss sheathing, blue digital display that refreshes every 1/2 second. The electronics look top notch but the plastic housing is second rate. I'll consider it an experiment if it breaks in a week. At least the thermocouple looks like it will last. _________________ 69 Westy |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Thu Apr 24, 2014 6:25 pm Post subject: |
Im game.... gotta link? _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Fri Apr 25, 2014 9:04 am Post subject: |
eBay, just search "dc thermocouple meter". The same guy can sell custom length thermocouples.
I took a look inside and I am almost positive this thing doesn't have cold junction compensation, even if the literature says it does.
(Ambient temp -72)+meter = actual CHT
I'll keep a thermometer on the dash for reference.
Here it is mocked up.
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Apr 25, 2014 9:18 am Post subject: |
Well, it fits nicely in that block-off plate, which is where I would consider putting gauges anyway. But the display is bigger than it has to be. I expect an electronics whiz could redo a readout that would be much smaller, which would allow more room for other gauges there.
I look forward to hearing about what you think of the thing once you have tried it out for real. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Fri Apr 25, 2014 9:25 am Post subject: |
I think the size is just right. The numbers are like an inch tall. Big enough where I won't be looking at it all the time but if I see a 400 I'll know right away. _________________ 69 Westy |
mojogoat Samba Member
Joined: February 25, 2013 Posts: 440 Location: Norcal
Posted: Fri Apr 25, 2014 10:26 am Post subject: |
I see some with 4 readouts, interesting, looks like I'll have to buy a couple, great find and thanks for sharing. _________________ 77 Riviera
78 CEII Westfalia |
WendyArmbuster Samba Member
Joined: March 03, 2006 Posts: 330 Location: Springfield, MO
Posted: Fri Apr 25, 2014 10:57 am Post subject: |
I'm glad you mentioned this. I am planning a poor man's cht gauge too. I am going to buy some thermocouple wire and a MAX6675 temperature compensated amplifier chip for it, which will output to a Picaxe chip, which will send a signal to a servo that I am going to mount in my clock block plate for analog CHT. There's a few other parts I'll need, like a 5v regulator for high noise applications and some capacitors and resistors, but I'm hoping to build it for less than $50. A lot of time, but I enjoy electronics projects.
Chips that amplify thermocouple voltages often have temperature compensation, and are pretty cheap when bought in bulk. I wouldn't doubt if yours has temperature compensation. It's sort of amazing that the vdo gauge doesn't. _________________ Brian Z
1978 Westfalia |
Posted: Fri Apr 25, 2014 11:17 am Post subject: |
Brian, my original idea was to put in an audrino board with multiple sensors for cylinder head temp, oil temp and oil pressure all displayed on a nice digital face that would fill the radio hole. Throw in a time display and a buzzer for programmed high temps and I'll be set. Maybe one day. _________________ 69 Westy |
sambabus Samba Member
Joined: December 02, 2009 Posts: 324 Location: N. Cal
Posted: Fri Apr 25, 2014 1:16 pm Post subject: |
I'd like to use an old android or iphone as a color touchscreen display and use one of the many apps that work with OBD2 cars. Maybe adapt a computer from the junkyard and just use the sensor part. There must be someone in this group that can hack this.
I also have my gauges mounted in the radio blank... _________________ 1971 Westy, 2017cc 78.4 x 90.5 Tims Stage 1 plus 42x37, CB 44IDF's, 135 mains, 175 airs, F111, 50 idles, Engle 110, 30mm, 009, single QP, DD CHT 300*f, VDO oil always 180* Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=541370
1970 convertible bug, 1835cc, single 40IDF, disks.
Symptoms Solved and Fixed http://www.thesamba.com/vw/forum/viewtopic.php?t=551358 |
bigdan.theplumber Samba Member
Posted: Fri Apr 25, 2014 4:32 pm Post subject: |
So, I hardly ever post anything on here. I mostly just lurk but, this is a subject I've given quite a bit of thought to.
I've been wanting to make an Open source OBD2 compliant ECU based off of an arduino. By making it OBD2 compliant you could output sensor data in a format that is readable by many scan tools. Specifically, I would like to use one of the bluetooth ones based off the elm327 chip so I can use the "Torque" app on my android tablet which I intend to mount in a custom headliner console above the dash board. I also intend to have a bunch of RGB LED's controled by the android tablet and an arduino so, I can make my bus look like a UFO (LOL).
Reading sensor information is fairly easy with the analog inputs. So, things like oil pressure, oil temperature, should be easy, Reading micro voltages seems a little tricky so things like CHT or a wide band O2 Sensor seem a little difficult but it would be pretty sweet.
I'm interested in trying to use the chinese CHT module with an arduino. I may have to buy one of these soon to try it out. MORE RESEARCH!
I work with arduinos on a regular basis so I feel comfortable with doing it. It's mostly just a matter of devoting my time. I barely have enough time to work on my bus as it is. |
Posted: Fri Apr 25, 2014 5:49 pm Post subject: |
I just ordered a wifi elm327 to work with my iphone, the bluetooth one doesn't. How much does a arduino cost? If you did it that way it would be a standard platform. _________________ 1971 Westy, 2017cc 78.4 x 90.5 Tims Stage 1 plus 42x37, CB 44IDF's, 135 mains, 175 airs, F111, 50 idles, Engle 110, 30mm, 009, single QP, DD CHT 300*f, VDO oil always 180* Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=541370
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Apr 25, 2014 8:41 pm Post subject: |
Or this:
http://www.ot-2.com/ _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Brian Samba Moderator
Posted: Sat Apr 26, 2014 2:54 am Post subject: |
You could probably make it work with obd1 if you have it by just jumping the pins, they do make adapters for that I believe. its just a matter of making the sensors work.
Fun fact, VW came out with the first OBD in '69 for the type 3. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sat Apr 26, 2014 3:01 am Post subject: |
sambabus wrote: |
How much does a arduino cost?. |
Not much, ~$30. Same as a raspberry pi or a beagleboard.
I do really like the idea of using obd2 with engines that don't have it and just send the scanner false data to make it work. I've had many thoughts of doing something like this, so I would love to see this play out. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sat Apr 26, 2014 5:23 am Post subject: |
So Im Very New learning my equipment for this project,
In the first picture you have a thermocoupler cable that has 2 loose ends, but all the ebay sellers show it having the yellow type connector. did you just cut the end and put your own leads on?
Also How do you drop the motor with the leads attached? Or if you damage the Coupler at the head, is there a way to have a short 3'-6' lead with a connector to the line that goes forward? For easy replacement?
Edited for above..... So I see connectors are available, is there any parasite loss other considerations when using the connectors vs a single wire to the unit?
Also, none of the auctions mention about cold junction compensation, was there a particular one you got or just noticed when you got it? _________________ Rebuild your own FI Harness..My Harness
Posted: Sat Apr 26, 2014 6:18 am Post subject: |
Thermocouples are simple. Two wires of different metal welded at one end will make a voltage at the other. The cold junction is just the end of the wires where you connect to the meter(since this wire has no breaks or extensions).
There are connectors made that match the two same metals in the wires. This way you can have a disconnect in the engine bay and have no effect on the reading. Each wire/tab/screw only touches matching metal so no voltage is created.
My wire came with the tabs on it. I just cut them off and striped the wire back to go on the meter. "Cold junction compensation" is written in the instructions but the whole thing is such a bad misspelled translation I don't know what is trying to be said. I did let it sit in the bus a few hours yesterday and it did read close to the correct temp from a thermometer I had a few inches away. Maybe there is an actual cold compensation circuit I there somehow. _________________ 69 Westy |
Tcash Samba Member
Posted: Sat Apr 26, 2014 11:31 am Post subject: |
Spot on!
There is also a red faced meter and a "4 readout" meter that will work. I don't want this to turn into an ad for the guy but that's what I bought.
I don't know if the EGT probe will work anywhere on a head, but should read just fine as long as you stay with a K type.
Also make sure you get a "Fahrenheit" meter. _________________ 69 Westy |
Tcash Samba Member
Posted: Sat Apr 26, 2014 11:51 am Post subject: |
Thank you.
I was thinking you could buy another meter and EGT sensor, weld a 1/8 NPT bung into the exhaust collector and collect that data. |
Posted: Sat Apr 26, 2014 12:00 pm Post subject: |
Not a bad idea. The radio delete plate is almost made to hold two meters. I'm thinking if this one works out I might want another for oil temp.
